Old 06-06-2006, 10:30 PM   #226
What's wierd, is I don't have that issue with my RR's - only the 5T.
I shimmed it up, and still on the same servo 10-15 tanks later.
The 5T has like 8-10 tanks, and 3 servos!!!
Old-school trader fb at http://www.rctech.net/forum/showthread.php?t=101926
sharkonwheels is offline   Reply With Quote
Old 06-06-2006, 11:15 PM   #227
Its a weird thing. I am totally puzzled. I guess I will find some nomex tape and try again.
shark on wheels, How high did you shim it up?
Thanks,
Steve
SC Racing is offline   Reply With Quote
Old 06-07-2006, 01:35 AM   #228
I just used spacers from a Nitro RS4 Racer 2 kit - mebbe 1-2mm?
Old 06-07-2006, 07:33 AM   #229
I'm about that high off the top plate. I found some nomex heat shielding from Losi on the net. I'm gonna look into it.
Steve
Old 06-12-2006, 11:15 PM   #230
nsr182's Avatar
hi guys... i have a fw-05-r.. bought about a year ago.. havent been playing rc for 6 mths.. getting back in touch...
just want to enquire.. isit worth to buy the conversion kit [fw-05-r to fw-05-rr] or just buy a whole new set??
nsr182 is offline   Reply With Quote
Old 06-13-2006, 01:45 PM   #231
snoebel's Avatar
That depends on the state of the R I guess.
Kit goes for ~100 dollar, but could be hard to get nowdays.
New car goes for ~325 dollar (HongKong).
And there are differences between the RR and the ugraded R. Like the driveshafts in the rear !
I would always go for a new one.
snoebel is offline   Reply With Quote
Old 06-13-2006, 05:17 PM   #232
Bundy_Bear's Avatar
Does the Fw05-RR still have the alloy crown gears in the diff or did they upgrade them to the Steel ones?
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 06-14-2006, 08:15 AM   #233
snoebel's Avatar
I know, that should be standard stuff... but it isn't. The RR comes with the alloy.
Old 07-09-2006, 11:43 PM   #234
I'm just getting into this 05R thing and was wondering whats the would you get out of, and the difference between the 37 and 39 ring? What's the pinion? Also what's the diff lube combination. I was started racing on an medium traction, technical track with one long straight. I was getting ready to put in 7000wt diff lube in front and back and decided to check the forums first. 8000wt seems to be the magic number.
vroomazoom is offline   Reply With Quote
Old 07-10-2006, 12:31 PM   #235
snoebel's Avatar
Pinion on all diff gears are the same, for 41,40,39,38 and 37.
You are aware that they are available in steel ?
Medium traction = don't use high numbers on diff oil, 7k or 8k sounds right.
Technical (meaning lots of corners ? ) = one way in front
Long straight = gear the car correctly for your engine, you have plenty of option with all the sizes !
ps. Never use same oil in front and rear, always use a little thicker in the front !
I drive mostly on very technical track, high grip, not a very long straight.
Use 39 diff gears, 10k oil in rear, one way front. (Have the OS TZ engine, 3 ports stock). Played a lot with setup's for diffs, but in the end I stayed with the one way, love the exit speed in the corners (because you go in faster), and the traction on the straight.
Be aware, I'm no expert, nor am I a championship driver.. Just drive (alot) for fun. And learned a lot on the track from those fast drivers Now I'm one of them !
Old 07-13-2006, 10:02 AM   #236
Thanks for the info on the diff stuff. I already rebuilt the diffs and its setup the way you explained it. I already got a one way on order, but will have to use the front diff for this weekend's race. Maybe I'll get it by Friday and I can drop them in before the race. You are right about the exit speeds on the one way, since thats where I've been losing it to the MTX-4's (which is the current dominant car on our track).
Who makes the steel gears? Does 3racing have any?
Thanks again for the info
Old 07-13-2006, 11:02 AM   #237
snoebel's Avatar
Steel gears are from Kyosho. Shame to them that they don't come standard on RR... Alu last only 5 to 6 gastanks with a decent engine.
Be aware that you need other swing shafts and joints to fit the one way !
Universals are great from Kyosho, stay away from 3racing, they used some sort of weird steel which is really crap.
MTX-4 is a good car, but I rank the RR just a little higher, but all depends on track (technical is great for RR), grip and tyres you use.
I think there are only two cars which really give a fight.. the Serpent 710/720 and the Kyosho V-one RRR.. The RR beats them on a short technical track.
Good luck next race !!!
Old 08-16-2006, 05:20 AM   #238
Bulkhead's Avatar
Default Front Overdrive
Anybody using front overdrive for this car?
Bulkhead is offline   Reply With Quote
Old 08-16-2006, 06:54 PM   #239
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default fw05 RRR
does kyosho have plans releasing an RRR version of this shaft drive kit?
bulkhead: luko
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 08-17-2006, 05:48 AM   #240
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
bulkhead: luko
i have the fw-05R then converted it into an RR but if kyosho will be coming out with a convertion kit from fw-05RR into RRR then i will convert it again just to be updated with the model
buboy28 is offline   Reply With Quote
Kyosho FW-05RR freefallmarine Nitro On-Road 13 10-12-2011 11:31 PM
WTB Kyosho FW-05RR monokenny R/C Items: Wanted to Buy 1 03-18-2006 05:51 PM
Looking for Kyosho FW-05RR Alain Patry R/C Items: Wanted to Buy 2 10-20-2005 06:15 PM
Looking for Kyosho FW-05R or FW-05RR Juan C Munoz R/C Items: Wanted to Buy 2 06-28-2005 06:23 AM
Kyosho FW-05RR Ron C. Nitro On-Road 11 04-08-2005 04:31 PM
