Team Magic G4 Family--The Joy of Driving
You may know that Team Magic is going to release two new G4. One is Le Mans G4 & the other is G4 S. I believe there will be more drivers enjoy driving the G4.
Very true.. Nickko, long time no hear from... I have a few questions... The current G4/Mongoose uses S-Class gears and the material of the spur gears were prone to stripping when using the 25 tooth clutch gear... Has this problem been addressed with the up coming car??? The material used in the S-Class spur gears needs to be alot more duriable... Two... Will the new car have a bell crank steering system??? Some are posting that it will.... One last thing, will we be able to adjust the front roll-center in the new G4S??? Nice to see you posting here Nickko and keeping us informed...
RC_Alan
RC_Alan
Is the new G4 S an evolution of the current G4 EVO or a completly new car?
Will there be any parts interchangable with the TM G4 EVO?
Good to see you here, so we have inside information.
More Information about Le Mans G4, please check the link.
http://www.teammagic.com.tw/en/profr...2073&pageNum=1
RC_Alan
RC_Alan
Ooooops my mistake !!
cya !
Originally Posted by Tabushi
RC_Alan, can you explain more about that S-Class gear problems ? ... i do use that gears and just had a problem one time and after that no more problems ... i used to use the paper-estrategy to mesh the gears but i found that didnt work goo, i had to push a little more and end with a little-tight gears that after a minute or two of running the engine they will end molding them selves (a little more initial wear on the pinnion but nothing else) ... and no more problems anymore !
hope this help ...
cya !
hope this help ...
cya !
Your car doesn't have the "S" class transmission system, yours has the previous standard system. Will mail you about it.
AFM
Radio Plate
Nick Ko,
Looks like the upcoming S version will share most of the Evo model, will we expect an upgrade for radio plate only? like we want the battery on the side and the receiver underneath, as of now im looking at the prototype the side plates are shorter to accomodate the battery and the throttle servo to move few millimeters backwards to gain room so i was i thinkin if we want to change the radio plate we will replace the side brace or possibly the chassy as well due to placement of mounting screws.I hope there will be a special radio plate for evo versions that dont require multiple parts to purchase
Originally Posted by afm
Pato
AFM
AFM
I race a G4 and i can tell you it makes me happy so see that Team Magic have upgraded it theres nothing like knowing theres more go fast bits to get but my wallet is going to become heaps thinner after a trip to the shop.
Thanks heaps Team Magic
Reg.
Chris
Reg.
Chris
We will have upgrade kit for the current G4 racers. We think it's good to drive a car for a longer time & you can still make the car very competitive. That's why the G4 has the most items available for you to tune the car.
Anytime is a good time to buy a G4.
This car look like .
As long as it's belt drive.
Thanks Nickko,
I look forward building the car and racing it. Racing will have to wait a bit because the season just ended and the wetter in The Netherlands isn't to good from November till March.
