Old 09-17-2008, 11:33 AM   #9961
Trader Rating: 16 (100%+)
Originally Posted by Speyederjedi View Post
Other than Wolf Hobbies where are some of you TM racers getting your parts from here in the U.S.??? I have a G4RS and need a shop to purchase parts from.
Regards,
Speyederjedi
We can do it....just shoot me your list via PM.
Old 09-17-2008, 07:38 PM   #9962
mytoda5's Avatar
Originally Posted by blee View Post
Bro., the engine on solara G4 is not same as yours.......... since the engine has been modified by me (as I show you earlier).
hehehe.....same heatsink..and body..but without blee secret ingredient...
btw solara..your kit give me good idea how to save our receiver...yea..from hardcore pitman...hehehe
dsm n 2.4ghz....kalu ariel panjang sejengkal..jangan diduga track 400m..
mytoda5 is offline   Reply With Quote
Old 09-17-2008, 08:13 PM   #9963
rcracer38's Avatar
Send a message via Yahoo to rcracer38 Send a message via Skype™ to rcracer38
WINNERS CIRCLE R/C HAS ALOT OF THE TM PARTS OUT OF CALI
rcracer38 is offline   Reply With Quote
Old 09-18-2008, 02:52 PM   #9964
freestyles's Avatar
Trader Rating: 14 (100%+)
I just tweaked my G4s chassis the other day and so i just bought the G4+ chassis (4mm). I've heard it's to rigid, is this true?
If so does anyone have any set-up tips to compensate for it?
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 09-19-2008, 12:28 AM   #9965
freestyles's Avatar
Originally Posted by razzor View Post
Down load the Serpent drive calc program from the Serpent website and just change all the pulley values to get your answer.
If not mistaken the 32 will not be a good idea.
You can buy the 30 tooth ally pully and use it with the Kfactory light weight spool or on a diff.
Do a search in the G4S thread, there is also a excell spread sheet the guys put together that can help with ratios and overdrive.
Thanks mate i just ordered the 30t front pulley, Do you know the web address for serpent?
Old 09-19-2008, 04:40 AM   #9966
razzor's Avatar
http://www.dmcc-rc.co.za/downloads/DriveCalc.zip
like i said just substitute pulley numbers.
G4S stock:
32t front diff
18t front inner
27t front outer
19t rear outer
19t Brake
48t rear diff
1st gear pinion
18t/19t/20t
1st gear spur
50t/51t/52t
2nd gear pinion
23t/24t/25t
2nd gear spur
45t/46t/47t
G4S ED/G4+/G4RS/G4JS
30t front diff
20t front inner
27t front outer
19t rear outer
21t Brake
46t rear diff
1st gear pinion
15t/16t/17t
1st gear spur
50t/51t/52t
2nd gear pinion
20t/21t/22t
2nd gear spur
45t/46t/47t
http://www.kfactoryracing.com/produc...4122&pageNum=1
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-19-2008, 11:04 PM   #9967
freestyles's Avatar
G4S stock:
32t front diff
18t front inner
27t front outer
19t rear outer
19t Brake
48t rear diff
1st gear pinion
18t/19t/20t
1st gear spur
50t/51t/52t
2nd gear pinion
23t/24t/25t
2nd gear spur
45t/46t/47t
30t front diff
20t front inner
27t front outer
19t rear outer
21t Brake
46t rear diff
1st gear pinion
15t/16t/17t
1st gear spur
50t/51t/52t
2nd gear pinion
20t/21t/22t
2nd gear spur
45t/46t/47t
That's a great help thanks razzor. Good that you can see any change when you play around with pinions and spurs sizes straight away like that.
Old 09-20-2008, 12:48 AM   #9968
NitroWD's Avatar
Default UFO2 clutch shoe wear
hi guys,
those using UFO2 clutch set; do you notice that the shoe wears with a 'step'? it happens as the shoe is of same diameter size as the bell and unlike the UFO1 shoe where it's smaller than the bell and thus the shoe will go 'into' the bell...
any of UFO2 users find that as the shoe wears; the clutch will tend to slip more? reason being the shoe wears faster on the inner (where it goes into the bell) and wears slower at the outer edge.
hope you understand what i'm trying to say...
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 09-20-2008, 01:30 AM   #9969
aussies1129's Avatar
Trader Rating: 74 (100%+)
Originally Posted by NitroWD View Post
hi guys,
what shoe are you using as there is a bit of a range now when it comes to how hard the material is used I have used the new brown shoe but had more success with the white for some reason maybe less slip?I have not really noticed what you have described probably cause I change and or cycle my shoes regularly.
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 09-20-2008, 03:34 AM   #9970
razzor's Avatar
The clutch setup gets more critical when you use the harder shoes as tehy slip more but can overheat and get glazed easilly if you just have that extra bit of spring tension.
I prefer to use the standard black shoe because it just works more consistent over a wider setup window.
The red shoes slip far too much but i havent tried the white shoes.
A buddy modified the Serpent yellow shoe and it works very well too.
Casterracing ZX1.5R
Old 09-20-2008, 06:51 AM   #9971
freestyles's Avatar
cheers
I know this sounds silly question but how do you know if your clutch is slipping, can you hear it?
Old 09-20-2008, 06:59 AM   #9972
clutch slip=your clutch simply needs a higher rpm to engage the higher the rpm needed the more slippage you have. give the white shoes a go I know they are softer and are supposably for high grip tracks but I find they grab very well and get the power down consistantly.
cheers
H.E.I AUSTRALIA
Old 09-20-2008, 08:05 AM   #9973
NitroWD's Avatar
cheers
how often do u chg the shoes?
anyway i've attached a pic showing what i mean...
this 'problem' doesn't happen to UFO1.
Old 09-20-2008, 08:09 AM   #9974
NitroWD's Avatar
ya...clutch slipping sure sounds different.
in order to confirm; check the inner of yr clutch bell where the shoe hits; if it's shiny it's slipping!
it should still have the clutch bell color if it's not slipping.
Old 09-20-2008, 11:30 AM   #9975
asil's Avatar
Send a message via MSN to asil
I've been using UFO2 for a while and never had this problem.. I'm using white shoe..
Asil
asil is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
