Old 01-28-2010, 01:23 PM   #11281
blis's Avatar
Default nice:)
Originally Posted by anthony_ling View Post
Hey Blis,
I drilled out a single hole in the stock pistons to a single 1.5mm on each shock.
I'm very pleased with the results! Getting excellent grip in the last three turns of the track when compared with the stock piston.
Cheers
Ant.
Yep it's coming together and Luis will be chuckling I know... I know... I know... I drilled out both holes with a 1mm so there was a little slack, if that isnt enough, Ill go one step further. Also did it for E4...
Ive got BAGS full of arms and parts atm, so we need to catch up on a Friday night, you are running the old style arms right? not the wings? Have two spare S chassis plates... and after bishop pointed out the rear end of the newer JR's have changed, there's a Lightened Chassis in there as well.
So can you pop down on a Friday night meet sometime and have a TM banter ? We're almost at the point where we might even have the numbers to have a MAGIC EVENING and hire the track for ourselves.
Boys are back at school and Sat/Sun is too much, I might come out to pit for Jeremy.
Hey, nice work on the VID... I bet your mate got dizzy at point 7... First gear looks a little long though, driving long into apexes.. just a thought.
He uploaded the AVI? Lookup ErightSoft - Super.. awesome re-coder for all types.
h
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 01-30-2010, 08:08 PM   #11282
Default RE: Chassis Replacement
It looks like the holes will line up just fine, but can someone tell me for certain if this chassis can be used as a replacement for my G4/RS(not 09') insead of the stock version which is a lot more expensive. It looks like the holes will line up just fine. Thanks
http://teammagicrc.com/articles.php?...cle=1000008306
OutlawIGT2 is offline   Reply With Quote
Old 01-30-2010, 10:45 PM   #11283
Bishop's Avatar
Sorry but no, 08 RS and JS/JR all use a shorter chassis with changes to rear mount holes, at a glance it looks the same, but when you sit one on the other it's different.
There is basically three generation of chassis on the pre-09 cars, all the early version run one, then you have the 08RS and JS/JR, then the last WC chassis, all are unique to the versions, you can't change them without changing a fair few other bits.
Bishop is offline   Reply With Quote
Old 01-31-2010, 08:10 AM   #11284
Thanks Bishop. Now I understand the talk about the constant changes in the TM cars. I just use the car for 132' drag racing and I'm frustrated.
I guess this #502319 fro $79 bucks is my only option. Kinda that you can get the 09' chassis for just $59.00.
http://www.wolfhobbies.com/search.cg...s&movetopage=4
Old 01-31-2010, 10:21 AM   #11285
Bishop's Avatar
http://www.rcmanufactory.com/search....31&Submit.y=12
RCMan is cheaper, I think, if overall strength is not so important, you could try even cheaper with the JR/JS chassis, but mine is soft so I can't recommend it as such.
And yes, 'everything' on the new RS09 is cheaper, a few theories floating around on that, it's either marketing by Team Magic to get more people buying into a new model sooner, or they have simply contracted out the production to cheaper sources, with maybe a question mark over quality doing that.
I do have my own theory though...
Some people are waiting for 'higher' spec 09/RS2 cars to come out, but I don't think TM will go that way this time, I think they are going to rely on a lower spec one version car, with bigger range of upgrades sold separately, cheaper but add up to more long term, better way for them to make money constantly selling upgraded parts with no new versions.
Old 01-31-2010, 07:09 PM   #11286
I think you are on to something with your theory. I'm in the US and not sure about RCMan, so I will have to call Wolfhobbies to see if he has the JS chassis. Couldn't find in on the website. Since I Drag Race, it deosn't matter that much about durability. If I hit at 55/60mph any chassis will bend.
Old 02-01-2010, 01:02 AM   #11287
Sp Racer's Avatar
This has worked for Kyosho for the past 30 years
Sp Racer is offline   Reply With Quote
Old 02-04-2010, 04:42 AM   #11288
Bundy_Bear's Avatar
Bishop:
Interesting... I am thinking Team Magic will continue to follow in Xrays footsteps. Xray released a standard NT1 to begin with and the we saw slight updates for the 2008, 2009 and now the 2010 models.
Remeber Team Magic did something similar with the G4 Evo, G4S, G4+, G4RS 2008, and then finally the G4+ Evo
Time will tell... At the moment Team Magic seem to be doing a HPI and concentrating on the RTR market with buggies (nitro & electric) and the drifter scene with easy sales!
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 02-05-2010, 05:19 PM   #11289
blis's Avatar
Default Brainstormers required.
I cant solve the loose tail end on my G4s... Pretty much all the Pre 08 G4 series I have feel the same.
So without posting the specifics, anyone care to throw ideas into the wind to save me writing a list of things Ive tried and failed.
What I can say, is I haven't explored Diffs intensively, nor tried much in roll centres and weight distribution. Sway blades are flat, tried soft, hard, suspension oils and springs, standing up, laying down, more camber, less camber, heavier diff oil, perhaps not light...
It snaps out of corner exits under power, behaves well into them.
h
Old 02-05-2010, 07:03 PM   #11290
NitroWD's Avatar
h
as a start and easy change:
1. softer rear springs
2. taller 1st gear.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 02-05-2010, 07:48 PM   #11291
blis's Avatar
Default Thanks.. any other ideas?
Tried all spring combos..
2. taller 1st gear.
Longer gearing? Ive been running Long on TG gas car.. makes no change.. back end still comes around.l
Old 02-05-2010, 08:28 PM   #11292
Sp Racer's Avatar
try get yourself a wc upgrade kit Harry, it's the only way you'll stop this inherent handling trait.
Cheaper than switching to the 09
Old 02-05-2010, 08:31 PM   #11293
roach's Avatar
Send a message via Yahoo to roach
Default ideas!
when i lose my set up...its like that sock in the dyer..that you never seem to find.... sooo now i'll just bring it back to the factory set up and apply the basic's again. and many times.. i've found something bent or not right. it sux to do!...but, when its right ..again, its so worth it.
roach is offline   Reply With Quote
Old 02-05-2010, 08:39 PM   #11294
British Menace's Avatar
Heloo all you G4 runners .....
How are we all?
There are some people out here I still remember from the early days when I used to be on b4.
Bils .... try cutting down the amount of droop on your front...... also try a little more rear toe. :-)
Good tohear the G4 is still alive and kicking !!
Anthony
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 02-05-2010, 08:40 PM   #11295
Lol ... the b4?? I think I meant the G4 Haha
Still as goofy as ever!!??!
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
