Build Complete: HPI RS4 3 SS
#31
Congrats for this project! Question, the diffs, do you use silicone oil or grease as it was original intended ?
#32
Nitro RS4 diffs don't have the necessary seals to hold silicone oil, so I use silicone grease instead. In the rear diff I use plain white silicone grease, and in the front diff I use Tamiya Anti-Wear Grease (which is extremely thick silicone grease with some sparkly silver crap added to it) along with a preload spring between the spider gears.
#33
do you still happen to have this car? I just recently installed the one piece hot bodies graphite deck into mine and I cannot fit my os 18cvrx motor into it. I'm about to swap to the stock deck to compare but the chassis engine mounts won't line up since the pull-start housing pushes against the deck where it mounts to the read diff housing.
#34
