Old 04-27-2006, 07:00 PM   #1006
YBSLOW's Avatar
Default 4 - Sale
Hey everybody,
If you are looking for G4 stuff I have listed on ebay a RD Logics Mongoose with almost every option installed as well as several hundred dollars worth of spares for a low starting bid of $125 bucks on ebay with no reserve.
Check it,
Brad T
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 04-27-2006, 10:11 PM   #1007
nitro_racer23's Avatar
I saw in a previous post about the final drive ratio i just wanted to know how to calculate this.
nitro_racer23 is offline   Reply With Quote
Old 04-28-2006, 05:03 AM   #1008
NiMo's Avatar
Front:
large front diff pulley divided by small front diff pulley multiplied by large side belt pulley divided by small side belt pulley miltiplied by spur gear divided by pinion gear equals final drive ration for front axle
32/18*27/19*46/24=4.842
Rear:
large rear pulley divided by small rear pulley multiplied by spur gear divide by pinion gear
Multiply final drive ratios on each axle by the tyre diameter on that axle to get the split size required if running overdrive
It's how I do it anyway
NiMo is offline   Reply With Quote
Old 04-28-2006, 06:30 AM   #1009
Thanks NiMo i dont run overdrive on the front wheels i always run the front 2-3 mm smaller than the rear so i have had dad help with calculateing this.
Cheers
Chris
Old 04-30-2006, 06:16 AM   #1010
g4-racing.de's Avatar
Originally Posted by g4-racing.de
hello
can someone tell me why do you bore the holes in the shocks to 1.3 mm.
Original they have 0.9
Marc
I have do this...to 1,2mm 2 Hole...it feels great
I will test it at the next weekend,this weekend there is ro many rain
Marc
KM-racing H-K1/Novarossi/AXE-Rossi Engines/Robitronic germany
g4-racing.de is offline   Reply With Quote
Old 04-30-2006, 07:16 AM   #1011
Default Generic Gear Ratio, Overdrive, Rollout and Speed Calculator
has someone made a Gear Ratio, Overdrive, Rollout and Speed Calculator
for the G4S??
Thanks for all
Marc
Old 04-30-2006, 07:32 AM   #1012
hey marc,
if you ask the right men, you can get one
dieter
4racer is offline   Reply With Quote
Old 04-30-2006, 09:15 AM   #1013
muppet racing's Avatar
hi Marc,
have a look here :
http://www.gearmachine.net/
for speed calculator, just make sure your faster than everyone else
muppet racing is offline   Reply With Quote
Old 04-30-2006, 10:10 AM   #1014
Roki's Avatar
Has anybody tried the K-Factory UFO Push Type Clutch Shoes RED k1497-6 ( http://www.kfactoryracing.com/prolis...me=%20k1497-6). I would be interested to see what effect this has on the clutch.
The spring tension seems super critical on the the new UFO clutch. It would be nice to get a bit of slip from the shoe so that you are not right on the threashold of total slip.Its seems any more than .8 tension and your springbound.
Roki is offline   Reply With Quote
Old 04-30-2006, 05:29 PM   #1015
Regional Moderator
daniz24's Avatar
Anyone have problem with this UFO clutch? After the engine has warmed up, and a couple of blip then I try to raise the throttle (the car is still on starter box)
10% engine rev, tires still not moving
20% tires start moving slowly
30% tires moving faster
40% engine rev higher but suddenly the tires start slowing and then stop
5o% engine rev higher tires start to moving again
I try every suggested clutch setup and it seems like no grip at all. My driver is kinda frustrated, because the car handling is already perfect but the UFO clutch performance is far beyond expectation. Removing some material from the lower suspension arm turns out can help the car on bumpy track.
daniz24 is offline   Reply With Quote
Old 04-30-2006, 06:24 PM   #1016
Car Breaker's Avatar
Don't have that sort of problem before, I am either too late engagement or "autorun" are you sure your flywheel pin is OK and everything went in smoothly?
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 04-30-2006, 07:09 PM   #1017
Regional Moderator
daniz24's Avatar
Yes, everything is well assembled.
Old 04-30-2006, 08:22 PM   #1018
BimmerDriver's Avatar
It might help to know what clutch spring you are using and how many threads are showing above the clutch nut.
BimmerDriver is offline   Reply With Quote
Old 04-30-2006, 10:06 PM   #1019
Regional Moderator
daniz24's Avatar
spring red, orange, yellow. tension 0.3-0.6mm. with and without weight. 0.4-0.6mm gap. I think almost all setup we already try.
Old 05-01-2006, 01:15 AM   #1020
wow, that is beyond my ability to diagnosis through knowledge+imagining the situation, wish more expert person can help over internet, personally I will have to take a look if I have to check the problem.
please anyone?
Xray X12 2015
ARC R10 ATS
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
