Old 09-07-2008, 11:36 AM   #9886
razzor's Avatar
I tap them with a screw driver on the back.
But yes takes some patience.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-07-2008, 02:01 PM   #9887
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
hi guys...
where are you buying cars and a STEADY supply of parts in the US.....all I get is mesaages stating TM does not have a US distributor...and TM's OWN site says wolf hobbies in CA.....with only a PO box for an address....not good...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-07-2008, 02:47 PM   #9888
Omarko's Avatar
hey guys , I need some advice ...
at EVERY club race I seem to have problems with the lower arms - fronts or rears ... the hole where the ball screw (the one that holds shock cups) goes in breaks / cracks ... its so annoying ...
I have gone through so mane lower arms that I lost count by now...
why is this happening? It almost seems like its a very soft material ...
Omarko is offline   Reply With Quote
Old 09-07-2008, 03:21 PM   #9889
Sp Racer's Avatar
I've only had this problem twice after a big, big shunt ( lots of air time )
The new kits ( latest batch ) has a longer ball stud that screws into the arm - the part # is 115029.
Before these came out, I would super glue the ball into the arm - it helps, but try and get yourself these.
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 09-07-2008, 04:07 PM   #9890
charlesd's Avatar
Quick question. Is there any way to modify the front one-way to make a solid axle? I have a few oneways i'm not using.
charlesd is offline   Reply With Quote
Old 09-07-2008, 04:16 PM   #9891
Omarko's Avatar
thanks for the tip .. I'll check it out ... do Kfactory make arms for the G4RS ? maybe from some stronger material?
The problem I am having is NOT the ball studs coming out but them cracking the arm/hole .... I'll post few pics tonight to illustrate ...
I was thinking of putting a STRONG cable tie around the two hole bit in hopes to help sturdying that whole section ... dont know ... its just annoying loosing shocks and springs ... costs a fortune!
Old 09-07-2008, 04:42 PM   #9892
Teehomo's Avatar
Trader Rating: 24 (100%+)
Omarko - you could try boiling the arms for 10 minutes in hot water. Apparently this takes some of the brittleness out of the new arms. I gave it a go - it did not warp the arms at all nor did it makle them bind, but I sold the car before I had a chance to run it and see if it made a difference. It could be worth a try, along with a longer threaded ball stud as posted above.
Teehomo is offline   Reply With Quote
Old 09-07-2008, 04:52 PM   #9893
Omarko's Avatar
thanks for the tip, I might try that this week ....
btw what shock oils would u guys recommend to use ?
Old 09-08-2008, 01:49 AM   #9894
Sp Racer's Avatar
It depends on the size of your shock piston holes - we are running anywhere from 50 - 60wt oil with the kit RS shocks , but the pistons have been drilled out to 1.2mm.
Old 09-08-2008, 05:11 AM   #9895
aussies1129's Avatar
Trader Rating: 74 (100%+)
hey SP is that both front and rear at 1.2mm and is that one hole that is drilled?I drilled mine ages ago on my G4S and am wondering whats needed for the RS shocks?
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 09-08-2008, 01:37 PM   #9896
Sp Racer's Avatar
Both holes @ 1.2mm , F & R ( same as the K Factory shocks )
Old 09-08-2008, 02:41 PM   #9897
Omarko's Avatar
whats the Kfactory part number for these?
cheers
Old 09-08-2008, 03:14 PM   #9898
Sp Racer's Avatar
cheers
K1008
http://www.kfactoryracing.com/produc...1008&pageNum=2
Old 09-08-2008, 04:55 PM   #9899
afm
afm's Avatar
Originally Posted by fastharry View Post
hi guys...
Go to their web page www.wolfhobbies.com
AFM
afm is offline   Reply With Quote
Old 09-08-2008, 06:57 PM   #9900
Ya from what rctvlive.com said the g4 rtr is a great car. Wolf hobbies has them listed for $379 us. Anyone have experience with one?
Ginsu is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
