Old 05-24-2009, 02:07 PM   #10831
Nitro-Racer*'s Avatar
yes of course a stiffer cluch spring should do it. also try some heavier diff oils too if you want more punch.
Xray Nt1-Novarossi 3sct-KoPropo-GRP-Altis 2.3-RB Fuels
Xray 808 09-RB Killer 9-Hitec-KoPropo-RB Fuels
Nitro-Racer* is offline   Reply With Quote
Old 05-25-2009, 01:39 AM   #10832
blis's Avatar
Default What's not working?
Originally Posted by abi View Post
Hi all,
I searched this thread and found some bits and pieces but I'll ask here for the latest.
I run a G4S on a tight temporary parking lot track each week. What would be a good setup for this application?
Track is small and tight, no track grip enhancer used except blowing track clean before racing. Racing is 2 x 5 minutes each night so tire wear is low.
Wanting to know best ackerman, tire diameter split, track and wheelbase, caster, springs, shock oil, pretty much everything.
Any help appreciated
I doubt an all purpose setup will be any better than what you have allready otherwise you wouldnt get around a tight twisty track. Is track smooth enough to run stiff? Over or under steer? Good in and out of corners?
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 05-25-2009, 01:50 AM   #10833
freestyles's Avatar
Trader Rating: 14 (100%+)
Hi all,
Do you run out at sirc (pdnr) on a tuesday night by any chance? If so PM me for a set up
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 05-25-2009, 05:46 PM   #10834
aizenbelle's Avatar
Originally Posted by Ladder Killer View Post
Check this
I cant wait!!!!!!! I want to fire it up!!!!!!!!!!!
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 05-25-2009, 05:56 PM   #10835
Ladder Killer's Avatar
Nice, hope it does good for ya.
My last race I had the wrong gearing but it was still flying.
( I know where you stood last weekend) http://www.MobileRCRacing.com
DiscountRCRacing - http://myworld.ebay.com/discountrcracing
Team Magic Parts, Kits and More www.machinaria.com
RC Apparel - http://www.bluegrooveapparel.com Globalhobby.com - XtM Racing Teamxtm.com
Ladder Killer is offline   Reply With Quote
Old 05-25-2009, 06:14 PM   #10836
aizenbelle's Avatar
Thank you !! I will post some more pictures soon when I get the rest of my new stuff.
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
Old 05-25-2009, 11:03 PM   #10837
abi
Yes I do freestyles! PM sent. Look forward to your set-up.
Thanks Blis, so far am using factory settings with the exception of softer springs (and the shortest gearing of course). Wheel track is currently 204mm, wondering if I should try say 197mm or 196mm etc?
abi is offline   Reply With Quote
Old 05-26-2009, 03:21 PM   #10838
blis's Avatar
Default Rear End..
Yep Magics are quite wide for AARCMCC spec races, you can either move lower arms into the inner position (if avail on your model) and this will reduce track. You can wind them in but ensure the dog bones arent jamming and the arms and joints are free and not sticky. Ensur the sway bar isnt locking when narrowing too.
And you might find you will have to dremel off the ends of the wheel nut thread as they protrude beyond rims and track width too, depends on hex hubs and wheels you use. Ensure to try a few wheels as not to grind off TOO MUCH.
Good all round springs in soft config = Turquoise front 1.6mm / Purple rear. 1.3mm.
Old 05-27-2009, 09:42 PM   #10839
Again, remember if you need rc parts, including Team Magic check out
ebay - his name on there is discount rc racing
Mention my name ( Donnie ) and he might give you a discount. You can email him off his ebay store page to ask any questions for parts or kits. He's a local here in Mobile Al
Old 05-27-2009, 09:52 PM   #10840
Here's a link http://stores.shop.ebay.com/Discount...__W0QQ_armrsZ1
Old 05-28-2009, 06:11 AM   #10841
Default G4RS Impressions
Got hold of a brand new G4RS kit and built it up. Initial impression of the car was that it had way too much steering and it constantly unsettled the rear end which resulted in a car which was unpredictable... Was told by many to try lighter rear diff oils and lighter rear springs to settle the rear but this resulted in sluggish car. The only good point I had about the car was its ease to drive, very planted feel and forgiveness to sloppy driving... but overall the car was not as competitive as my prevous Xrays and Kysohos in terms of lap timings...
However, i did not give up on the car and analysed the issues i had with the car which were basically the way too fast turn-in unsettling my rear... I also wish to run a stiffer rear end with a heavier diff without it kicking out of corners for the added punch.
Decided to lower the front roll center to deaden the steering and also lower the rear roll center for more rear grip... now the car understeers more and works like a charm.... I am clocking similliar timings as before...
So in short, try the roll centers before giving up on any car... must say this car is really nice to drive...
katze is offline   Reply With Quote
Old 05-28-2009, 12:26 PM   #10842
nice info to know
Old 05-28-2009, 03:15 PM   #10843
Sp Racer's Avatar
katze -
Good to see you chose the "analysed the issues" route and didn't just give up, sell it and get a different car ( as most do)....
Unfortunately, that handling trait seems to be the Achilles heel of the G4RS - you'll tame the snappy steering by lowering the front roll center and then you will lose steering response and the car will feel "doughy" on the change of direction.
Don't be afraid to try front springs from different manufacturers ( hint)
The WC adjustable roll centre kit solves this by giving you greater adjustments.
aizenbelle -
I have a G4+EVO and in comparison to my RRR they are on the same level. I dont think the G4RS would be much different. all the parts in the G4 line are Interchangea
The nicest thing about the TM stuff is the material quality!
We've raced G4RS's for over 18 months - still on the original F & R belts, original diff out drives and still the original drive shafts!....cars are still tight and slop free.
nazwenhome -
ome racers here told me, it is a wrong move from Kyosho to TM chassis. IMHO, small details wont hurt me
Your hip pocket will disagree !
Sp Racer is offline   Reply With Quote
Old 05-28-2009, 09:14 PM   #10844
Originally Posted by Sp Racer View Post
katze -
i am using Xray front springs... they just feel better up front... more precise steering...
Old 05-30-2009, 04:22 AM   #10845
aizenbelle's Avatar
great thank you I noticed there are more sellers online now than there were a year ago, so that is good news for my TM cars.
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
