Old 10-10-2008, 01:16 PM   #10111
can anyone help me with the shocks on the g4+. I put them together like the manual said and they are way taller than they are supposed to be. my ride hight is around 10 mm! I can't figure out how to bring it down.
nc racer is offline   Reply With Quote
Old 10-10-2008, 01:31 PM   #10112
sorry, I should have mentioned that my shock length when assembled is a little longer than 2.5 inches. i've tried adjusting the collars all the way down and it only takes it down to about 2.4 inches.
Old 10-10-2008, 02:45 PM   #10113
Trader Rating: 16 (100%+)
Originally Posted by qcrc View Post
Blee, maybe the TS1 but also its big brother, the 353! I gotta have some big power for the Nats next spring.
I knew you had your eye on my BLEE mod 353....
Old 10-10-2008, 02:51 PM   #10114
Only way to make your car to have 10mm ride height even you have dialed the collet all the way down is you are using the wrong spring (longer springs)...are you using the TM G4 springs..? Or others like serpent or whatever..? Or you have the spring collet installed the wrong side? Or mounting the shocks at the wrong holes?
I am not 100%, and I don't have G4+, only have G4RS. I have the TM springs sets and I have not try using other brand springs...but on my E4 car...their springs are 1/4" shorter then the typical TC car's spring like AE or Xray...so, check that.
10mm ride height is crazy...LOL
Old 10-10-2008, 04:05 PM   #10115
nope, i have the team magic springs that came in the kit (1.7's on back, 1.9's on front). it's in the proper mounting holes according to the stock set up sheet, it's just that the shock lengths are way longer than they should be according to the set up sheet. it's like i'm driving a frikken rally car :-)
help!!!!!1
Old 10-10-2008, 05:24 PM   #10116
aussies1129's Avatar
Trader Rating: 74 (100%+)
help!!!!!1
all I can recommend is to strip everything and rebuild, double check everything as its probably a simple mistake in building
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 10-11-2008, 12:16 PM   #10117
razzor's Avatar
Post a pic and we could identify a problem.
The adjuster on the shock could be upside down and are you using teh original spring seat and ball end ???
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 10-11-2008, 12:17 PM   #10118
razzor's Avatar
Originally Posted by blee View Post
Nova 2601 is too old and replaced by Nova 2630 for very long time. Skyline is not necessary to mention, unless you are as good as J-Lin.
Both Nova EFRA 2630 and Shark EFRA2625 are very good........ hard to tell which one performance is better.... however I have these pipes.
One thing I am sure, shark pipe is much stronger and durable than Nova. Of course if you driving technique is good and never hit the wall, using Nova would not have problem.
Interesting !!
Ill look into that.
at teh moment i use the Skyline VR12+ and i have the 2601 as a back up and they always run great.
I tried the TeamMagic Missile pipe and it was a real disspointment although it is a good looking and strong pipe.
Casterracing ZX1.5R
Old 10-11-2008, 02:57 PM   #10119
freestyles's Avatar
Trader Rating: 14 (100%+)
Originally Posted by razzor View Post
Interesting !!
Ill look into that.
The missile is a great looking pipe, i've only tried the 6mm version but wasn't good enough at the time to notice any difference in power delivery.
I've heard a lot of other people, like yourself, don't like the missile pipes but just wondering if anyone has tried the 5mm.
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 10-11-2008, 07:24 PM   #10120
keavze's Avatar
Default rear lifted up
hi guys,
just checking is it possible that my car's rear lifted up by itself when i race down the straights? (towards 3/4 of the length).
i seems to have noticed that my rear lifted up slightly; maybe when i let off the gas?
any issues here?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 10-11-2008, 08:39 PM   #10121
jameslow's Avatar
Originally Posted by keavze View Post
hi guys,
any issues here?
you sure is ur car lift up bec of speed? bec i find that the track we racing, towards the end of the straight the road is uneven! Which might cause ur car to lift up!
jameslow is offline   Reply With Quote
Old 10-13-2008, 05:13 AM   #10122
hi guys,
any issues here?
could it be a rear spoiler issue, the only thing I could think of is that your rear wing could have a slight upward angle maybe its angle has changed caused by a crash?
cheers
H.E.I AUSTRALIA
Old 10-13-2008, 02:41 PM   #10123
Sp Racer's Avatar
hi guys,
any issues here?
Check your diff outdrives - could be notched and binding up your suspension under power
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 10-13-2008, 04:50 PM   #10124
blis's Avatar
Default G4+ Shocks
I had my fun trying to dial in the suspension on my G4+.
1) Bought the softer srpings the ones that come with G4+ 1.7 etc are too hard for my liking, and I get no dropp using these srpings. The car just sits ontop of them
2) Bleed the g4+ shock with shock shaft all the way up and do not overtighten the cap or the shock will lock up on you.
3) Using a lower roll center and angled my shocks out to form a longer hypoteneuse.
4) Check your roll bars and ball joints, ensure they arent sticky. All my joints were too tight and I had to ream them out to loosen up my suspension
Cheers.
blis is offline   Reply With Quote
Old 10-13-2008, 05:07 PM   #10125
blis's Avatar
Default Differences between G4+ and g5RS
1) G4+ Chassis plate is 4mm lightened, not 3mm and stiffer
2) Transmission axle uses a screw, not C clip (love it)
3) Brake disc and hub are upgraded. Does not use the two prong hub rather a chamfered barrel for the disc mounting.
4) Full Carbon fibre front top plate and alloy plate with G4+ logo
5) Composite stiffening brackets both sides
6) Full JAP raced bearings
7) Carbon top plate stiffener
8) G4+ shocks, not the standard.
9) G4+ has Different fuel tank and Handle
10) Hex screws all round. (Unsure if RS is wood screws
11) Oneway lockable front spool
12) Its sexier!!!
Add the WC nulkhead kit to a g4+ and you will hopped up to the max with KFacroy. Short of composite ball joints and a few other minor upgrades, g5+ with WC kit is probably the best TM setup available.
Cheers.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
