MRX-4X
MRX-4X
I figured since we have a new car/upgrade kit I thought I would start a new thread so we don't have the MRX5 thread continuing.
Here are some links to the upgrade kit manual, setup sheet, and parts list.
Manual:http://www.mugenseiki.co.jp/mugen/do...nual_h0080.pdf
Setup Sheet:
http://www.mugenseiki.co.jp/mugen/mr...0701kitstd.pdf
Blank Setup Sheet:
http://www.mugenseiki.co.jp/mugen/mr...e0701blank.pdf
Parts List:
http://www.mugenseiki.co.jp/mugen/mr...artslist-e.pdf
Setup Sheet:
Blank Setup Sheet:
Parts List:
What's good Chicky? The parts really seem 2 b good. I didn't drive mines yet but I feel that it gonna b off da hook!!!!! U should try and make it 2 the I-95 shootout.
Yea just got mine all done. I get to try it this weekend. Can't wait.
I already commited to a carpet race at Fastcats that weekend or I would be there fo sho.
Paul
Paul
Me too
I can't wait for the weekend. Hopfully its a good result for the debut in the MWS!
I have a ? about the MSR spring. Do you use the same distance from the end of the nut as the super hard silver spring? Or more or less?
I plan on starting with the base setup this weekend for a Midwest Series race in Chicago. If I change things, then I will post my setup after the weekend.
Got my MRX4X battery tray today!! Thanks Brad looks sweet and was 55 grams on the nose
Check it out at http://www.ybslowinc.com
Paul
Paul
Some Q's....
Sneaking on the parts list, found this....
Just curious... somewhat similar to gray springs... and doesn't come marked as an optional part (so should be a standard kit part), but... anyone found new springs on their conversion box?
Code:
H0515 FRONT DAMPER SPRING YELLOW φ1.8mm
