Servo over heating
#16
Learned something I think
I think I got it figured out.
I either needed a voltage regulator to use the LIpo batteries, a receiver capable of handling it, use a LiFe battery (lower voltage) or an electronic switch that would control the voltage.
I had none of those.
Oops. Lesson learned I guess.
#18
I think newer systems you can run analog or Digital servos. Ck type of servo on your PX pg39 in manual. make sure it set on Digital servo, run 7.4-4.5v, compared to 6-4v analog. Ck your RX, maybe it cant handle the servo. RX does 2 things signal to channels, and act as a voltage regulator to servos. RX may either wrong or defected. I'm just guessing!!
#19
Only Sanwa has something high speed that only works with certain Sanwa servo's. I do not know what effect that has on other servo's.
Also the receiver does not act as a voltage regulator to the servo. There are a few which do but these are not the receivers/brands we normally use. Such receivers are marked with "BEC".
#20
#21
Excellent reply I will check that. Now that u mention it I copied settings for a 2w electric car and then made the changes to those settings for the nitro which has 2 servos. I have no idea what setting the throttle servo is in. I will check after work. Receiver was also in the other 2w electric car. So I may have really screwed up.
#22
There is no setting of "analog" or "digital" servo's. Only analog servo's have problems with a higer framerate, they need to get a normal signal which is arround 20msec.
Crap.
A disagreement. Now how do I know who is right? Hmm??? Guess I gotta figure it out.
#24
With Futaba and digital servo's nothing can go wrong. Digital servo's work normally on all modes and the Futaba does not have a special high speed modus for only special futaba servo's.
#25
I don't know Futaba servos, but for a throttle servo I have always used the highest torque I could find/afford. You don't need anything high speed, the engine can't respond as fast as the high speed servos can move and you need torque for the brakes. Just my $.02
#26
It is not about a fast throttle, it is about a fast brake, you will notice the difference between a crash with broken parts or a soft touch with only a bend body.
#28
Check the travel of the servo. I'll bet the horn is hitting on something. Either that or something is really binding in the linkage. You didn't say which car. If it's 1/8 you need atleast 200 oz of torque. I'm actually trying to hunt down some gears for my servo sometime today.
#29
