Old 11-10-2002, 05:49 PM   #1
Default Have some rookie questions?
I have a RSR4 RTR3 nitro car. I am new to the sport. and have a couple of questions if anyone can answer them i would be grateful. The first one is there some kind of warm up period that i need to do before running my car. it seems to run real sluggish if i do not let it run for a minute. before running it. and second what kind of bottom end should this thing have. it was not really what i expected on the bottom end. what kind of tune has anyone run with one of these kind of cars that has good luck with. thank you
NOS331GT is offline   Reply With Quote
Old 11-10-2002, 07:40 PM   #2
Too detailed to give here. Buy a tuning guide at your local hobby shop. good luck
Dbackmasta is offline   Reply With Quote
Old 11-10-2002, 08:49 PM   #3
popsracer's Avatar
Default RS4 RTR3
I don't believe HPI has ever produced any kind of "tuning guide" for their cars, except the instructions that come with the kits.
The 15FE as it comes stock, is a pig. The single needle carb really holds it back. You can buy one of the HPI hop-up kits for the motor (on their website) or just live with it until it's time to buy another motor.
It takes a minute or so to warm up from stone cold.
popsracer is offline   Reply With Quote
Old 11-11-2002, 01:05 AM   #4
Im2lazy's Avatar
i haven't met an engine that didn't run better 1 minute after starting up then at 45 seconds after starting up. All engines work best (when tuned close or at optimum) about 2-3 minutes after starting. That is why we take warm up laps b4 our race; let everyone settle down, and let the engines warm up. True some engines seem to run quite well just when starting up, but not all the assorted metal parts of an engine heat to normal operating temperatures at the same times let alone in less then a minute.
But I do agree that rather than trying to make it better, just run it into the ground as is. And its bottom end is very...bad.
Im2lazy is offline   Reply With Quote
Old 11-12-2002, 01:50 AM   #5
Send a message via Yahoo to TambokGT
Default Re: Have some rookie questions?
Since you are using the stock 15FE engine, try gearing down if you need more acceleration.
TambokGT is offline   Reply With Quote
Rookie to electric and have some questions. bassmaster345 Rookie Zone 1 10-18-2007 04:58 PM
Rookie ISBB Rookie Zone 2 05-17-2007 03:19 PM
Rookie Black_Widow Singapore R/C Racers 0 07-18-2006 07:04 AM
Not Quite a Rookie, What's Next? Hawk6 Rookie Zone 45 02-10-2006 02:25 PM
Some real rookie questions on Nitro equipment. markp27 Rookie Zone 3 01-23-2003 06:25 PM
