Old 03-22-2006, 02:10 AM   #181
ChApS's Avatar
Anyone know the main diffrence with performance with the protoform Nemisis and Mazda 6?
ChApS is offline   Reply With Quote
Old 03-22-2006, 04:49 AM   #182
Sp Racer's Avatar
and SPRacer, sweet mod dude, something to definitely look into... again, a bit rusty but I think lowering the rear roll-center should give the rear end more predictable traction by allowing the car roll a bit more in the corners and rid the car of a washy rear end... great to correct the mid-corner and on-power capabilities of the car. Or so I imagine, but dreaming ain't nothing compared to reality. Need to try it on some of my many extra H blocks I got in my spares collection.
I'll pull the blocks off and show you how I've modified them, you have to use the "L" block upside down, and machine down a 2.5 mm cap head screw to fit in the chassis hole.
getting the sway bar to work with the RRR rear arms was tricky...
Main difference, with this set up you can run the shocks layed right down, the car is better on the bumps, puts the power down .
I used to always run almost fully vertical rear shocks, whenever I layed them down the car felt weird - not any more!
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 03-24-2006, 12:02 AM   #183
Im2lazy's Avatar
sweet dude, just what my car needs. But RRR arms? Didn't notice that one... where are my eyes?
With foams, my car is just fine, but with rubber tires (sometimes I run both on the same car in the same day to race another class) the low blocks are a must... with this mod it should make the car have a bigger sweet spot as far handling goes. And I'm with ya SP about having to stand up the rear shocks... when I lay 'em down, I never know what the heck to think but change it back.
The nemesis is a bit more stable than the Mazda, but the Mazda is stable enough as is. I prefer how the Mazda feels in the middle of the corner. A little more balanced front to rear. Rotates nicely. All this is my opinion, of course; but for 40 bucks you can try them both back to back on the track.
Im2lazy is offline   Reply With Quote
Old 03-24-2006, 12:06 AM   #184
ChApS's Avatar
Thanks for that.
I am currently using the nemisis.
Old 03-24-2006, 07:55 PM   #185
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
aside from Kyosho is there any other company that makes a thicker rear shock tower for the 05RR, thanks
buboy28 is offline   Reply With Quote
Old 03-24-2006, 08:07 PM   #186
3 racing might.
ShAfTy is offline   Reply With Quote
Old 03-25-2006, 05:12 PM   #187
ChApS's Avatar
Dont think that they make thicker rear shock towers but they do make them out of diffrent materials.
Old 03-25-2006, 06:24 PM   #188
prg
Default spracer mod
looks good.. did you machine down the back of the L block where it has the locating strip thats sits under the rear diff housing too ??
prg is offline   Reply With Quote
Old 03-26-2006, 12:24 AM   #189
Sp Racer's Avatar
Yeah, just cut it off with a sharp knife.
I'll pull it apart and take some pics in the next day or so...
Ran it again today - it's awesome
Front shocks 1 hole out from the inside - 70 wt oil 2 hole piston
Front springs - kyosho silver (soft)
Rear shocks - as per the pic, 50 wt oil , Kyosho long black springs ( medium)
spool in the front, 10000 wt oil in the rear..
I also removed the blue spacer from the outer link on the rear hub ( raise rear roll center slightly - more forward bite)
great turn in, stable on power, excellent on the bumps
Old 03-27-2006, 02:13 AM   #190
ChApS's Avatar
Sounds like a good setup.
Old 04-12-2006, 04:08 AM   #191
ChApS's Avatar
Ive got something slipping in my gearbox but its not the oneway bearing.
But when it gets heated it stops slipping.
Anyone know what this could be.
Old 04-12-2006, 04:31 AM   #192
esham's Avatar
Carefull on the ring gear inside the gearbox. The original iron cast is easy to wornout.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 04-12-2006, 04:33 AM   #193
ChApS's Avatar
Thanks ill give it a go soon.
Ill update what happens
Old 04-12-2006, 06:25 AM   #194
Tim Johnson's Avatar
Check to make sure your flywheel is tight, as well.
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 04-16-2006, 03:11 AM   #195
ChApS's Avatar
I replaced the front end of the gearbox.
ITS ALL GOOD
thanks for the replys
Kyosho FW-05RR freefallmarine Nitro On-Road 13 10-12-2011 11:31 PM
WTB Kyosho FW-05RR monokenny R/C Items: Wanted to Buy 1 03-18-2006 05:51 PM
Looking for Kyosho FW-05RR Alain Patry R/C Items: Wanted to Buy 2 10-20-2005 06:15 PM
Looking for Kyosho FW-05R or FW-05RR Juan C Munoz R/C Items: Wanted to Buy 2 06-28-2005 06:23 AM
Kyosho FW-05RR Ron C. Nitro On-Road 11 04-08-2005 04:31 PM
