Old 03-18-2011, 02:18 AM   #11551
blis's Avatar
Originally Posted by Bundy_Bear View Post
Harry:
This is a good read, good to see the boys flying the Team Magic flag and doing well.
Abbey has given permission to change project Mongoose to either G4+ or G4+ Evo.... Not sure which way to go, leaning towards to the + LE to be honest! Any thoughts will be appreciated!
Andrew
Andrew I think there's going to be very little difference as from what I saw, the mongoose is using the new hubs, the newer front brace etc.
I'd decide whether to use the ED transmission from the LE in the mongoose with the vented brakes and steal the RED KF bearings from the LE as well as they are very good.
The EVO rear end will cause you grief as it's using different bulkheads, hence if you smahed up the plate, you've got the parts short of the bulkheads.
I have spare chassis plates etc.. wanna give me a call and have a chat?
h
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 03-20-2011, 11:51 PM   #11552
Hey iv got a team magic g4js and the back belt seems to have to much play and slips but It's not adjustable dose any one no a way to fix this problem pls help and thank you
oldskool325 is offline   Reply With Quote
Old 03-21-2011, 12:19 AM   #11553
Bundy_Bear's Avatar
Oldskool325:
Your right about the rear belt, Team Magic have a belt tensioner available, but is only for the G4RS chassis and is screwed underneath onto the chassis itself.
The G4RS chassis is #502319
Rear Belt Tensioner is #502266-1
And then you can move everything from your G4JS onto the G4RS Chassis.
Hope this helps
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 03-21-2011, 07:25 AM   #11554
qcrc's Avatar
I have not seen a JS in person but will the old G4 top mounted belt tensioner work? Just an idea.
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Old 03-21-2011, 09:58 AM   #11555
yes that dose help thank you,is there any other way instead of buying the g4rs chassie?
Old 03-21-2011, 08:35 PM   #11556
Bundy_Bear's Avatar
Oldskool:
As Qcrc has mentioned KFactory use to have a rear belt tensioner that screws onto the carbon fiber brack bracket, but i believe this has been discontinued now.
I need the same part for my Project Mongoose 2011 as the belt flaps in the wind so to speak.
Another option might be to try a KFactory Competition Low Friction Rear Belt as it isn't a rubber belt and looks tighter then the rubber ones. I haven't tried this either and don't have a part number as i am work!
I will post part numbers when i get home...
Hope this is helpful
Andrew
MissMooRC Racing
Old 03-21-2011, 08:42 PM   #11557
Bundy_Bear's Avatar
Oldskool:
Andrew
K1495 is the rear belt!
MissMooRC Racing
Old 03-21-2011, 10:27 PM   #11558
im going to try and change the belt if that dosent fix the problem i guess im going to change the chassie unless i figure something else out thank you for the help
Old 03-21-2011, 11:27 PM   #11559
hey would this part make a difference or is it just a replacement part
k1453-6
Old 03-22-2011, 01:34 AM   #11560
I put a tm belt tentioner on my mongoose by drilling two holes just take your time to carfully locate the mounting holes then countersink at 45 deg.hope this helps
mxfred is offline   Reply With Quote
Old 03-22-2011, 01:43 AM   #11561
do you have any pics so i can get a better idea ?
Old 03-22-2011, 02:30 AM   #11562
blis's Avatar
Old school..
If you give me some reference points on .. no matter..
Old 03-22-2011, 03:35 AM   #11563
Bundy_Bear's Avatar
k1453-6
Oldskool:
This is a pulley for a rear ball diff instead of the standard gear diff. So no i wouldn't go down this path...
Andrew
MissMooRC Racing
Old 03-22-2011, 09:01 PM   #11564
okay thanks guys ! im going to try changing the belt first
Old 03-23-2011, 03:55 AM   #11565
Bundy_Bear's Avatar
Oldskool:
No problems, glad i could help! Let me know how you go...
Andrew
MissMooRC Racing
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
