Old 03-02-2009, 06:02 PM   #10606
NitroWD's Avatar
Originally Posted by Pattojnr View Post
if your only running 1 mm of caster now, then id try 1mm toe out (each wheel) and more rear droop first.
more droop = smaller number on the droop blocks?
is it always setup to have the rear less droop than the front? meaning the front having lower number than the rear on the droop blocks.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 03-02-2009, 07:12 PM   #10607
rcrevolution's Avatar
Send a message via AIM to rcrevolution
price is $330 shipped for a BRAND NEW NEVER RAN G4RS, THATS $70 off retail!! i built it last fall and never ran it, I just lost my job so it has to go, hit me up if you're interested!
rcrevolution is offline   Reply With Quote
Old 03-02-2009, 08:17 PM   #10608
Pattojnr's Avatar
Trader Rating: 19 (100%+)
more droop = lesser number yes on the blocks. more rear droop will give a little more steering, but too much can upset the rear off power. droop is used to fine tune your setup. so its not a certain number on the blocks that will make it right, sometimes it takes a small adjustment while racing to ge the balance your looking for. can be equal front to rear, but generally i wouldnt use more rear droop than the front. but dont rule out not doing it, just make te adjustments while at the track to feel how it changes your cars feel.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-03-2009, 03:09 AM   #10609
prawntoe's Avatar
man, I really like the engine mounted with the heatsink leaning forward.
Just like Usain Bolt sprinting towards the finish line
cool stuff man !!
prawntoe is offline   Reply With Quote
Old 03-03-2009, 03:48 AM   #10610
asw7576's Avatar
I think the idea of the engine leaning forward could lead into another dimension of troubles : glow plug installment become less precise.
Consider the situation if the glow plug is dropped, and the mechanic try to scoop it and quickly try to put it back. The threads alignment might not aligned properly due to the engine head is not perfectly vertical.... As the result, the turbo head plate become damaged, and the racer get into DNF due to engine trouble.
That's why TM will never be Xray or Mugen or Kyosho....... TM cars often get into DNF situation.
Old 03-03-2009, 04:27 AM   #10611
Pattojnr's Avatar
this is a concept car, many ideas here that they have illustrated , often change upon release. many manufacturers are in this stage of a new car, and im sure they will all hit the market at similar times, making the choice of a new car plentyfull. i just hope the plastic arms are much stronger cause thats the only thing that let it down previously. i was overall happy with the rest of the car. to say TM will never be Xray or Mugen , you got that right, and i hope it never will be, each manufacturer is different, and TM has always been different, thats why there is only a certain few that drive them. lets say id probably be still driving one if something wasnt offered to me at a crucial point in time. all i can say is i have enjoyed the transition, but each car has its own problems.
Serpent - Walter RC
Old 03-03-2009, 09:11 AM   #10612
Speyederjedi's Avatar
Glow plug miss-alignment??? Come on, that's your argument for why this concept won't be up there with Mugen, Kyosho or X-Ray??? That's a bit of a stretch (your pit person should be able to properly install a glow plug no matter the position of the engine). Don't get me wrong, I'm a loyal Kyosho fan but I've had a TM G4RS and this Concept II looks to have some fast forward innovations which may change the other manufacturers approach on chassis design and layout. A chassis that can be stiffened or softened front or rear. That's frickin cool!!! Unbelievable amount of ackerman adjustment not to mention the wheelbase adjustment, sealed fuel cell and of course the forward leaning engine mounted position. Now, I'm not saying I'll go out and buy one but seeing this new approach in design gets me excited about the future of 1/10 nitro and where it's heading
Regards,
Speyederjedi
Schumacher Mi5/Serpent Cobra GT
Novarossi Kappo Rally .21/Novarossi Kangaroo .21
Airtronics M8/Spectrum
SWEEP Tires
Speyederjedi is offline   Reply With Quote
Old 03-03-2009, 10:53 AM   #10613
freestyles's Avatar
Trader Rating: 14 (100%+)
I've seen heaps of mugens, kyosho's and Xray with DNF next to there names. It's the drivers that get them into that situation not the brand car they drive
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 03-03-2009, 12:52 PM   #10614
keavze's Avatar
what i can think of is it'll be more difficult to start the engine by yrself as u can't use yr plug starter to push down the car onto the starterbox...
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 03-03-2009, 01:38 PM   #10615
Sp Racer's Avatar
I have the LRP buggy with the engine at an angle - no problems.
It's only at a small angle though, 10-15 deg from the vertical
Sp Racer is offline   Reply With Quote
Old 03-03-2009, 01:39 PM   #10616
blee's Avatar
Obviously your conclusion is not ture. This design is new to G4 Series.
As last World Race event, only 4 to 5 G4s (out of 120s) attended the race. And one G4 went into A main final…… the result was very good even DNF finally.
For your logic, Xray is the worst, they have most cars attending in the event but they didn’t win the champion. Do not have bias, dude!
On the other hand, only a few folks running with G4 in major event around the world…. How you often see G4 get into DNF situation? Really unbelievable!
blee is offline   Reply With Quote
Old 03-03-2009, 01:58 PM   #10617
qcrc's Avatar
Out of the two years that I've run my G4 I have only not finished two races. Both were by my choice. I had a terrable setup once and the other I forgot to put the pin back into the rear shaft on the one-way. I can't blame the cat for either of them.
https://www.facebook.com/ISLANDSPEEWAY/
qcrc is offline   Reply With Quote
Old 03-03-2009, 06:55 PM   #10618
prawntoe's Avatar
Who cares how you stuff your plugs in, concept car looks good to me
not only that, TM marketing (gif/pix drawings, product writeups and presentations etc . . ) these 1~2 years really good too !!
it'll be a real wallet magnet !!
Old 03-04-2009, 12:09 AM   #10619
freestyles's Avatar
Hey Luis how is the new buggy? Have you got the new truggy aswell?
Old 03-04-2009, 12:55 AM   #10620
asw7576's Avatar
Wow, so many G4 supporters
Only time will tell if G4 II will be a successful car or not.
I have bad experiences with G4S before..... bad experience from working on the car, and 2 times DNF. Perhaps that's why I feel " I'm done with G4 cars forever ".
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
