Old 10-29-2008, 07:09 AM   #10201
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by aussies1129 View Post
I weighed my RS and it came in at 1720 so 1800 is a tad on the heavy side, also there is a weight limit if you are going to run state and national evernts I think its 1700 correct me if I am wrong?
also is there any one running the RS that has issues with the wear out rate of the 2 speed clutch, howfar done have people gone with the screws that expand the shoes, how much of a gap are you getting at the joins on each half?does it not matter how far apart you go as long as you get the right fit into the housing?
cheers
your a tad on the light side Aussies. the legal limit is 1725g. weighed with transponder, tyres, no fuel. hint when to weigh, put some small tyres on. after a 20-30 min main, they will weigh the cars after the finish. so try to copy how you think the car will be. empty tank, and small tyres. if your around 1720, you should add weight where you think you need it. try to get it around 1730-35 incase some weight falls off possibly due to an accident. so to add 10 grams, use 2 5gram stick on weight.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-29-2008, 07:36 AM   #10202
NitroWD's Avatar
cheers
yup, 1.8kg is heavy!
my RS weighs about 1730g.
regarding the 2speed clutch shoe; even after i expand the shoes by using the screws; it'll close up again after a few runs.
what i do is to use a small shim/washer inbetween the shoes each side (through the engagement adjustment screw) to space out the to the limit i wanted.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 10-29-2008, 07:53 AM   #10203
freestyles's Avatar
Trader Rating: 14 (100%+)
cheers
They say not to let the shoes seperate when tightening the grub screw. Not sure why but it probably has something to do with the timming of when the shoes actually engage the hub.........maybe
How could i shave some weight off?? Everything is carbon, plastic or light weight alluminium, i even bought the light weight foam bumper as i thought it was going to be heavy when i was building it. The only thing i can think of is to loose the 4mm chassis for a 3mm and then hopefully i should be spot on.
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 10-29-2008, 08:17 AM   #10204
Pattojnr's Avatar
here are some jenny craig tips.
if you run a spool, get the lightweight K factory spool. this can shave 15 grams and lighter rotation. titanium screws, go lipo, a chassis change i think was only a 20 gram difference. you will get mor from the spool and the lipo. you can shave 15 grams a servo by using low profile ones. you can trim the rear diff pulley a bit from the edge, there are also lightweight out drives from kfactory, but do be aware, they arent as strong. all this and it would be possible to get them under 1700G. then it is possible to add the weight where needed. use a tweak station with a level on it. once centered, then add weight to get both front and rear perfectly balanced left to right. if you inderstand that. these are the advantages of getting the car as light as possible.
Serpent - Walter RC
Old 10-29-2008, 09:17 AM   #10205
ALG
Default weight
Hi guys,
My car weight 1744grs, with medium size tires. I know Im on the edge of a clift with one leg on the air and the other on a bannana peel.
I have Futaba 9451 on steering and mini 9650 on throttle. NO problem with the mini servo working, you can even use the 9551 low profile servo on the steering to save some more weight.
Im using the original TM barrety pack and also have the 8 titanium pillow balls.
I have check the weight of the bodies, Central Civic and Protoform Stratus, and the Central is 12 grs more.
Remeber HAVE FUN!!!
ALG
ALG is offline   Reply With Quote
Old 10-29-2008, 10:11 AM   #10206
Nitro-Racer*'s Avatar
hey about the weight limit isnt it 1725 grams with transponder, tyres, no fuel, body and body clips on??
Nitro-Racer* is offline   Reply With Quote
Old 10-29-2008, 10:24 AM   #10207
ALG
YES, after racing with NO fuel.
Old 10-29-2008, 04:47 PM   #10208
freestyles's Avatar
Maybe i shouldn't have put so many coats of paint on my body
Old 10-30-2008, 12:31 AM   #10209
keavze's Avatar
i remember weighing the RS chassis to be about 15-20g lighter than a 3mm S chassis.
so if u got the 4mm G4+ chassis; it might be 25-30g heavier than the RS chassis.
low profile servos and lipo are great ways to reduce weight.
try to have minimum coats of paint and stickers too!
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 10-30-2008, 01:54 AM   #10210
NitroWD's Avatar
i've been 'spacing' out the shoes with shim with no issue encountered.
shifting is still as what i wanted.
Old 10-30-2008, 02:58 AM   #10211
freestyles's Avatar
I don't think i will be going to go li-po any time soon as the cost involved to get new chargers, balancers, regulators etc. is just to much for me at the moment
Pattojnr, what's this weight saving mod with the rear brake pulley. Would it really save me that much?
How much roughly have you guys spent on your low profile servo's?? Once again the cost will be the major factor for me so i hope they aren't to expensive.
Old 10-30-2008, 07:53 AM   #10212
keavze's Avatar
i would recommand futaba's 9551 low profile servos...
about 45g. price? not sure on yr side.
Old 10-30-2008, 08:18 AM   #10213
ALG
http://www3.towerhobbies.com/cgi-bin...&I=LXRWS8&P=ML
hope it helps
ALG
Old 10-30-2008, 08:20 AM   #10214
ALG
http://www.amainhobbies.com/product_...ducts_id/21633
this is on the budget mind
Old 10-30-2008, 01:34 PM   #10215
afm
afm's Avatar
Default G4 + EVO
New kid on the block.... Check it out
http://www.teammagic.com.tw/en/profr...2089&pageNum=1
A combination of the G4+ RS and parts of the WC upgrade
AFM
afm is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
