HB RGT8
#46
With the split of HPI and HP there is not much going on with the onroad cars of HB, it seems the HB brand is only focused on the offroad section.
I would sugest the Mugen GT, it is a good car and easy to get. But so far the rules say you can not enter the Dutch GT cup with a car other than Serpent.
#47
Thats a matter of time. Basically there is no such thing as the Dutch GT cup as there are no rules defined. The only real thing which has been agreed with the Nomac organisation is to allow the 1/8 GT's to run in paralel with the 1/10 nitro championship. All the rest is a bunch of meaningless hot air.
Will go for the Mugen I guess...
thx for the advice
w.
thx for the advice
w.
#48
Willem, good to hear your enthusiastic with this new class.
Maybe there will be rules next year, could be best to wait for this to happen I think. Ask Richard perhaps.
Regards JW
Regards JW
#49
#50
Just purchased a RGT8 and have 6 degree castor blocks that were made for the GT. This car is going to be solid once I get it together and do some tweeking. I have run both Serpent and Mugen cars. I am sure this one with the right driver and set up will compete just fine. The GT class is growing slowly. I will give updates on the build. I also have new hard arms that are available. This will give a great tuning option. Can do stock arms with plastic or carbon stiffeners or hard arms with plastic or carbon stiffeners. The also have a new b-block for the new D817 which will help tune kick up. I am loving this thing so far.
Part number for GT castor block HB204333
+1.4 b-block HBS204053
Hard arms 115835 and 115833
#51
Kit went together flawlessly. NO rubbing of ackerman and diff case!
HB did a great job and even included the hard arms. Didn't know that until I compared
part numbers. 6 degree caster blocks and 0 degree steering blocks installed too.
I went heavy on the rear diff. 50k instead of 10k. Pistons are 2 hole 1.3 in front and 3 hole 1.3 in the rear with 550 weight oil. That worked well on my mugen so I am going to start there.
I may not get a chance to run this car before leaving on business for a couple of months. However, will be handing the car over to an offroad team driver who will be starting to run onroad to test.
#52
#53
Now the fun begins with adjusting the 2 speed. The manual didn't give too much info at all. I will play around and see what works with the 2 speed in terms of how many turns out from the adjustment screw are needed to get you in the ball park. I set it up close to the way I would build my mugen's but every manufacturer is different. Maybe I can do a video. I just want to make this class grow with support from any team. It's such a fun class and if you are an offroad guy it's an easy transition to onroad.
#56
Finally got to run my RGT8. Very easy to drive and consistent lap times. Still need set up work and testing for the track I run at to get the best out of the car. Also started RGT8 FB page for other to share info.
https://www.rccaraction.com/hb-racin...ut-2018-euros/
#57
Had a great weekend. Took 3rd place at a race at Steel City RC. Did some major set up changes to make the car handle better. I have a second car now to play with. I switched the springs front and rear to run the harder springs up front. I also went to 1000cst oil in the front and 800cst rear. Droop went to 11mm front 14mm rear with 8mm ride height front and 9mm rear. Layed the shocks all the way down. I am running on a high grip track with very smooth asphalt. My lap time went from 22.5 with stock set up to 21.2 with current set up. Still breaking in a new motor so I think I can scrub a little more time off once motor is broken in.
#59
You going to be using the 2 speed? I might go a bit taller gear for second gear for higher top end depending on length of the drag. I also just recently flipped my b-block over. I had to dremel a bit to clear diff outdrive area. By diong this mod, I am down to 6 degrees of caster, with the 4 degree steering block. I have the zero degree steering blocks too so I will get my caster down to about 2 degrees. Had to add 6mm of spacer behind the shocks to move them out. Never done any drag racing with GT. You may want to try adding anti squat with the rear instead of pro squat with box set up.
