Old 09-12-2008, 04:22 AM   #9916
razzor's Avatar
Originally Posted by Omarko View Post
I agree with that but also get the 4mm chassiss .. the stock one is too flexible imo
But leave alone if your track hasnt got good traction !!!
The stiffer setup would suit treated high bite tracks.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-12-2008, 11:08 AM   #9917
Trader Rating: 16 (100%+)
Thats why I've got the WC kit.....got everything take care at once.
Old 09-13-2008, 02:44 PM   #9918
blee's Avatar
Thumbs up
Brother, you should have all new stuff today....... keep eyes on Postman rings your door bell.
blee is offline   Reply With Quote
Old 09-13-2008, 08:31 PM   #9919
keavze's Avatar
a quick qn:
lighter clutch throw-out weights = higher clutch spring tension?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 09-13-2008, 10:33 PM   #9920
blee's Avatar
Thumbs up
UFO 2
Old 09-13-2008, 11:06 PM   #9921
Omarko's Avatar
it happened again yesterday during the race ...
why do these keep cracking like that ? anyone else have the same problem?
Omarko is offline   Reply With Quote
Old 09-14-2008, 12:02 AM   #9922
Sp Racer's Avatar
This is the same problem everyone using the flying wing arms has in a big crash, mainly the rears - in the latest kits TM now use a longer ball stud.
Up until now, I was using super gluing the balls in place ( helps a lot)
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 09-14-2008, 12:26 AM   #9923
Pattojnr's Avatar
Trader Rating: 19 (100%+)
when i ran the car, i used to use the G4S front arms, they are much stronger. but was still left wondering after a minor incidcent,wether the rear arms were ok. by using the G4S arms, the castor remains the same, but you wont be able to use the shorter front wheelbase unless you shorten the length down 2mm . i used the Mugen shock ends also, but this still didnt fix the cracking issue.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-14-2008, 01:37 AM   #9924
Omarko's Avatar
yeah I superglued the new ones in now ....
can the longer ball studs be bought separately? if yes, whats the part no ?
cheers
Old 09-14-2008, 02:11 AM   #9925
Sp Racer's Avatar
longer ball ends for the arms - part#115029
Old 09-14-2008, 05:34 AM   #9926
gansei's Avatar
G4RS Arms are TOO WEAK!!!
i am using G4S old arms.. of course, you can use 2mm shorten..
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 09-14-2008, 05:48 AM   #9927
aussies1129's Avatar
Trader Rating: 74 (100%+)
hey Alex how are they cracking are you hiting something hard ??I have never had an issue with my front arms i am not sure if i use the longer thread studs but I have smashed and flipped my car in a race every now and then but i have only cracked a front hub, could there be an issue with your down travel screw setting??there must be something thats creating pressure and makes the bottom of the shock pull out the ball stud like that??cause the amount of times you have had it happen dosent seem right?
cheers
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 09-14-2008, 09:16 AM   #9928
razzor's Avatar
Longer ball studs will solve the hassle even on the G4S but more so on teh flying wing arms as there is less material around the mounting hole.
This is rather a common problem.
I had the std ones pull out on teh G4S often.
Casterracing ZX1.5R
Old 09-14-2008, 06:18 PM   #9929
NitroWD's Avatar
how much longer is it than the usual one?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 09-14-2008, 09:13 PM   #9930
Trader Rating: 55 (100%+)
Anybody have a G4RS for sale? I'm in the market, so just LMK. Thanks.
WatchOut is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
