Old 04-23-2009, 11:12 PM   #10741
keavze's Avatar
Originally Posted by nazwenhome View Post
for the extra info, im using stock red spring, red centrifugal shoe, single flyweight.
0.4mm clutch gap and 0.1mm end play.
its like totally the opposite from manual. wont it prematurely kill my shoe clutch due to slip?
clutch gap is by shimming at the thrust bearing side and end play is shimming at the spring nut side; hope it's clear...
0.4mm clutch gap and 0.1mm endplay is a good starting point.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 04-24-2009, 12:05 AM   #10742
nazwenhome's Avatar
Trader Rating: 33 (97%+)
this is clear enough thanks guys. will try the setups tomorrow. my problem is, my grp engine lacks so much bottom end compared to my previous engines. it just doesnt gives much punch out of the corner, so i suspect its the clutch tuning or wrong glow selection. any thing i need to highlight for the next correction?
Serpent S411 TE : ready to race
Tamiya TA05 VDF : sleeping mode
Align 450 sports v2 : tick-tock in progress
nazwenhome is offline   Reply With Quote
Old 04-24-2009, 03:53 AM   #10743
freestyles's Avatar
Trader Rating: 14 (100%+)
As Keavze said it's just a starting point. You will have to fine tune from there depending on track conditions and driving style. It's more a personal setting, how much slip you run. The manual states .4mm-.7mm clutch gap with minimal endplay eg:.1mm is recomended starting point.
If your running the red shoe i think that's the hard shoe so it will wear normally.
Also i have a question of my own, what's the difference between the fly weights? I know it's the material but is there any tuning advantages to using different types of throw weights?
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 04-24-2009, 03:57 AM   #10744
freestyles's Avatar
If you want a bit more acceloration down low try running a bigger clutch gap it will make your clutch engage at higher RPM's and should make your car accelorate better. If your gap is to small the clutch engages at a lower RPM and bogs your motor down a bit
Old 04-24-2009, 04:28 AM   #10745
nazwenhome's Avatar
i did read about the fly weights somewhere in this thread, maybe page 30 onwards. more weight ,linear acceleration feel at mid band. most of g4 drivers here didnt put any weight, they claimed its best suited for mod motors with huge power at bottom end like the JL tuned.
as for the material used in the hard red centrifugal clutch shoe(which hold the 2 fly weight), it last longer than the normal shoe. i've been using them for 4 months with not much wear as compared to my buddies at track.
Old 04-24-2009, 08:35 AM   #10746
keavze's Avatar
running bigger gap will not be suitable for lowgrip and/or small tracks; it'll also make yr car more likely to break loose out of corners.
to engage at higher rpm, you should adjust the spring instead. grp is a rpm engine, you must let it rev up to be in the power band. using a smaller gearing will help.
Old 04-24-2009, 04:36 PM   #10747
freestyles's Avatar
That's where throttle control comes in. If clutch engagement is tuned by the spring tension what does the clutch gap do? You can tell i know nothing about nitro motors
I realise the material is harder/softer therefor lasts longer/shorter but i was wondering if there is a tuning benifit from using harder throw weights. Eg: earlier clutch engagement with harder throw weights, later clutch engagement with softer throw weights etc.
Old 04-24-2009, 04:44 PM   #10748
Sp Racer's Avatar
.....Just drive around it !
Sp Racer is offline   Reply With Quote
Old 04-24-2009, 07:34 PM   #10749
RACER12's Avatar
any one out there now where i can down load a manual for a G4 mongoose team magic nitro car
RACER12 is offline   Reply With Quote
Old 04-24-2009, 07:41 PM   #10750
Sp Racer's Avatar
What do you need to know Chris ?
try this
http://teammagic.com.tw/download/G4EVO/G4EVO.zip
Old 04-25-2009, 07:26 AM   #10751
nazwenhome's Avatar
i got the perfect setting today, its not my gap that causes the problem, its the lower rpm. previously i run 0.8mm spring tension, now 1.2mm.. lotsa power out of the corner. but after 5 laps, i get temp of the clutch bell, its 49 degree Celsius!! i dont normally do this, is it normal for a 0.1mm clutch gap and 0.4mm end play?
Old 04-25-2009, 03:52 PM   #10752
freestyles's Avatar
If you have to wind your clutch nut down that far then it's time to get a harder spring. The red spring is very soft, may i suggest to order the orange spring and give that a try. That will help with bottom end snap. .1mm clutch gap with .4mm endplay is the opposite to what i run and i wouldn't personally run that, that's not to say it wont work but probably not recomended.
Old 04-25-2009, 07:17 PM   #10753
keavze's Avatar
clutch gap will determine how hard/soft the clutch engages while spring tension decides when it engages.
no offence mate.
Old 04-25-2009, 07:20 PM   #10754
keavze's Avatar
0.4mm end play will destroy yr thrust bearing earlier.
usually i run my engines with 0.5mm gap and 0.1mm or less endplay.
Old 04-25-2009, 11:25 PM   #10755
RACER12's Avatar
try this
hi lou
need steering servo horn,battery pack and a few more bits also would get some spares to
just trying to get part numbers so i can source these bits
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
