Old 02-20-2006, 04:04 AM   #151
NARNYRX3's Avatar
i work in a hobby shop & have to deal with them also. they haven't changed from when you were dealing with them. slow, rude, keep stuff all parts, over priced, no help & did i say slow. sad when they are the aust. distributor
NARNYRX3 is offline   Reply With Quote
Old 02-20-2006, 11:03 PM   #152
ChApS's Avatar
no airleaks so im hoping it's the fuel.
ChApS is offline   Reply With Quote
Old 02-21-2006, 06:06 AM   #153
Tim Johnson's Avatar
keep us posted.....their are other things as well.
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 02-21-2006, 06:36 AM   #154
macnkitty2002's Avatar
darn trading are slow as. I used to work for my local Hobby shop and we have always said they were slow. because they are one of the slowest distributer weve eva delt with.
so im goin to the HK shops
aren't all private hobby shops like that?!?!?! no help unless you are going to buy a new car or something. luckily, there are chain stores like HobbyTown USA, where you're guranteed to get good service.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 02-21-2006, 10:19 AM   #155
Secret_weapon's Avatar
Would any one tell me where can i find FW-05R-FW05RR conversion kit.
I searched all websites i know but still couldn't find.
OR
Please tell me the parts that i will need to convert, because my fw-05r is fully hopped up. And where can i find the 37/38 ring gears ?
Secret_weapon is offline   Reply With Quote
Old 02-21-2006, 08:51 PM   #156
If i remember correctly kyosho america may still have some. What part of the world are you in? If you are in the states, i can find a shop near you, so that you may order it IF kyosho america has them. I will check stock in the morning.
Airtronics|Kyosho|
Old 02-21-2006, 10:10 PM   #157
I live in the middle east, United Arab Emirates, Dubai.
But I can order online if available.
Old 02-22-2006, 12:01 AM   #158
ChApS's Avatar
I tried some diffrent fuel which isn't as old as mine but still a little old and i was reving in the air and i seemed to not be getting hot as quickly but after a little while about 1/4 tank done it again went very hot and stalled from heat and unable to start again from the heat.
Im going to get fresh fuel tomorrow but now im not sure that it is the problem.
These engine are ment to be reliable but there is obvously something over heating it.
Not last 5 minute qualifings are enoying but unable to finish the 20 minute final realy makes me think diffrently about this engine.
Any ideas.
Old 02-22-2006, 01:00 AM   #159
hey guys i have my gs-15r apart do you think it would be a good idea to remove the inner facing shield of the front bearing?? as it has dual shields and as far as i can tell it is unn needed or is it? is there enough crank case preasure to warrant the second shield?? just getting some opinions
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 02-22-2006, 06:38 AM   #160
leave it be.
Losi Rock Rey
Old 02-23-2006, 06:07 AM   #161
Has anyone tried the TCD diff in a FW-05 ? Will it fit? Kyosho TCD Gear Set V-One vzw009
zulu is offline   Reply With Quote
Old 02-24-2006, 12:42 AM   #162
hi
Can anyone tell me where can i find these parts for FW-05RR :
-Front upper suspension shafts (VS038)
-Front upper bracket (VS037)
Old 02-24-2006, 12:46 AM   #163
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
It fits, but it's no good if you run on foam. I don't know about rubber. The car is inconsistent as the grease heats up and making it consistent with thicker grease totally negates the supposed benefit of the diff.
Racing4Evo is offline   Reply With Quote
Old 02-24-2006, 01:08 AM   #164
esham's Avatar
Yes it fits but i use diff oil instead of TCD oil. Not so sure if this make the diff function differ but so far the car with it running well. And yes i run form tires.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 02-24-2006, 07:54 AM   #165
Send a message via AIM to jeff whiting
I have used the TCD Diff gears in the past and what I found was that, it did exacly what Kyosho says it will do and that is, lock up under high load and spin free when not under load. The problem I had with it is when you were powering through a corner and then let off a bit to correct or avoid another car it would unload and then when you hit it again you could tell that there was a small delay in getting that power on steady feel of a locked diff back again. I just found that regular gear diff with the right fluid for the track is better.
JEFF
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Kyosho FW-05RR freefallmarine Nitro On-Road 13 10-12-2011 11:31 PM
WTB Kyosho FW-05RR monokenny R/C Items: Wanted to Buy 1 03-18-2006 05:51 PM
Looking for Kyosho FW-05RR Alain Patry R/C Items: Wanted to Buy 2 10-20-2005 06:15 PM
Looking for Kyosho FW-05R or FW-05RR Juan C Munoz R/C Items: Wanted to Buy 2 06-28-2005 06:23 AM
Kyosho FW-05RR Ron C. Nitro On-Road 11 04-08-2005 04:31 PM
