Old 09-24-2008, 04:21 PM   #9991
British Menace's Avatar
Originally Posted by British Menace View Post
Hey freestyles,
I have an 'S' and use the RS rear sway bar.
All you need are the Baulkheads and the rear arms from the RS for it to work.
Natrually you will need to have the Sway bar and fittings.
On the clutch setting up. Just ensure when all is assembled that you have "some" end play to your clutch bell! Some run more then others. But make sure there is "some" movement!! Otherwise you will blow up your thrust bearing VERY quickly!!
British Menace
Shoot.. Forgot. You'll also need to make sure you use the RS Carbon Brake bracket as the "S" one will not allow for the RS sway bar........sorry
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 09-25-2008, 04:32 AM   #9992
razzor's Avatar
A good alternative to the RS stabiliser is to do the Mugen sway bar mod.
Its simple and you wont need to buy bulkheads etc.. just Mugen 2.2/2.3/2.4 sway bars and the ball ends and balls to mount it.
Have a look at post #5635 and part numbers on post #3742 of the G4S thread. I have bumped it up
We just file a slot in teh bulkheads for the bar to locate and it works very well.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-25-2008, 04:32 AM   #9993
razzor's Avatar
Casterracing ZX1.5R
Old 09-25-2008, 05:06 AM   #9994
aussies1129's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Solara View Post
Yes...it does work on the front. And front only...the WC front kit use the G4RS lower bulkhead and G4RS lower front bumper plate, that means it will fit the WC chassis AND/OR the RS chassis.
hey cheers for that I will try the front first and hopefully later upgrade to the WC rear and chassis.
thanks!
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 09-25-2008, 08:58 AM   #9995
Trader Rating: 16 (100%+)
thanks!
Your order is on the way...
Anyhow, yeah, you must have the WC upgrade, make a hugh different.
Old 09-25-2008, 12:23 PM   #9996
ALG
This is a GREAT mod, I have it, and I think that the 2.3 is a all aound setting.
I will try to have some pictures of my car.
Have you tried to shave some material from the front blade, to made it softer? It also work great.
Have fun
ALG
ALG is offline   Reply With Quote
Old 09-25-2008, 04:02 PM   #9997
freestyles's Avatar
Trader Rating: 14 (100%+)
Originally Posted by asil View Post
congrats to all TM crew in US
a question about speedshot.. earlier times in this tread we were talking about stiffening speedshot bracket by JB weld... my speedshot just arrived and I saw carbon stiffeners in the holes??? are these carbon parts new or it was always there?? here's the photo;
thanks in advance...
Have you got a part number for that speedshot bracket it looks sweet. I just got the new speedshot bulkheads but don't have the brackets to fit to it so now i can't finish my kit
Also that other part looks like it's made of nylon, i thought it's made of carbon fibre?
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 09-25-2008, 04:04 PM   #9998
I thought it is the same as the G4RS front end...the carbon fiber piece and the bracket.
Old 09-25-2008, 06:19 PM   #9999
NitroWD's Avatar
the speedshot bracket is the same; however there's 2 types...
the RS is using nylon while the G4+ is using alum.
the carbon fibre part is the speedshot X-plate.
same for RS and G4+ but JS using nylon.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 09-25-2008, 08:27 PM   #10000
Ok...got it, freestyles question was about the bracket, which is the same as the RS....so its all good.
Old 09-25-2008, 10:02 PM   #10001
casimirsa's Avatar
Like Razzor said! The G4S is still well alive!
He took 1st B-main with a G4S in our last Nationals. on the TRAP track (www.trap.co.za) in Pretoria South Africa!
Second place was was also a G4S if my memory is not to bad
Congrats
"Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it."
TM G4S (ED), TM G4S,SERPENT M2+835+960FD, MUGEN SEIKI MRX4-X, MUGEN SEIKI MRX4 (WORLDS CHASSIS), MUGEN SEIKI MTX4, MUGEN SEIKI MBX5T, HPI PRO4, TAMIYA, PALMARIS, RB C5+C5 RODY+V12 RODY, NOVAROSSI, JP, AXE ROSSI, MEGA, NOVAMEGA KHM, KO PROPO, HITEC, GRP, UFRA, ROBITRONICS, SJ, LRP
casimirsa is offline   Reply With Quote
Old 09-26-2008, 01:05 AM   #10002
blee's Avatar
Wink
G4+ is same as G4RS, not AL. but nylon.
See detail here.
blee is offline   Reply With Quote
Old 09-26-2008, 01:30 AM   #10003
NitroWD's Avatar
oops, i thought G4+ is using K14124 set...
Old 09-26-2008, 01:31 AM   #10004
razzor's Avatar
Here is pics of mine with a 2.2 bar but am going up to a 2.4 bar.
Casterracing ZX1.5R
Old 09-26-2008, 01:52 AM   #10005
freestyles's Avatar
Bugger i just bought the rear roll bar set up for $20 but if it doesn't work out some how i might try it. What's the part number for that front alloy bulk head brace, the one the top arms are joined to and the carbon brace under it.
Is that called the "speedshot bulkhead brace", pardon my stupid question i'm only catching up to the G4s now
I just ordered the speed shot do i need that alloy piece aswell or will it come with it? I'm sure there will be more stupid questions comming as i'm trying to put together a 1/3 G4s, 1/3 G4rs and 1/3 G4+ so it will be interesting how it turns out. I'm hoping it will be the "super G4"
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
