Front hopping on turns?
Hey guys, I have an Xray NT1 2013 that has recently began to hop in the front of the car when I make turns. This happens both left and right turn. The track just received a new surface for this season so traction is way up from last season. What adjustment can I make to keep the front of my car from hopping? It's like the front wants to traction roll but the rear isn't letting it.
Ride height = Front - 5 / Rear - 5.6
Downstop = Front - 0.5 / Rear - 5.4
Camber = Front - 2 / Rear - 2.5
No added weight.
Thank you,
Kyle
No added weight.
Thank you,
Kyle
Worn driveshafts and drive cups will do that.
DCJ drives that fit will work way better than CVD's..... I got them in my Ntc3, and they make a big difference....
Glad you found the issue. The symptoms you described were classic worn shafts.
I check my shafts after each day running on the car. When the pin gets to 2.5mm at the smallest point it's scrap. I always replace shafts and cups at the same time.
