Old 01-10-2006, 12:48 AM   #46
ChApS's Avatar
I don't have a RR yet but ive almost got one but i do have another FW and it runs on a short tech with low to medium grip.
for grip i would go with Jaco nitro shoes 40 shore as any foam tyres around the 40's would be good. If not something softer might work.
springs i would go with a medium stiffnees in the rear and a softer spring set in the front.I also go with 40-50 shock fluid in both the front and rear.this should all make it turn in better with less understeer.
Shock location i would set the rear to the middle space as this gives me a far bit of grip and it does not understeer a whole lot.
gearing i would go with a lower tooth ring i heard the 37t is a good idea as you would make faster laps if you can master the corners at a high speed.
you will also want a bit of tow in at the rear for a bit of extra grip.
areodynamics i suppose this will affect the handling if you get the wrong body so i would go with the Mazda 6 as it handles well for cornering.
once i get my FW-05RR i will be investing in a new engine either a o.s 12 3 port TZ or a techwell as money will come a issue and i have aso swapped the Mazda 6 for the nemisis.
I hope this gives you a bit of an idea but i think ShAfTy would be the guy to ask at the momment as he already ownes the RR and he runs at the same track as me and hes a little quiker then me at the momment........
he's a bit under a second quicker.
at the momment.
Cant wait for my new kit.
ChApS is offline   Reply With Quote
Old 01-11-2006, 09:59 AM   #47
Tim Johnson's Avatar
I thought I would let everyone here know that FW-05RR's are now available in the USA. Kyosho America has just received them this morning. Contact your local Kyosho dealer to pick one up.
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 01-13-2006, 03:35 PM   #48
ChApS's Avatar
WOW you's are just recieving the RR now.
it has been available in Australia for about 8 months i think.
Old 01-13-2006, 05:02 PM   #49
Moderator
Clegg's Avatar
Honestly, I think anyone who wanted one ordered it from Japan by now.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 01-15-2006, 05:35 PM   #50
ChApS's Avatar
Got my RR kit the other day.
Old 01-15-2006, 06:23 PM   #51
Angel Santiago's Avatar
Originally Posted by Racing4Evo
I disagree. I have had both cars each for a year. First the FW-05R then the V-One RRR. I've also tried the RR conversion on the FW. To me the FW-05 is more of a parking lot car and the RR conversion was to make it better on bigger tracks where you are mostly on power. The V-One RRR works everywhere but is especially good for open tracks. The FW-05 is only REALLY GOOD when the traction is extremely high. You can run much softer tires than any belt car without a hint of traction rolling.
PARKING LOT CAR JEJEJEJE interesting........
My friend I think that you change your car so quick that you cant see all the diferent settings that the car have..
Angel Santiago is offline   Reply With Quote
Old 01-15-2006, 07:02 PM   #52
Thanks to all who have helped. With the O5RR, the kit comes with black and gold springs. What other options do I have? My manual doesn't list any. Would the springs from the RRR work? Would the springs from the Mugen MTX4? Any help would be great.
FXDAVILA is offline   Reply With Quote
Old 01-15-2006, 07:15 PM   #53
Well my friend try to use the factory settings and then in your local track try to use your best settings.I use the factory spings. the only thing is that I use golds in front and rear
If your going to use front diff use 100.000 oil in front and 30.000rear
I going to post all my setting later
Old 01-15-2006, 08:19 PM   #54
What hobby shop did you get yoru 05RR from?
Airtronics|Kyosho|
Old 01-15-2006, 09:10 PM   #55
Online from Japan. RC-Mart.
Old 01-15-2006, 11:00 PM   #56
actualy it is HK, but cool.....Thanks.
Airtronics|Kyosho|
Old 01-16-2006, 02:13 AM   #57
ChApS's Avatar
Local hobbie shop in Dubbo.
Old 01-16-2006, 09:33 AM   #58
I ordered my fw05rr about a year ago. I forget that rc-mart is from HONG KONG.
I ran my car this past weekend and I love the way the car pulls from a dead stop. The car is very good in the corners. I need to take the front oneway out and put in a diff. I need more breaking.
Later
fx
Old 01-16-2006, 04:22 PM   #59
ChApS's Avatar
What would be better for a short technical track a one way or diff.
Is there a better way to use the brake with the one way.
Old 01-16-2006, 05:06 PM   #60
front diff is the way to go The brakes with one way are limited or use antilocks if you haved in your receiver
Kyosho FW-05RR freefallmarine Nitro On-Road 13 10-12-2011 11:31 PM
WTB Kyosho FW-05RR monokenny R/C Items: Wanted to Buy 1 03-18-2006 05:51 PM
Looking for Kyosho FW-05RR Alain Patry R/C Items: Wanted to Buy 2 10-20-2005 06:15 PM
Looking for Kyosho FW-05R or FW-05RR Juan C Munoz R/C Items: Wanted to Buy 2 06-28-2005 06:23 AM
Kyosho FW-05RR Ron C. Nitro On-Road 11 04-08-2005 04:31 PM
