Old 08-19-2008, 01:46 AM   #9736
freestyles's Avatar
Trader Rating: 14 (100%+)
Team magic make a good set of shocks, though unfortunately i don't remember the p/n. They are all alluminium and were the easiest of shocks to build and get equal rebound. The pre-load adjuster is the smoothest i have ever felt on any car. They don't leak like the stock ones do and are so strong even i can't break them (and that say's alot)
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 08-19-2008, 02:24 AM   #9737
aussies1129's Avatar
Trader Rating: 74 (100%+)
Hi Guys anyone know who stocks steel pinions #14122-15S
and has anyone tried them?
cheers
Originally Posted by NitroWD View Post
yup, TM does have steel pinions and they're cheaper than the HC Alum...
i was asking about reviews on them in post #815 (previous page) but no one seems to be using them.
they start with pn 14122-15S for the 15T, etc...
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 08-19-2008, 03:49 AM   #9738
Bundy_Bear's Avatar
Originally Posted by Sp Racer View Post
Yes Gansei, but what was it that caused the retirement?...
let's take a guess....
broken flying wing arm?......
stripped spur gear?........
broken front-side aluminum ED drive pulley ?.....
bent chassis? ( was he using the WC kit ? )
what are the odds?...
I disagree that they need a total new structure, the car is still very competitive ( look at the lap times )..... more like a "re-focus" - flying wing arms need a re-design, spur gears don't mesh properly etc etc....
Let's wait and see if Barry Baker gets to make some changes ! ( I bet he'll be suggesting a few!)
Just my opinion
Hi Luis
Speaking of fragile... I just finished reading your G4RS review in "Racing Lines"
and it didn't mention fragile at all
I actually had a flying wing front arm crack during the build on my G4+! Patto will tell you it is because i am too heavy handed, but they just don't make things like they use too.
BB
Bundy_Bear is offline   Reply With Quote
Old 08-19-2008, 03:54 AM   #9739
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Bundy_Bear View Post
Hi Luis
BB
i would suggest to leave the hammer in the tool box next time you build ya kit or take a deal to have some one build it for you
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-19-2008, 04:07 AM   #9740
Bundy_Bear's Avatar
HAMMER.... WTF!!!
I thought i had a customer deal sorted and then i got left at tha alter at the last minute. Now i will have to be a sheep and run a Mugen
BB
Old 08-19-2008, 04:44 AM   #9741
Pattojnr's Avatar
HAMMER.... WTF!!!
BB
Baaaaaaaaaahhhhhhhhhaaaaaaaa
deal is still on the table , you know that, just things change
Serpent - Walter RC
Old 08-19-2008, 05:11 AM   #9742
Bundy_Bear's Avatar
:P
Get back to building your 960 build for this weekend
BB
Old 08-19-2008, 06:32 AM   #9743
Sp Racer's Avatar
Hi Luis
BB
I've broken 3 fronts in total since November last year - big crashes ( but that is across 2 cars , Brendan did 2 in one meeting )
At the time of the review ( j/k) I hadn't broken one
I have seen some that look like they've had a trapped air bubble in the plastic, which makes them weak...
Still, it's a $4 part...
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 08-19-2008, 07:21 AM   #9744
PrimeAKF11's Avatar
I like how the LX shocks have bleed holes on their caps so I can set rebound strengths for all 4 equally fairly easily . I just wish the damping is externally adjustable like the Xray ones though .
PrimeAKF11 is offline   Reply With Quote
Old 08-19-2008, 07:34 AM   #9745
Pattojnr's Avatar
more parts internally mean more can go wrong. there int anything wrong with the LX shocks. they are great shocks.
Serpent - Walter RC
Old 08-19-2008, 03:47 PM   #9746
Bundy_Bear's Avatar
Hehehehehehe... All good!
Ari from HEI actually replaced mine under warranty. He was very professional to deal with and it wasn't good news when i heard he had lost the rights to TM here in Australia.
Luis are you racing at the nationals at Brendale?
BB
Old 08-19-2008, 03:55 PM   #9747
Sp Racer's Avatar
Yep, we felt the same way , and are still very thankful for HEI's help -
so far, Brad (the new importer ) from Zauber has been pretty good to deal with.
Yes , Brendan and I will both be racing there
Old 08-19-2008, 04:09 PM   #9748
Bundy_Bear's Avatar
Ok cool, not long to go now. Will have to try and get over for a looksy.
BB
Old 08-20-2008, 03:00 PM   #9749
freestyles's Avatar
Hi Keavze, Have you got a part number or better yet a photo of those 'new 30mm thinner shoes'??? I have an Eagle racing G4 and the throw weights that fit the flywheel are a lot thinner than the throw weights in my G4s and i can't find them anywhere. I'm hoping the ones your talking about might fit. For your clutch slipping maybe try tightening the clutch spring just a tad bit and then see how you go and tune from there.
Originally Posted by keavze View Post
hi,
just started trying out the Mugen hard spring with no weights in the flyouts.
my problem: clutch slipping when throttling up to 50%, from 50% onwards, it's ok, no slippage.
spring tension is minimum (spring nut flush with flywheel nut) and clutch gap is 0.4mm.
so...what's my solution? reduce clutch gap further?
btw, can i use UFO1 clutch shoe in UFO2? and how about the 'new 30mm thinner shoe'?
Old 08-20-2008, 06:53 PM   #9750
keavze's Avatar
K1410-5...
http://www.rcshopping.com/profra.jsp...10-5&proclass=
tightening clutch spring won't make the slippage worst???
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
