Old 09-01-2008, 07:14 PM   #9841
gansei's Avatar
Originally Posted by ALG View Post
Bander, what car was the black one? if was fast, very fast!!! he pass both of you and pull away!!
nice vid
Have fun
ALG
It was a MRX-4. But The MRX-4 Driver is not fast car.
He recorded Best Lap 16.2 sec.
But Other Top Driver(Evolva M3) recorded 15.3 sec.
I recorded 16.9 BestLap.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 09-02-2008, 01:24 AM   #9842
Omarko's Avatar
guys I need help!
I am installing the WC kit but I just noticed that the front left and right bulkhead bits are different to the ones in the pic / manual in the kit
see this pic:
see the original G4RS bit has the plasticky bit over the hole where the front diff goes ...
the one in the pic seems like there is nothing there ... of course, the top does not fit ... as there is now lag between the cover and the bulkhead
am I doing something wrong?
cheers
EDIT: is it supposed to come with the bulkhead? cause mine did not!!!!!!!!!
Omarko is offline   Reply With Quote
Old 09-02-2008, 02:09 AM   #9843
Sp Racer's Avatar
...just cut that plasticky bit off
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 09-02-2008, 04:02 AM   #9844
I left it on and just slid the diff under it and then screwed in onto the chassis. Makes it a little harder when i want to change the diff though
RB_Racer is offline   Reply With Quote
Old 09-02-2008, 04:26 AM   #9845
freestyles's Avatar
Trader Rating: 14 (100%+)
Just a quick question concerning my ED transmission in my G4's. If i changed the front 30t pulley to a 32t pulley how would that affect how it drives??? I want to use a K-factory spool that i have but the 30t pulley doesn't come off the multi-diff so i would have to use the 32t pulley that's on it. Every other pulley, pinion, spur gear will remain the same.
Also anyone got a part number for the K-factory bell crank that comes in the 'wc' kit???
I am also after an alluminium brake lever for the G4's, i've had no luck in the buy/trade/sell section so i will post here. Pm me with details. Thanks
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 09-02-2008, 05:03 AM   #9846
razzor's Avatar
Originally Posted by Omarko View Post
guys I need help!
see this pic:
cheers
That is excess from the mould so just trim it off with a hobby knife.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-02-2008, 05:13 AM   #9847
razzor's Avatar
Down load the Serpent drive calc program from the Serpent website and just change all the pulley values to get your answer.
If not mistaken the 32 will not be a good idea.
You can buy the 30 tooth ally pully and use it with the Kfactory light weight spool or on a diff.
Do a search in the G4S thread, there is also a excell spread sheet the guys put together that can help with ratios and overdrive.
Casterracing ZX1.5R
Old 09-02-2008, 06:19 AM   #9848
NitroWD's Avatar
Default teeth gap
hi guys,
since the stock G4 pinions and spurs are using a gap of 5 teeth difference; will it matter if i'm using a 6teeth gap on the pinions but a 4teeth gap on the spurs?
will it cause improper meshing and strips my gears?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 09-02-2008, 07:04 AM   #9849
aussies1129's Avatar
Trader Rating: 74 (100%+)
I would modify your brake arm get a mugen mtx lever with pin from 3racing i think there is one at rc mushroom then you can also get the mugen linkage with it also this will prevent your linkage popping off and also you can dial your brake in to what you want. look back a few posts as I remember seeing somepics.
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 09-02-2008, 07:08 AM   #9850
here you go i found a pic just leave out the aluminium stopper on the brake linkage I just didnt cut it short enough
cheers
H.E.I AUSTRALIA
Old 09-02-2008, 07:13 AM   #9851
razzor's Avatar
Originally Posted by NitroWD View Post
hi guys,
I know that was a issue on the Serpents with the pitch they use but havent had any hassles with the gear combos i have tried.
Some others can comment but i dont see it as a hassle.
Only problem we had with stripping gears was the bearing play on the 2 speed housing and having excessive clearance on the 2 speed shoes to the 2 speed housing.
Some have mentioned with the RS that the motor mount caused some hassles too.
Casterracing ZX1.5R
Old 09-02-2008, 07:33 AM   #9852
Rick Vessell's Avatar
Originally Posted by keavze View Post
hi,
just curious...
is it true that almost 100% of us here run the front spool?
anyone actually prefer the front diff or 1 way?
any particular reasons?
I run the diff up front most of the time. 50000 wt front and 10000 rear. It makes the car very smooth even on high traction tracks. You do have to be smoother on the throttle as it will diff out if you jump on the gas really hard out the corners. It just makes the car very easy to drive and feels more like an electric car on track.
Rick Vessell is offline   Reply With Quote
Old 09-02-2008, 07:35 AM   #9853
Originally Posted by blee View Post
Wish you would dominate the race, bro.!
He won't dominate because I'll be there!
Old 09-02-2008, 07:44 AM   #9854
keavze's Avatar
so...front diff is faster than spool?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 09-02-2008, 07:52 AM   #9855
NitroWD's Avatar
well...maybe it's due to the 2 piece engine mount that the RS is using?
i'm using the 1 piece kf mount on my RS and haven't had any issues.
i'm going to try 16/50 and 22/46; we'll see any gear stripping issues!
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
