Old 09-08-2010, 05:35 PM   #11461
qcrc's Avatar
How are your outdrives on the rear diff? If they get notches in them the cvd's won't slide and can cause the suspension to act wierd. I have seen it wear the tires on the outside more than the inside even with 4* of camber.
https://www.facebook.com/ISLANDSPEEWAY/
qcrc is offline   Reply With Quote
Old 09-09-2010, 05:14 AM   #11462
VinnieWee's Avatar
Originally Posted by blis View Post
Sonsa, I said before, it's natural that rears will wear more as the transfer of weight shifts to rear. So run harder tyres, 40's give yourself 2mm split larger rear.
And you're sure side belts and front belts arent slipping right?
h
PS: This will be even worse with Soft Shore and Hard Srpings.
Yeah i know the rear tires will wear more, but i still want more drive at the front.
Yes im sure no belt is slipping.
Well i have 1.6 springs rear, is that to soft / to hard?
If youre talking to me - The outdrives look fine and the cvds slide as butter.
But still tire wear is not my biggest concern, i want to know why the tires chunk on the outside of the rear tires. I have tried using the stickers and shape the outside more round. Both dont work, i will try glue next time but i doubt that will work.
Mugen MBX7R - RB BXR SLSDI5 - Byron Race - S9352HV - Futaba 4PX
Mugen MTX6 - RB TXR Touring LS3 - Byron Race - BLS571SV - Futaba 4PX
Mugen MBX7R ECO - Tekin RX8 GEN2 + 1900kV - ProTek 4S 100C - S9352HV - Futaba 4PX
XRAY T4 - Tekin RSX Gen2 + 4.5T - Team Orion 2S 100C - BLS571SV - Futaba 4PX
VinnieWee is offline   Reply With Quote
Old 09-09-2010, 05:38 AM   #11463
Pattojnr's Avatar
Trader Rating: 19 (100%+)
using Xceed tires ? i use them and they are great. no chunks.
i know you posted a setup before, but it is missing things on the sheet.
it is important to know what all the settings are at.
too soft a shore tire will alwyas load the outside , as teh foam is softer, and the rims pivots ont eh edge of the foam on fast corners, and heavy braking.can be simple as a rock, or too much roll on foam, creating your problem. droop can be used to limit the upwards chassis travel, but it also effects how much camber the tires have when they are just about to unload. if you dont use screws, they will have free travel, and can even drop back to 0 or even + camber unloaded, this can have a big effect on chunking as well.
no matter what car you drive, rears will always wear faster, unless you run different front to rear shores, or change the overdrive drastically.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-09-2010, 07:12 AM   #11464
DHooter's Avatar
Trader Rating: 25 (100%+)
does horizon hobbies carry parts for the team magic/ rd logics mongoose g4, my LHS orders from horizon and great plains and was wondering if i could just go through them or if i have to order from someplace on line
Daniel Hooten
SEE YA IN THE FIRST TURN!
DHooter is offline   Reply With Quote
Old 09-09-2010, 09:33 AM   #11465
g-wan's Avatar
Send a message via MSN to g-wan Send a message via Yahoo to g-wan
even i also get the problem for the rear tyre wear but after using 37 front and 40 rear its work,but its take me alot of time to make my driving work on the setup,i got traction roll on the sweeper which make my car roll over to the curb.. by using 35 shore front and rear..
km k8 / os speed / savox / blitz / contact tyre
km hk1 evo / os speed / savox / sweep
sworkz evo / spower evo s7 / sweep / savox
xray t3 2012 / tekin rs pro / reedy / savox
km racing / sworkz / xray / savox / sanwa / os speed / sweep / ulti / blitz
g-wan is offline   Reply With Quote
Old 09-09-2010, 03:26 PM   #11466
blis's Avatar
What parts were you after??
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 09-09-2010, 04:35 PM   #11467
Ahhh im so mad right now. Everytime i drive my g4s on the track, both rear tires gets destroyed.
Foam gets ripped of the wheel on the outside, this happens EVERY time. What the hell is wrong???
No one at my local track knows why this happens. I have the same setup as they have in camber, toe-in and such. They dont have this issue...
I changed the oil in the rear diff to 30k cause someone said that was the problem, i hade 6k before.
I didnt hit the curbs, i didnt flip the car or anything. Im getting so sick of this that i am thinking about stop racing 1/10th onroad...
EDIT: And yeah one more question, HOW do i get more front drive, its like im driving a rwd car right now. TM added a huge front sidepulley and a small one rear side. 27t vs 18t/19t, what the fudge?
Sonsa I've reviewed your setup, I recommend reviewing your rear ride height at 8mm this is going to make a significant change in the camber at the wheels. On the 30k fluid this isn't going to be causing the problem... however it should only be used when the traction is high... In low traction you'll have a better feel if you put fresh 7-10k oil in a rebuilt diff... You can mix a little 30k oil in too if you want to bring it up a fraction.. say nearer 15k
I have chuncked several foam tyres on the G4s, aside from a very agressive camber setting, I'd check your rear width... I found that when I had set my rear width at 200mm with 1 particular brand, then changed tyre brands to another (matrix) that resulted in a much wider track width... so far that the lexan body could cut into the edge of the tyer, causing it to chunk...
Check the ripple strips at the track, they can also give you some trouble as they can have an edge that will damage the side of the tyre.
As others suggested it will help prevent chunking if you can keep your tyres trued between rounds..
anthony_ling is offline   Reply With Quote
Old 09-10-2010, 05:24 AM   #11468
DHooter's Avatar
im just looking for a good parts supplier for next season, it will be my first nitro on road season comming from stock elec TC and off road so im sure ill need a few parts from time to time lol
Daniel Hooten
Old 09-10-2010, 08:11 AM   #11469
blis's Avatar
The mongoose.. as in the old model car?
If so it's evolved a lot and Ive got heaps of older g4 parts I cant use.. Im not sure how easy it will be to get spurs either for the older transmission.
Anway.. if things break.. just ask.. or try www.rcmanufactory.com
cheers
h
Old 09-16-2010, 01:34 AM   #11470
Bundy_Bear's Avatar
Default G4RS 2008 2 Speed Shaft!
Hi
Has anyone tried to shim some of the play in the 2 speed shaft at all on the G4RS? I noticed it is the same on the G4JR as well, it seems to come back an hit the clutch bell and put a mark on the spur gears
Cheers
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 09-16-2010, 06:09 AM   #11471
qcrc's Avatar
Originally Posted by Bundy_Bear View Post
Hi
Cheers
Andrew
It works well. Be carful not to use too many shims and make sure you leave a little bit of play or things can go bad.
Old 09-16-2010, 04:29 PM   #11472
blis's Avatar
Hi
Cheers
Andrew
Bundy the evo came with one of those bearing with a moudled washer attached. Seemed to remove all the play. Ive had a lot of play in my trans axle and it hasnt caused problems.
Old 09-17-2010, 04:44 AM   #11473
Bundy_Bear's Avatar
Thanks for advice, i used some shims from Tamiya electric car... I also moved the motor back a little more just to be on the safe side.
Will track test it on Sunday when i get all my receiver back together!
Thanks for help
MissMooRC Racing
Old 09-17-2010, 04:48 AM   #11474
Bundy_Bear's Avatar
Harry
I remember the bearing was different, but i don't know where i have put them. It could be in Abbey's G4JR, i still haven't fixed her radio on it yet so i wouldn't dare raid the 2 speed:P
Going to try Wynnum again this weekend with the G4RS, I have tried a few different things with my setup, but the track was so dusty last Sunday i am not holding my breath!
MissMooRC Racing
Old 09-17-2010, 03:06 PM   #11475
blis's Avatar
Harry
I also noticed the EVO uses a larger bearing in the 2 speed housing.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
