Old 08-21-2011, 10:21 PM   #11611
Bundy_Bear's Avatar
Originally Posted by blis View Post
The locker/spool on the front will reduce the weight significantly. Depending on your track this can work for or against you. A spread spectrum radio with good servos will be a better investment in the long term and give you much better response.
The stiffer the diff oil the more push/understeer you will get "on power". Soften the oill too much and with oversteer it will snap out on you. Once you get the suspension, steering and overall balance to your liking things will settle down.
Try adjusting the castor to set the camber on turn and don't throw your money at the car until you know what you need and why.
Speaking of diff oils, i have just ordered a heap on Patto's recommendation to try something new and see if i can overcome my on power oversteer issues. Failing this and i will have to get a customer car deal on a Serpent 733 TE and just show up to the track to drive :P
Patto: Are you listening
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 08-21-2011, 10:24 PM   #11612
Default How old is the G4 Chassis
Hi all, i have inherited a g4 roller, ad was wondering how old this chassis is and what if anything would have to be upgraded to make it competive at club level.
A scape goat is almost as good as a solution to the problem.
Craig67 is offline   Reply With Quote
Old 08-21-2011, 10:52 PM   #11613
Bundy_Bear's Avatar
Craig:
If possible could you post a picture off the car so we can see what model you have. The original G4 was 2004 from memory and Team Magic used this platform till 2008 over many variances.
Looking forward to hearing from you and happy to help... Where are you looking at running it?
Andrew
MissMooRC Racing
Old 08-22-2011, 12:56 AM   #11614
Default G4 pics
thanks for the relpies, not sure what im going to do with it, came as part of a package of gear( serpent 733, dx3r+bits and peices) i bought second hand. New to rc car racing, so i will give brendale a go.
cant post pics at the moment, the chassis and pic are in the Australlia for sale section
posted by K-h1
cheers
Craig
Old 08-22-2011, 01:17 AM   #11615
Bundy_Bear's Avatar
posted by K-h1
cheers
Craig
Craig:
I think it is an original G4 from memory, best bet is to talk to Blis (Harry) as he races a G4 at Brendale with his sons and he will be only to happy to assist.
Andrew
MissMooRC Racing
Old 08-22-2011, 02:21 AM   #11616
blis's Avatar
posted by K-h1
cheers
Craig
Have heaps of parts to get you up and running.. Short of spurs and belts.
PS: Will you be running Friday nights or Weekend Pro touring, Im a member there.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 08-22-2011, 12:36 PM   #11617
g-wan's Avatar
Send a message via MSN to g-wan Send a message via Yahoo to g-wan
anyone know where can i get the k factory brown belt?as i check k fac website there no old brown belt anymore for the g4,
as for the diff its really hard to find the small rear diff,so i try to convert my trany from kyosho or mugen as i have nothing to do with my time while waiting for the part coming,
km k8 / os speed / savox / blitz / contact tyre
km hk1 evo / os speed / savox / sweep
sworkz evo / spower evo s7 / sweep / savox
xray t3 2012 / tekin rs pro / reedy / savox
km racing / sworkz / xray / savox / sanwa / os speed / sweep / ulti / blitz
g-wan is offline   Reply With Quote
Old 08-29-2011, 07:12 PM   #11618
Bundy_Bear's Avatar
Default Diff Oils / Oversteer On-Power!
Hi
Just wanted to let everyone know that changing the front diff oil making it thicker has cured my on-power oversteer. Only issue now is a little mid corner understeer which i will try some castor/ front roll centre changes and see what difference this makes... Very Happy Team Magic Camper now!
Andrew
MissMooRC Racing
Old 08-30-2011, 05:47 AM   #11619
blis's Avatar
Originally Posted by Bundy_Bear View Post
Hi
Andrew
Could that mean you may have thinned your rear?
Old 08-30-2011, 06:50 AM   #11620
Bundy_Bear's Avatar
Harry
I haven't touched the rear, just used a thicker oil in the front diff. I might have to go thinner in the rear to get some steering back, but have gone back to original settings for the front roll centre and caster as see what impact this has now.
Hope the weather comes good for the weekend so i can try it now!
Andrew
MissMooRC Racing
Old 08-31-2011, 01:01 AM   #11621
Bundy_Bear's Avatar
Default Clutch SOS!
Harry I need help with the blasted clutch again. I have changed my engine to a new STS from the Picco and it has rounded the edge of the teeth on second gear from the clutchbell. If i push the motor back to give it more space the first gear pinion only sits half way through first gear....
Between issues with 2nd gear I managed to loose the screw and thrust bearing out of the engine. Hope it hasn't damaged the thread on the crankshaft.
Andrew
MissMooRC Racing
Old 08-31-2011, 10:49 AM   #11622
blis's Avatar
Andrew
I am assuming you are using a steel new bell. this is a common problem with the TM. I've rounded the second spur a few times and it doesnt seems to cause too much of a problem. Just check it once you have run in the gears.
If you cant settle the engine mount you can shim behind the collete to get the clutch bell a fraction further outward but be careful you dont consume all the clutch gap in the process
TM's arent the easiest clutches to mesh.
Old 09-07-2011, 04:16 PM   #11623
Default centax
Hi,
I have a TM G4JR car, and it don't have the centax.
One friend have a Hobao GPX4 centax kit, and is not using it.
I'm looking his GPX4 centax kit to fit in my TM G4...
Anyone can tell me if the GPX4 centax will fit in the G4???
My friend lives far away form me, so I can't try to put the centax in my car to know if it fits...
Thanks.
guilcm123 is offline   Reply With Quote
Old 09-08-2011, 04:51 AM   #11624
Hello!
I'm really pissed here, let me tell you why. I bought a G4S (first one, they sey) and everyone says my car isn't competitive in comparison to the cars running at my track. G4RS and Mugen MTX4R.
The question is, is that true? Is there any way of Upgrading my car? I prefer to spend 150$ with upgrade, instead of 500$ on a new KIT. The engine I admit is not competitive, Its a Novarossi LS3 buy I'm thinking on buying a Flash later.
Can you Guys help? I'm also looking on the web for the G4 Series on the web and i can't find de order for the cars... Wich one came first.. .and second... G4 -> G4 + -> G4+ Evo -> G4S -> G4RS -??? Is this right?
Hope you can help me. I really like my TM.
Nelio is offline   Reply With Quote
Old 09-08-2011, 05:26 AM   #11625
g-wan's Avatar
Originally Posted by Nelio View Post
Hello!
regarding for TM g4,im still using g4 black magic for my whole season,i admit that my speed very slow then other brand but as long as im still love to drive with the magic so whatever people say or critic bout those kit i jus ignore,
so for the option part u can check on rcmushroom.com,
http://www.rcshopping.com/index.jsp?tag=index
its start with #502 for g4,g4s,
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
