Old 11-01-2008, 04:36 PM   #10231
aussies1129's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Nitro-Racer* View Post
great info about spur gears striping. my problem of the spurs stripping was the fact that the spurs and pinios sucked in dust and little rocks due to going off track. thanks for all the info
hey try the steel pinions they have worked great for me the aluminium ones that I used before just wear to quickly,
also update: I ran 4x5min qualies last night with a 20min main and did all of the above with preventing stripping of spurs gears and my gears on the RS ran perfect, I made sure I put a good amount of locktight on the engine mount screws as I run a one piece and not one sign of movement even after a fews spills here and there.
thanks for the support guys
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 11-02-2008, 01:04 AM   #10232
Sp Racer's Avatar
Originally Posted by ALG View Post
It's great to read everyone post,
keep up the good info,
Next week I will be racing an Invitationaal race on Argentina, I will keep you all posted of the progess of TM and the race on Argentina.
I will be driving and TM G4SRS+ power by JP Eagle http://www.jpracing.com/en/products/...e_12_TL-3t.php with Enneti tires http://www.jpracing.com/fr/produits/enneti/
Thanks for your support, and have fun
ALG
Buena suerte ! dejanos saber como terminas
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 11-02-2008, 09:59 PM   #10233
revo523's Avatar
Hey guys i went to the local track today to race with my mongoose i never raced before but i had a good time out there and the rest of the guys were very cool but the only problem was that the rear of my car was sliding on every turn so since I'm a noob at this i wanted to see if ya ll can help me out. what can i do to control the rear of the car?. i was running the kfactory 42 shore at the rear and on the front i don't remember i all so have the ed tranny and the UFO clutch system with the stock diff oil on the front and rear running on asphalt any other info ya ll need to try to help me let me know thx.
revo523 is offline   Reply With Quote
Old 11-02-2008, 10:28 PM   #10234
keavze's Avatar
try a softer tire for the rear or a harder tire for front for a start.
then maybe you could try laying down yr rear shocks more or stand yr front shocks up more.
anything else think you've got to let us know what's yr car setup.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 11-03-2008, 08:00 AM   #10235
British Menace's Avatar
YEs. I would deffinately try softer tires first. Especially if your on a parking lot track. Try 40 or even 38 Shore tires all round. You may be set up too stiff too. If your running stock shock piston hole sizes, you need to be around the 40 WT mark. -3 degrees camber and -3 degrees toe in too at the rear is a goos starting point. If your on a bumpy track, go with 5mm front and 6mm ride hight at the rear. Smoother tracks you can go a little lower.
Also. Is your clutch set too aggressive? Do you put the power on when you go around the corner? And thats whu your rear is comming around.
Make sure your suspention is free when you disconnect your shocks. The arms must be smooth and free from binding.
Lastly. Make sure your droop screws are not set too high.
When your car is ready to race. Place the car on the floor (or set up table) and raise the rear of the car, slowly. The car should rise around 3 to 4mm BEFORE the tires come of the ground!
The front should be slightly less around 2mm.
Try this and see how you get on.
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 11-03-2008, 10:27 AM   #10236
revo523's Avatar
yeah it does happen when I'm hitting the throttle when going true the corners so I'm going to check my clutches what should be my settings on the clutch? I'm taking the care apart for inspection and cleaning thanks for the help guys.
Old 11-03-2008, 01:07 PM   #10237
Rick Vessell's Avatar
Revo,
Red shoe, Orion spring, 0.4 preload, 0.5 gap, 0.1 endplay, both slugs in the flyweights.
Socko
Rick Vessell is offline   Reply With Quote
Old 11-03-2008, 03:13 PM   #10238
Sp Racer's Avatar
Originally Posted by JonnySocko View Post
Revo,
Socko
Same setup as I use !....
Hey Socko, you tried the new flyweight setup?.....I'm using it at the moment, big improvement...
p.s. got some info on our Jaco's
Old 11-03-2008, 10:21 PM   #10239
revo523's Avatar
Well guys i took the car apart and i found some binding at the rear and got that fix and changed the oil in the shocks to 50 front and rear and i changed the diff oil to 50k in the front and 10k in the rear fixed my droop and a couple of other things oh and the clutch i made it less aggresive lets see how it handles this weekend. thanks for yall help!
Old 11-04-2008, 12:24 AM   #10240
freestyles's Avatar
Trader Rating: 14 (100%+)
Hey louis what's the new flyweight set up?
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 11-04-2008, 02:55 AM   #10241
Sp Racer's Avatar
The latest batch of G4RS come with a different version of the UFO2 clutch, it is more like the older "push type" clutch ( just like a Kyosho 3D clutch with the 3 flyweights, does away with that "heavy" aluminum housing )
Here are the Teflon version of the same flyweights http://www.kfactoryracing.com/produc...33-8&pageNum=1
At the moment, I am using these with the weight in ( only 1 hole in these ) with the red shoe, crf spring and the same gaps as socko.
No more uneven wear and the shoes seem to last longer
Old 11-04-2008, 08:10 AM   #10242
revo523's Avatar
hey guys i order a new g4js since all im doing is parking lot racing but my question is where can i buy the specific battery pack for the car thanks
Old 11-04-2008, 11:37 AM   #10243
I would think;
www.wolfhobbies.com
www.rcmanufactory.com
One of them should be able to sort you out.
I hope your testing goes well
British Menace
Old 11-04-2008, 03:56 PM   #10244
revo523's Avatar
Originally Posted by British Menace View Post
I would think;
www.wolfhobbies.com
British Menace
Yeah i cant wait to test the car out thanks for the help.
Old 11-04-2008, 04:08 PM   #10245
revo523's Avatar
sorry for all the questions but is this the one i need?http://www.wolfhobbies.com/Batteries...t_Battery.html
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
