New "ball type" clutch >
Old 04-28-2016, 04:35 AM
Frank Clementz's Avatar
Default New "ball type" clutch
I see there is an new type flywheel with balls instead of sentrifugal shoes on the marked. Someone here tested it?
Attached Thumbnails New "ball type" clutch-12985359_1124398400925416_4061367586622035082_n.jpg
Frank Clementz is offline
Old 04-28-2016, 05:59 AM
Who make it?
beebone is offline
Old 04-28-2016, 06:23 AM
Originally Posted by beebone View Post
Who make it?
10 years back when I use CEN kit, the centex was bearing type
kyosho malaysia is offline
Old 04-28-2016, 07:08 AM
Roelof's Avatar
Mugen Sting and the BMT Pantera were also using balls. Pretty safe when on full throttle the clutch comes loose.....
Roelof is offline
Old 04-28-2016, 07:11 AM
Oh, old skool
beebone is offline
Old 04-29-2016, 04:49 AM
foampervert's Avatar
Default ball weighted clutches
These ball weighted clutches were quite common in the past.
Picco and Kyosho had Cone weighted clutches.
Everyone else used balls (If i remember right)
Problem with them was, the balls will eject catastrophically (think 40,000 rpm + centrifugal force) if the clutches were not set exactly right, or if the bearings seize or wear out or play develops for whatever reason...
Lots of clutch fiddling required.
The current systems using angled resin weights or flat resin weights (more recent), make for a lot less fiddling...
foampervert is offline
