Old 06-12-2006, 02:33 PM   #1366
D-man's Avatar
Brian Berry, you have a PM
D-man is offline   Reply With Quote
Old 06-12-2006, 03:18 PM   #1367
rcrevolution's Avatar
Send a message via AIM to rcrevolution
Darkseid what screws are those? are they the ones that come with the conversion kit or the ones for rcscrewz?
i want to but the kit from rcscrewz but I dont know if I should get the g4s kit for the mongoose or the g4(original) kit for the mongoose.
also do their screws still grip well? cause i notice they have different threads.
rcrevolution is offline   Reply With Quote
Old 06-12-2006, 05:22 PM   #1368
Car Breaker's Avatar
I don't think the Mongoose screw kit will have all the screw that G4S need, I might be wrong since I bought mine 3 years ago.
I will suggest to count and measure the screws on G4S and buy them seperately.
From my experience, screw from RC screw are not consistant.
these day I prefer to get flat head and socket head from Hex Screw (I destroy the front of my Mongoose before I can put a scratch on those screws in teh front) and get some Ti screw for buttom head from someone else.
the main reason I deal away from RC Screwz is because their hex isn't precise and deap enough for buttom head and flat head.
I only use them on low stress area ONLY because I have plenty yet don't like to bent screw on the track.
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 06-12-2006, 09:36 PM   #1369
Motorman's Avatar
See ya all after the nats.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 06-12-2006, 09:57 PM   #1370
4F1Racing's Avatar
Darkseid,
You now have a G4s with a completely different weight distributiion and steering system. Use the base set up in the manual or the last one reported here on this thread whicj was froma cincinati race. Real good base setups to start.
The car looks great! Good Luck and Good Racing!
Sam
4F1Racing is offline   Reply With Quote
Old 06-13-2006, 12:46 AM   #1371
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
hey all I am thinking about getting an g4. Has anyone ever used the
K - Factory Alum. One Piece 32TFrt One Way/Solid Axle?
thanks Jason
jscamry is offline   Reply With Quote
Old 06-13-2006, 01:28 AM   #1372
thanks Jason
it is a standard in G4S, a decent piece of parts that reduce the need of disassamble the front end which is the only pain of G4 Series
Xray X12 2015
ARC R10 ATS
Old 06-13-2006, 08:08 AM   #1373
4F1Racing's Avatar
Carbreaker
Old 06-13-2006, 11:40 AM   #1374
jscamry's Avatar
about how many scews and time does it take to remove the front end, if youhad to replace the diff?
thanks Jason
Old 06-13-2006, 11:42 AM   #1375
NiMo's Avatar
less than an RRR or an FW05 as you dont have to touch the radio tray.
front diff change time on the G4s is the quickest I have come across, unless the belt wants to be awkward.
NiMo is offline   Reply With Quote
Old 06-13-2006, 01:42 PM   #1376
Changing front diff of G4 is quicker but not quickest, 710 and MTX4 is quicker then G4. I see a potential change in G4 bulkhead that can make it even faster changing, only if TM can figure it out
vs.
Xray X12 2015
ARC R10 ATS
Old 06-13-2006, 02:36 PM   #1377
mtveten's Avatar
Trader Rating: 27 (100%+)
I am fairly sure the Kyosho has a quick release from diff similar to the G4's quick release rear diff on their newest RRR kit.
Although its one of the more time consuming changes to make on the car, it is fairly easy and doesn't take that long to change the front diff. On the rare occasciot you need to change the front diff simply:
1. remove the front bumber assembly
2. remove the front upper bulhead brace
3. remove front shock tower
4. remove 1 front arm hing pin and pull arm out of the way.
5. remove diff retainer from 1 side of car and thats sides bulkhead half
6. pull out & replace diff.
7. re-assemble.
For a slow mechanic like me it takes about 15min.
Mark
mtveten is offline   Reply With Quote
Old 06-13-2006, 03:07 PM   #1378
with my Idea draw above, replace the front diff will take no longer then 5 minute just as fast as the rear diff of G4
Xray X12 2015
ARC R10 ATS
Old 06-13-2006, 03:56 PM   #1379
NiMo's Avatar
7. re-assemble.
That's how I do it
I had the RRR and that front quick release only worked if you took of the radio plate, it was actually quicker to do it like the G4 as mentioned above but then getting those belt tension rings in the correct slots were a pain.
Old 06-13-2006, 05:10 PM   #1380
mtveten's Avatar
Oh well, comming from electric racing I guess I am just used to this kind of thing. I remember with my last sedan, Xray Fk05, I would have to take screws out of the upper deck loosen the opisite side, remove the bumber, and a bulkhead to change from a front diff to a 1-way and the have to reset the tweak so the car world be drivable.
What I would really like to see is some way to change the rear diff lube without having to take the diff out of the car. If they were to come up with a casing that had a filling hole and a means to drain the diff before a refill I would be in hog heaven.
Mark
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
