Old 04-17-2006, 04:16 AM   #196
esham's Avatar
Most of the time i run my V1RRR in bigger event. But i still keep this beast. Blashing with friends on the weekend with it on Parking lot track
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 04-29-2006, 09:19 AM   #197
snoebel's Avatar
Thumbs up New steel ! pinion gears !
After years of alu pinion gears, Kyosho decided it's time for better ones...
Maybe I'm wrong, but I only find the first gear pinion ? Ok, that is the one which wears the fastest.
VZW-66-20 Ritzel#20Z, Stahl
VZW-66-21 Ritzel#21Z, Stahl
VZW-66-22 Ritzel#22Z, Stahl
VZW-66-23 Ritzel#23Z, Stahl
Took them a long time to realize that this was needed
snoebel is offline   Reply With Quote
Old 05-01-2006, 08:40 AM   #198
How many teeth are on the pinion gear in the diffs?
And are the 05R and 05RR the same?
Old-school trader fb at http://www.rctech.net/forum/showthread.php?t=101926
sharkonwheels is offline   Reply With Quote
Old 05-01-2006, 10:46 AM   #199
snoebel's Avatar
Hi,
No, those diff steel gears were already long time available.
These are pinion gears for on the clutch !!
And yes, they are the same for R and RR.
Old 05-02-2006, 05:50 AM   #200
Anyone know how many teeth are on the pionion gear in the diffs?
If there is a difference, the optional steel 37T setup?
Old 05-02-2006, 05:57 AM   #201
snoebel's Avatar
Diffs gears come in 41, 40, 39 and 37T setup.
Old 05-02-2006, 10:00 AM   #202
I'm interested in the number of teeth on the pinion gear that
comes with the 37T steel diff gear setup. Trying to calculate the
gear ratio of the gearboxes.
Old 05-06-2006, 09:27 PM   #203
Loving the RR....thanks kidDynomite.
But.... setup-wise, my car runs fine, but when I hit the brakes, it spins.
The tail flips around to the left. What can I do to curb this tendancy?
Old 05-06-2006, 10:10 PM   #204
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
All the Kyosho ring gears come with 13t bevel gears.
The Internal Drive ratio for the Rings gears are:
37T- 2.84 : 1
38T- 2.92 : 1
39T- 3.00 : 1
40T- 3.07 : 1
Racing4Evo is offline   Reply With Quote
Old 05-06-2006, 10:15 PM   #205
Racing4Evo's Avatar
You can reduce the EPA on the brake till it barely starts to rotate. The car has a one way I take it. With a one way the car doesn't stop nearly as good as 4 wheel braking so it's more like slowing the car than stopping it.
Old 05-06-2006, 10:16 PM   #206
Racing4Evo's Avatar
Actually there is no 41 tooth, I think. Just 40, 39, 37, and 38 with the 38T being the most recent introduction.
Old 05-06-2006, 11:50 PM   #207
im curious how come kyoho team drviers and most unsponsored drivers dont drive the fw-05rr?
its seems to be a great car but know one runs em is there a reason?
in my local area its all mugen and fw-05 so im trying to figure out why pro's dont like the fw??
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 05-07-2006, 12:17 AM   #208
Except for the end-around it's trying to do (I'll try the EPA adjustment tomorrow, but you BARELY touch the brakes, and it's switching ends!) I like the car. Yep, got a one-way on the front. Prob going to do away with that.
Braking is too twitchy with the one-way.
Old 05-07-2006, 12:32 AM   #209
Racing4Evo's Avatar
Belt drive cars are just easier to drive. You can spend a week trying to tune the FW-05RR to be as good as a V-One RRR you only spent one day tuning. Plus the suspension on the V-One RRR is a lot better than the FW-05 RR.
Old 05-07-2006, 03:28 AM   #210
ChApS's Avatar
Today i noticed what the RR drives like on loose surface.
It was cold and dusty so off went the jaco 40's and the sorex 36's were put on and it was still incredibaly slippery.
It was sooo hard to drive well the most difficult race conditions i have raced in but at the end of the day with the sorex 36's and the RR combination worked well.
Ill be hopeing for more grip in the future
ChApS is offline   Reply With Quote
Kyosho FW-05RR freefallmarine Nitro On-Road 13 10-12-2011 11:31 PM
WTB Kyosho FW-05RR monokenny R/C Items: Wanted to Buy 1 03-18-2006 05:51 PM
Looking for Kyosho FW-05RR Alain Patry R/C Items: Wanted to Buy 2 10-20-2005 06:15 PM
Looking for Kyosho FW-05R or FW-05RR Juan C Munoz R/C Items: Wanted to Buy 2 06-28-2005 06:23 AM
Kyosho FW-05RR Ron C. Nitro On-Road 11 04-08-2005 04:31 PM
