Old 01-02-2006, 06:57 PM   #1
Quietroit's Avatar
Default 40% nitro fuel
When using 40% nitro fuel do you have to change head clearance. If you do, what mm do you change to.
Thank you,
G4rs 09|3pk| KO KO PROPO
Quietroit is offline   Reply With Quote
Old 01-02-2006, 06:58 PM   #2
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
There is no set amount you change. Especially when we dont know what engine its for....but there is a guide to the amount you might want to change.
But 40% , wow , thats some potent stuff. Most people around here run 30% if not less.
Artificial-I is offline   Reply With Quote
Old 01-02-2006, 07:07 PM   #3
ogreasurada's Avatar
All I know is that you need to run cooler glow plug for higher nitro fuel.
ogreasurada is offline   Reply With Quote
Old 01-02-2006, 07:59 PM   #4
Vince's Avatar
try this http://cefx.net/tips/nitro/nitro/index.php
Wallace Motorsports
WRC
Murnan Modified Motors
VP Fuel
Hot Race Tires
Vince is offline   Reply With Quote
Old 01-02-2006, 08:59 PM   #5
Moderator
I meant to edit my post.
Going higher nitro % , you will want to add more shims. Just for reference.
Lets say you have .3 shims for stock setting and reccomended %20 from your manual.
Youll want to add at least .1 shims for every 10% nitro.
If it was .3 , I would now go at least .6 and see how it tunes out.
Old 01-03-2006, 10:31 AM   #6
Usually adding .003 to .005 in shims will work, however watch your plugs, If you start hurting them, then add a little more shim.
40% tends to cause you to change rods more often and you'll need to weigh the minimal advantage to using 40% against higher maintenance costs.
quickie is offline   Reply With Quote
Old 01-03-2006, 03:27 PM   #7
nitro must be cheap over there
if you can't get power out of 20 to 30%nitro then your tune/clutch/pipe must be wrong!
qwerty is offline   Reply With Quote
Old 01-03-2006, 05:59 PM   #8
You're partially correct, everything else needs to be right, but we were only talking about nitro percentage vs. deck height.
Frankly, 40% adds a little speed at the end of the straight and a little snap off the corners and I will only use at at a major race and then most of the advantage is physcological.
Nitro fuel prices went up, converting nitro buggy to lipo,brushless its a good idea rc4fun Nitro Off-Road 74 12-29-2008 09:08 PM
NITRO FUEL tsanc10 Nitro Off-Road 5 07-26-2007 10:42 AM
Tower Hobbies Power 20% nitro fuel VS Trinity Monster Brew 20% nitro fuel? needhelpPLZ? Nitro Off-Road 1 07-23-2007 06:01 AM
MuchMore goes to Nitro - Nitro Power Fuel rcforum Nitro On-Road 0 05-02-2007 09:40 PM
MuchMore goes to Nitro - Nitro Power Fuel rcforum Electric Off-Road 0 05-02-2007 03:29 PM
