Old 12-05-2008, 06:54 AM   #10351
NitroWD's Avatar
Default Differential gears
hi guys,
when do you know that the differential gears need to be replaced?
will them ever wear-out?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 12-06-2008, 05:20 PM   #10352
freestyles's Avatar
Trader Rating: 14 (100%+)
Originally Posted by NitroWD View Post
hi guys,
Yeah they will wear. Like anything that gets subjected to the abuse diffs do then they will wear. But if you shim them accordingly then you should last a while. When you do diff maintenance have a look at the gears and you can see where the gears fit into eachother and you should see a slightly worn area where the teeth meet. Sometimes you can see actual chunks out of the teeth (crashing into walls at high speeds will do this). But in a nutshell over time they will need replacing it's just your budget that dictates when.
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 12-09-2008, 02:01 PM   #10353
freestyles's Avatar
I just bought some clutch gear but i'm not sure which ones to use. There were five springs black,silver,yellow,orange and red. They are all roughly the same thickness (give or take 0.1mm) but they are all different lengths. It also came with the white shoe and the brown shoe from k-factory.
So my question is what combination do i use I have red (hard) and stock (black) throw weights and i have a stock (black) shoe aswell. And how many slugs do i use?
Can someone please help me.
Old 12-09-2008, 03:05 PM   #10354
hooked_on's Avatar
Originally Posted by Pattojnr View Post
for that hard braking corner entry, front tires are loaded up, and your trying to stop the car to get it to turn in. this will create wear, heat, and stress on your transmission. my suggestions previously were for a different way of driving the car, with out the heavy braking. if your braking your slowing down if your getting that little bit of slide with out braking, then your goign faster and you will get a bit more even wear as the rear will be sliding that bit more, not the front. have a think about how your loading the car up with the way your driving it now
Hey Serpent boy you are posting in the wrong thread;
What have you been up too Paul? Are you hiding from your Brisbane fans???
hooked_on is offline   Reply With Quote
Old 12-09-2008, 03:21 PM   #10355
Pattojnr's Avatar
Trader Rating: 19 (100%+)
still around, but super busy. never a wrong thread to post in. since i ran the car for so long, and i didnt get out of the car cause it wasnt good, just got a better offer. but now all the TM stuff i had is gone. but still have a looksy in here from time to time.
but i feel more at home with the serpent and will be awaiting the new car for SA and possibly the nationals.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 12-09-2008, 03:28 PM   #10356
hooked_on's Avatar
All good man... technically i am posting in wrong thread as well
Are you getting a new tourer? And will you get 08 model or is 09 due out soon?
Old 12-10-2008, 12:50 AM   #10357
Sp Racer's Avatar
With what you have, i'd use the yellow spring, (brown) red shoe and red throw weights - depending on how you like the clutch to engage, try 0.7 spring pre load and experiment with 2 slugs, 1 slug or no slugs ( less slugs make the clutch take longer to engage )
The white shoe is good, but has very little slip so you have to have the pre-load , slugs etc etc just right otherwise the engine will bog down.
The red shoe bites almost as hard but easier to set up if you know what i mean......in either case, they are far better than the kit black shoe.
See if you can get hold of the "push type" throw weights and hardware - they transform the clutch
http://www.rctech.net/forum/5012981-post1354.html
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 12-10-2008, 01:55 AM   #10358
hooked_on's Avatar
Sp Racer:
What car are you going to be running in the new year? Are you sticking with the G4?
Old 12-10-2008, 03:01 AM   #10359
Sp Racer's Avatar
Sp Racer:
Yep - we will be running the G4, can't see a reason not to
Old 12-10-2008, 03:16 AM   #10360
hooked_on's Avatar
No worries... thought i'd ask as has been eventful year with the change in distributor here in Australia.
Old 12-11-2008, 10:53 AM   #10361
freestyles's Avatar
I read an issue of racing lines yesterday and for the first time i saw advertisments for Team Magic all the way through it for the G4+, G4js, M8 buggy and even the E4 so it's good to see TM are spreading the word in OZ. surely this is a good thing I am seeing an increase of interest for the G4 at my local track so maybe it's working and why shouldn't it? Parts are easy to get NOW (thanks to www.zauberimports.com), the cars are fast and most importantly of all they look good so i can't see why you wouldn't want one
Old 12-11-2008, 02:43 PM   #10362
hooked_on's Avatar
Sorry i haven't noticed any change here in Brisbane. This is Mugen country, LHS don't carry TM spares... they can get them i am sure, but only have Mugen stuff on the shelf!
Old 12-11-2008, 04:57 PM   #10363
British Menace's Avatar
No worries mate ..... they'll wake up soon, after all, it is the 21st Century.
I think Mugan are still in the 20th .. lol
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 12-11-2008, 08:49 PM   #10364
freestyles's Avatar
Hi Luis,
I'm about to order the CRF square clutch spring do you recommend it or should i stick with the yellow spring?
Also what's the difference between the UFO1-UFO2? Is it just the material?
I'm going to do a clutch over haul tonight seems as though it's pouring rain and i can't drive it
PS: That link you posted in the last message to me doesn't seem to work have you got another one because i'm confused as i thought i had a "push type" clutch
Old 12-12-2008, 03:33 PM   #10365
Sp Racer's Avatar
The CRF spring is awesome.
UFO1 Vs UFO2, I think the difference is the flywheel ( but don't quote me on that) - Patto ?
The new clutch set up does away with the "UFO" part and the 3 small fly weights.
It is just like the Kyosho 3D clutch)( 3 flyweights, aluminium spacer, clutch shoe ) except you have a provision for 1 slug in each flyweight.
Since switching over to this setup, I have a far move even wearing clutch shoe, but these weights are heavier and thus require a harder spring ( CRF works the best so far )
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
