Old 04-26-2006, 06:59 AM   #991
g4-racing.de's Avatar
hello
can someone tell me why do you bore the holes in the shocks to 1.3 mm.
Original they have 0.9
Why do you use the 3 hole ons???
And you all use asso oil
In Germany asso is not good to buy.........
We have Robitronic at most or LRP.
who knows differentiated ???
Marc
KM-racing H-K1/Novarossi/AXE-Rossi Engines/Robitronic germany
g4-racing.de is offline   Reply With Quote
Old 04-26-2006, 08:00 AM   #992
NiMo's Avatar
Originally Posted by g4-racing.de
hello
Marc
In the UK we drill them to 1.2mm due to the colder more humid climate but I still only use 2 hole pistons
NiMo is offline   Reply With Quote
Old 04-26-2006, 09:43 AM   #993
muppet racing's Avatar
hi Marc,
i have always done this in all my cars, i just like the feel that this combination gives. you can run a fairly heavy oil, with decent damping but because of the good size holes you shouldnt get any 'pack'.
you can replicate with any oil but it will just depend on how they rate there oil.
on www.3hobby.net there is some comparison data,
http://www.3hobby.net/modules.php?na...howpage&pid=52
hope this helps.
muppet racing is offline   Reply With Quote
Old 04-27-2006, 03:20 AM   #994
Z00M's Avatar
Trader Rating: 15 (100%+)
Well done Darren! 2 wins from 2 starts in the championship is it? That Aussie sunshine must have been really good for you.
Thanks for the package you sent, it's mint! Helped me with building the new car!
Cheers,
Mike.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 04-27-2006, 04:32 AM   #995
Cheers Zoom, yep 2 from 2, but i doubt the serpent team will like that, and it will be probably get tougher !
Old 04-27-2006, 06:36 AM   #996
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Hi everyone
I just built my G4S and i want to put the Lola body on it. Do i need the convertion bumper or can i use the stock foam bumper? I also noticed that the front shock tower hits the body and doesnt allow the body to come all the way down. Any suggestion? I drilled the spots that were marked on the body. Is that my problem?
nitrobeast is offline   Reply With Quote
Old 04-27-2006, 07:14 AM   #997
The conversion bumper places the body in the correct position and also has a shorter shock tower. The body can be fitted with the stock bumper but you hve to trim the foam quite a bit and you will need to cut down the front shock tower so only the lower shock tower holes remain to mount the shocks to.
Motorman2 is offline   Reply With Quote
Old 04-27-2006, 09:51 AM   #998
nitrobeast's Avatar
http://www.kfactoryracing.com/produc...1486&pageNum=1
Is the shock tower the part at the top of the picture? If yes it is carbon or plastic?
Thanks for your help.
Old 04-27-2006, 10:03 AM   #999
4F1Racing's Avatar
Nitro Beast,
That piece is body post mount for the smaller body post. This is just the bumper kit and that is all that is needed to put on the VDS bodies. Everything else remains the same on your car.
Sam
4F1Racing is offline   Reply With Quote
Old 04-27-2006, 10:07 AM   #1000
4F1Racing's Avatar
Nitro Beast,
Looked at pic again and that is the shorter shock tower that is needed for that sloping front. It is pastic
Old 04-27-2006, 10:07 AM   #1001
4F1Racing's Avatar
plastic....
Old 04-27-2006, 11:29 AM   #1002
nitrobeast's Avatar
Originally Posted by sfelish
Nitro Beast,
Thanks. I guess i could fit the body on with some mods to what i have but the best bet is to spend the $15 and get the conversion set. Like that if i ever go to a normal cover i can swap everything out again.
Thanks again.
nitrobeast
Old 04-27-2006, 12:10 PM   #1003
4F1Racing's Avatar
Nitro beast - I sent pm
Old 04-27-2006, 02:42 PM   #1004
mtveten's Avatar
Trader Rating: 27 (100%+)
Can someone please post a spring rate chart fhe G4 spring set?
Thanks,
Mark
mtveten is offline   Reply With Quote
Old 04-27-2006, 02:49 PM   #1005
afm
afm's Avatar
Thanks,
Mark
tm gray 1.9mm 52.0 lb/in
tm orange 1.8mm 41.5 lb/in
tm blue 1.7mm 31.0 lb/in
tm aqua 1.6mm 26.0 lb/in
tm silver kit stock 26.0 lb/in
tm purple 1.5mm 20.0 lb/in
tm pink 1.4mm 17.0 lb/in
tm fuccia 1.3mm 13.5 lb/in
tm green 1.2mm 11.0 lb/in
AFM
afm is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
