Old 11-13-2002, 11:03 PM   #1
Need advice - Kyosho
Got a Kyosho nitro car about 5 years ago,
put it together, into the cupboard and just found again last week. Lost the manual. What needs to be done to get it in working order? Air filter is melted and the remaining fuel in the tank has turned into orange jelly. Some hints or links in the right direction would be greatly appreciated. Thanks.
omnivaal is offline   Reply With Quote
Old 11-13-2002, 11:19 PM   #2
Well it would help if you knew what model of Kyosho car it was. Kyosho makes like a dozen cars if not more.
calimassive is offline   Reply With Quote
Old 11-13-2002, 11:53 PM   #3
That's the problem, I don't know. I've got no documentation, just the car. The body was a Mercedes but that's probably no help at all.
Old 11-14-2002, 12:03 AM   #4
oh ok,
hmmm, you could try going to www.kyosho.com
see if the car you have looks like anything you see on the site.
Old 11-14-2002, 01:05 AM   #5
Send a message via ICQ to V-One S
His car is probably discontinued.
V-One S is offline   Reply With Quote
Old 11-14-2002, 02:32 AM   #6
I'm not really looking for model specific stuff, more like what things should I do to a negelected engine. The rest of the car is pretty much mint cond.
Old 11-14-2002, 02:40 AM   #7
I'd start with:
Replace the fuel line abd pressure line
Fill and rinse the tank completely a couple oftimes using oil, cheaper then using the nitro methanol fuel.
Clean the exhaust pipe out,
Replace the Glow plug.
With glow plug off tip a bit of oil through and slowly wind the engine over a little bit.
Replace the air filter.
Check that no dust is in the carbie, it so remove the carbie and clean it out.
Take it out side and see if it will start
Old 11-14-2002, 10:29 AM   #8
Trader Rating: 21 (96%+)
Send a message via AIM to RCNUT
Default pciture
If you can post a picture of it, someone might be able to identify it. I have done that a couple of times and I even got a manual out of doing it.
RCNUT is offline   Reply With Quote
Going to buy a PS3, need some advice RoosterXp Chat Lounge 68 11-15-2010 03:10 PM
RB C5 advice. REVOS5 Nitro Off-Road 1 02-13-2008 03:56 PM
Need advice for Kyosho MAD FORCE ~~ (^_^) vios8820 Malaysian R/C Racers 4 11-29-2007 06:43 PM
any advice about buying kyosho stuff online sambonee Electric Off-Road 6 08-07-2007 01:47 PM
XRAY T1 Evo 2: Building Advice, or setup advice Carbon_Fibre3 Electric On-Road 9 01-03-2003 02:44 AM
