Old 06-15-2006, 03:48 AM   #1396
Car Breaker's Avatar
Originally Posted by indypwr
hey buddy, i was wondering if you can help me. i can't seem to move the spur gears backwards like other cars out there. it seems like it's locked on something. i changed my one-way up front into this blue anodized solid front. my car is the rd logics mongoose by the way. the car drives fine at all. it's just weird how i can't move the car back with my hand. the gears tend to lock up and wheels wont turn either. but pushing the car forward is fine.
can you help me out?
tks
I may not be right, but you can try take off the brake disk and see if the issue gone. If so, you might may a defacted Alu. break pulley parts as I did. I used to have drag when I push my old Mongoose backward. but it was gone when I use the full Alu. 18t break pulley.
there was a updated alu. part of break pulley come with G4S I did try it before I switch to the option pulley.
look at the picture below, which one look like yours? the one on the left is the old version.
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 06-15-2006, 03:41 PM   #1397
rcrevolution's Avatar
Send a message via AIM to rcrevolution
Originally Posted by BimmerDriver
I remember measuring mine at almost 2 inches
I was going to get Lunsford 1 7/8" and use RPM ball cups. Maybe I need to re-measure
its deff 35mm or 1 3/8inches
rcrevolution is offline   Reply With Quote
Old 06-15-2006, 07:15 PM   #1398
Default Team Magic G4-S
Brian Berry
This is Gary McDow from Toledo track.
What brand pulleys are you using on your car?
and is that what you used at MWS @ Toledo?
I was not able to get my car together for race and then went to Virgina.
Want to be ready for next club race and GLC race.
I also had a problem with my clutch when installed as manual stated without any shimms and tighten screw for thrust bearing the clutch is tight against shoe I had to use Elec. motor shimms between SG shaft and thrust bearing sleeve to get clearance to spin clutch bell.
I have the Nova made Mugen X12 JP mod. motor.
Today I found the UFO clutch doc. That Dennis put on Kfactory site and will try that.
I bought my kit at Larry's and a few spares please let me know where I can get parts as He does not have much.
Thanks Gary McDow
macthehack is offline   Reply With Quote
Old 06-15-2006, 08:29 PM   #1399
Send a message via AIM to munrath
Gary you have PM
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 06-16-2006, 12:21 AM   #1400
razzor's Avatar
tks
From your explanation ,that is normal with a oneway.
My TRF415 ,Serpent and my G4S all do same .
can roll forward with no binding but lock up when rolling backwards.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-16-2006, 01:06 PM   #1401
munrath what do you mean
( Gary you have PM )
Thanks Mac
Old 06-16-2006, 02:48 PM   #1402
Meaning you have a Private Message.
Races for 2015:
Old 06-16-2006, 02:49 PM   #1403
Brian Berry just stepped it up in round 2. 19/5:11
Go G4S
Races for 2015:
Old 06-16-2006, 10:00 PM   #1404
Regional Moderator
Darkseid's Avatar
Originally Posted by rcrevolution
Darkseid what screws are those? are they the ones that come with the conversion kit or the ones for rcscrewz?
i want to but the kit from rcscrewz but I dont know if I should get the g4s kit for the mongoose or the g4(original) kit for the mongoose.
also do their screws still grip well? cause i notice they have different threads.
Sorry for the delayed reply, I had a major computer crash and was off-line for a few days...
If your refering to those silver screws, they're neither the G4s conversion or Rcscrewz. They are from a website call fastener-express. I had some leftovers from when I added some blue and silver screws to my TA05, so I threw them on this car to replace the Mongoose's leftover phillips head screws.
And the screws are VERY good. Both the stainless steel and the alum. screws have very precise heads and I have yet to strip either material.
TLR 22...Tamiya F104...
Old 06-16-2006, 10:01 PM   #1405
Regional Moderator
Darkseid's Avatar
Originally Posted by sfelish
Darkseid,
You now have a G4s with a completely different weight distributiion and steering system. Use the base set up in the manual or the last one reported here on this thread whicj was froma cincinati race. Real good base setups to start.
The car looks great! Good Luck and Good Racing!
Sam
Thanks...I'll start with the base setup and work from there then.
Old 06-16-2006, 10:02 PM   #1406
Regional Moderator
Darkseid's Avatar
Flying the Team Magic colors...
Old 06-17-2006, 08:22 AM   #1407
Holeshot's Avatar
tks
I think you might want to check your 2 speed for problems. That happend to me and the 2 speed wasnt disengaging. Re-ajusted 2 speed spring adjustment and the problem went away. The adjustment screws were hitting the outer housing.
Holeshot is offline   Reply With Quote
Old 06-17-2006, 12:46 PM   #1408
We are taking about 3 threads off the 2 speed screws, to prevent this from happening.
Mark
Races for 2015:
Old 06-17-2006, 07:56 PM   #1409
Congrats to Dennis for bumping into the A-main for the Open class!!
Congrats to Ray and Brian for putting the G4S in the A-main for the Open class!!! Awesome job guys
Mark
Races for 2015:
Old 06-18-2006, 02:52 AM   #1410
Holeshot's Avatar
Mark
Ahh good idea. I didn't think of that. Luckily my car shifts at the right point when I backed off the screws.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
