Old 03-17-2007, 02:42 AM   #271
I love the FW05RR... i actually love it more than my RRR EVO WCE. I think its the built and it really rolls smooth.
The only thing is, parts is really hard to get for this car.
rhys: If you cant make it to the A-Main with the 05rr... you got a buyer here.
Ecleftone is offline   Reply With Quote
Old 03-17-2007, 07:41 AM   #272
rhys's Avatar
Do any of you have any tricks that I need to know about this car. Gears, springs, diff oil, shock holes etc.... Looks like our race will be moved to another day. It snowed again. Thanks for any help.
rhys is offline   Reply With Quote
Old 03-18-2007, 03:00 AM   #273
Hoggy's Avatar
Trader Rating: 26 (100%+)
hey all
i am selling my FW-05RR It is on ebay atm, has alot of hop ups on it.
http://cgi.ebay.com.au/ws/eBayISAPI....4330&rd=1&rd=1
Hoggy is offline   Reply With Quote
Old 03-19-2007, 08:55 AM   #274
Good day of racing yesterday... just got one question...
For those of yougiving this car a serious run, has anyone had probs w/ the pins that hold the break disk sliding out? Ive tried everything, changed to the alu 3racing part but no difference, also tried to epoxy the pins in but nothing. I have destroyed several trans mount, currently running the 3 racing version that opens on the top.
It has ruined many A mains in these past 2 years w/ the car. On another note, I can say this has been the only problem I have encountered w/ the car. Last A main run w/ this car was yesterday, and again had the same problem.
So if you have any ideas on how to resolve this problem for good, please keep me in the loop.
thanks
havy
havy is offline   Reply With Quote
Old 03-19-2007, 07:09 PM   #275
moot's Avatar
does anyone know what parts are in vs035? its a clutch assembly.
moot is offline   Reply With Quote
Old 03-19-2007, 09:07 PM   #276
Ed Anderson's Avatar
137 flywheel vs029
139 collet um213
140 washer um213
141 flywheel nut vz094
143 3d clutch disc vz095
144 clutch shoe fm351
145 3d spring catch vz093
146 clutch spring fmw16
147 spring nut fm353
155 bell guide washer vz099
153 vz099 x2
154 vz099 x2
142 3d weight vz091 x3
3x12mm cap screw
3x15mm cap screw
Ed Anderson is offline   Reply With Quote
Old 03-27-2007, 06:25 AM   #277
rhys's Avatar
Never had that problem, maybe I am just not fast enough. If you find out let me know please.
thanks
havy
Old 03-27-2007, 01:46 PM   #278
Trader Rating: 52 (98%+)
Hi guys,
I have a New in box, RR for sale, pls check the link:
http://www.rctech.net/forum/showthread.php?t=152171
Lots of RC Stuff
straightaway is offline   Reply With Quote
Old 03-28-2007, 02:11 PM   #279
OK I'll let you know, for straters, let me say I run the 3 racing quick change center bulk head. The pads are the ssp ones, I have tried the 3 racing Alu break stopper and the stock plastic Kyosho one. To both I have tried to epoxy the pins in place and have left them stock but no improvement. I have put a spacer between the disk and the bearing to limit the travel. And even then I somehow loosen the pins to the point that they hit the center bulkhead and bind. I have ordered the Kfactory and the Alu Kyocho break stopper (disk break holder) and will be testing them to see if this may solve the problem. But I fear that I may only be able to resolve this by making a new part or something that may hold a different manufacturer's disk break. Maybe Ofna CD3 one or something. we'll see what happens w the other 2 when they come in from HK.
havy
Old 03-29-2007, 02:30 AM   #280
Hi, try to Locktide the pins, dont use the one for theads, but the harder one - dont remember the number, it is green and then it is not possible to remove until heating a quite lot. I use it for FSR boats.
majk is offline   Reply With Quote
Old 08-21-2007, 10:21 AM   #281
Exclamation FW-05T Offset conversion
Folks I wanted to know if it was possible to convert FW-05T 2mm offset to 0mm offset much like it can be done on the RRR ??
jelayne is offline   Reply With Quote
Old 08-21-2007, 12:18 PM   #282
snoebel's Avatar
You mean the 2mm offset on the rear joints ? Or do you still use the "old" 2mm offset wheels ?
If you use the wheels, you can purchase the joints with 2mm offset on them, this gives you the possibility to use 0mm offset wheels. You can use VSW007 or VZ081 do make this happen. Just replace the existing ones.
But if you want to get ride of the offset joints, you can use the FW-05RR rear end, it's a little more work, but if you download the exploded view from the FW-05RR you can find the parts needed. A fw-05T+ also has the same rear btw. It uses some parts of the V-One RRR !
I used both the 2mm offset joints and the FW-05RR setup, makes no difference in driving in my opinion, the front is a different story :-)
snoebel is offline   Reply With Quote
Old 08-21-2007, 02:04 PM   #283
Thanks for the information, well basically a friend of mine wanted to use 0mm offset tires because it is easier to get locally
Old 11-01-2007, 10:07 AM   #284
FW-06 announced. http://kyosho.com/eng/products/rc/de...duct_id=102655
Is that supposed to be an upgrade worth to be called 06? it looks more like a FW-05t++ . Oh well I guess no FW-06R
deceiver is offline   Reply With Quote
Old 11-01-2007, 02:48 PM   #285
Sp Racer's Avatar
LOL!!! Told ya !
Can I take you back to March last year !
Originally Posted by Sp Racer View Post
Has anybody had a good look at the roll center on the back of the FW series cars, at the lowest setting ( using the L block) it is still higher than the highest setting (A upper) on my RRR..
I got bored and did this.. seems like development on these cars stopped when the RRR came out.
The difference is amazing
Well, what do you know !
Sp Racer is offline   Reply With Quote
Kyosho FW-05RR freefallmarine Nitro On-Road 13 10-12-2011 11:31 PM
WTB Kyosho FW-05RR monokenny R/C Items: Wanted to Buy 1 03-18-2006 05:51 PM
Looking for Kyosho FW-05RR Alain Patry R/C Items: Wanted to Buy 2 10-20-2005 06:15 PM
Looking for Kyosho FW-05R or FW-05RR Juan C Munoz R/C Items: Wanted to Buy 2 06-28-2005 06:23 AM
Kyosho FW-05RR Ron C. Nitro On-Road 11 04-08-2005 04:31 PM
