Old 02-22-2009, 05:24 AM   #10561
freestyles's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Undies View Post
Patto being a Snake Boy... I heard these creatures are slow travelling, so he might have to leave now to be there on time:O
Originally Posted by Pattojnr View Post
sorry man, cant make it. i will be attending the Sa titles, WA is so far from anywhere , and SA is the most cost effective place to travel for me, plus i got some good mates there too. well they say thier good mates im trying for the nationals in Sydeney, (Pun intended)
WA is nice though my brother used to live there. When are the Nats?
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 02-22-2009, 06:36 AM   #10562
Pattojnr's Avatar
Trader Rating: 19 (100%+)
that will be October some time. i guess dates will be confirmed in the next couple of months .
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 02-22-2009, 06:53 AM   #10563
aussies1129's Avatar
Trader Rating: 74 (100%+)
howdy guys!
nsw state titles should be fun, where are they runnning the sa titles is it in the hamptons the new g4 looks good but thats what I thought about the evo2? TM just keep getting better! so you reckon you could dump the serpent and get the
g42?
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 02-22-2009, 02:57 PM   #10564
Undies's Avatar
Originally Posted by aussies1129 View Post
howdy guys!
g42?
cheers
Aussies: Are you going to drop your NT1 for it? Speaking of which have you noticed any inconsistancy with the 2 speed as yet? I heard you have to "upgrade" the springs in the 2 speed for it to improve.
Undies is offline   Reply With Quote
Old 02-22-2009, 05:32 PM   #10565
keavze's Avatar
Default spool push
anyone knows the best or most effective way(s) to reduce or get rid of the 'push' when using front spool?
or it'll always be there no matter what you do?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 02-22-2009, 05:49 PM   #10566
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Go to using a diff makes all the the difference in the world I had the same problem Talk to one of the sponsor racer at our local track he suggested using a diff with 100,000 wt or higher in the front & 30,000 in rear I probably won't ever go back to using a solid(spool) having a diff no more of a push and the car to me handles and drive better, give it a try you won't be disappointed you can always go back to using a spool..
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 02-23-2009, 12:10 AM   #10567
no mate I only just got it at the end of last year so still testing, I ran the g4s and g4rs for the last two years so xray is it for me for a while, but I have a soft spot for TM thats for sure!
cheers
H.E.I AUSTRALIA
Old 02-23-2009, 03:20 AM   #10568
Pattojnr's Avatar
howdy guys!
g42?
cheers
lol, i wont be dumping the serpent as yet. will have a new one this week for the titles. yes little hampton in SA, great track, very challenging.
if one was to recieve this Concept Car and asked to run it, then anything is possible and as im sure it would be for you as well
Serpent - Walter RC
Old 02-23-2009, 03:32 AM   #10569
Pattojnr's Avatar
Hello there George, and Anthony. Ant, how was the move mate ? raced in Vic yet ?
Serpent - Walter RC
Old 02-23-2009, 06:41 AM   #10570
Nitro-Racer*'s Avatar
yep same as me. always loved and will love the solid diff (it always fells like "home" when i drive with it) but when i used diffs i saw a great improvement and yes the best combo its 100000 in the front and 30000 in the back
Xray Nt1-Novarossi 3sct-KoPropo-GRP-Altis 2.3-RB Fuels
Xray 808 09-RB Killer 9-Hitec-KoPropo-RB Fuels
Nitro-Racer* is offline   Reply With Quote
Old 02-23-2009, 12:26 PM   #10571
Chickentrader's Avatar
Using 100,000 weight diff oil at the front and 30,000 - 50,000 at the rear is the conventional teaching. However using a very light oil at the rear seem to work better at my home club, and could be worth trying. You could also go for an even heavier front diff oil like say 300,000 at the front to limit the slip little more, without causing too much push.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 02-23-2009, 01:03 PM   #10572
Thumbs up
Kindest regards,
Lars.
I use 20,000 in the rear, I might try the 300,000 in the front... thanks for the info..
Old 02-24-2009, 08:09 PM   #10573
does anyone know what diff oil thickness they build the diffs with, for the g4js? the manual comes with setup sheets, one filled out for a starting setup and lists, 30k up front and 10k in rear. I'm wondering if that's what they built it with. anyone know for sure?
gladcow is offline   Reply With Quote
Old 02-24-2009, 10:56 PM   #10574
freestyles's Avatar
Most probably But i would empty them and put 100k up front and 10k-30k in the rear depending on traction levels where you race.
Also i have two questions: 1) How do you guys set up your ride height. I have set up wheels that are 65mm in diameter but when i set up on them the ride height is over 10mm Should i use the the size tyres that i will run with? But if i do that wont the ride height change as the tyres are getting smaller
2) Can someone clear up what happens when using different holes in mounting the rear camber links. For example: there are two vertical rows of three holes. What would happen when you move the link in or out apart from making the link longer? I understand what happens when you move it up or down
Old 02-25-2009, 01:42 AM   #10575
Pattojnr's Avatar
hey Keaves, when is your car pushing ? on power off power ?and hows your rear grip on power corner exit ?
Serpent - Walter RC
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
