Old 08-15-2008, 06:56 AM   #9706
aussies1129's Avatar
Trader Rating: 74 (100%+)
yep! I would have to agree my track is medium to low grip and setting the car up so its not so stiff really made a difference, I am now running lap times faster than anyone else, the car just holds so well although shiny aluminium would look flash! can you get the chassis as a sepaerate part??
cheers
Originally Posted by Pattojnr View Post
im just having this conversaton with some one else.
the G4+ was too rigid, and as a result was hard to find a sweet spot.
the G4RS was a step in the right direction once again. know i feel any flex or roll with the new alloy bulkheads, are a step backwards. if these parts were made in plastic, then it would be much better.
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 08-15-2008, 07:52 AM   #9707
keavze's Avatar
cheers
ya man!!! exactly what i wanted too...
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 08-15-2008, 12:32 PM   #9708
Trader Rating: 16 (100%+)
I think RedRC already mentioned DARIO is using his last year G4+ for the world...in the racer/manufactory stand point, as long as his driver WINS the race, what year model does not matter...
Beside, G4+ and G4RS, very similar in design...
Old 08-15-2008, 12:55 PM   #9709
Jorge G's Avatar
Originally Posted by British Menace View Post
I take back what I said.
It appears there are a few distributors / dealers who have or have had in, the "WC" parts this week.
Yes. As 'Patto' has said the screw at the end of the two speed shaft comes from the ED trans' which came on the G4+ and as an upgrade too.
Good to see Barry, Dario and Marc able to make the G4 go so well in Portugal. I think with a little more luck, it could have been so much different!
On the WC stuff....... I do like the chassis and the rear parts. I think the front parts are somewhat.......cosmetic?!
Regards,
British Menace
Menace,
Do you know the part number(s) for the screw at the end of the two speed?
Thanks!
TC6
XRAY NT1/ Novarossi 353 Race Engine
F1 F104 Pro V2
Jorge G is offline   Reply With Quote
Old 08-15-2008, 02:19 PM   #9710
British Menace's Avatar
Originally Posted by Jorge G View Post
Menace,
Thanks!
I believe the screw size is 3 X 8 (mm) Button Head screw.
You may find going to the local DIY store you will be able to get a dozen screws for alot less then if you got the exact part number.
Although. If you still have problems getting the screws you need. Go to
www.tonysscrews.com
he has all the screws you need. And good ones too. He even does a screw kit for the G4 which gives you "EVERYTHING" !!
If you still want to get the TM screws. You will need to get a screw pack which TM does. Can be tough to find.
Regards,
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 08-16-2008, 12:26 AM   #9711
blee's Avatar
Brother, Peter said those are G4RS base plus G4+ options plus WC kit.
blee is offline   Reply With Quote
Old 08-16-2008, 04:23 AM   #9712
keavze's Avatar
Default clutch slipping...
hi,
just started trying out the Mugen hard spring with no weights in the flyouts.
my problem: clutch slipping when throttling up to 50%, from 50% onwards, it's ok, no slippage.
spring tension is minimum (spring nut flush with flywheel nut) and clutch gap is 0.4mm.
so...what's my solution? reduce clutch gap further?
btw, can i use UFO1 clutch shoe in UFO2? and how about the 'new 30mm thinner shoe'?
Old 08-16-2008, 05:28 AM   #9713
Sp Racer's Avatar
Originally Posted by keavze View Post
hi,
Try putting 1 weight in each flyout....same settings as you are running now
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 08-16-2008, 05:48 AM   #9714
Pattojnr's Avatar
Trader Rating: 19 (100%+)
hi,
now your clutch has slippage....... hows the wheel spin ?
from here it is fine tuning your clutch.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-16-2008, 06:09 AM   #9715
keavze's Avatar
hi patto and sp,
initially i'm using TM 1.8 yellow with all weights, 0.4mm gap.
now it's mugen spring with no weights, 0.4mm gap.
maybe i shld try with 1 weight as sp suggested.
another thing came to my mind, how to know when yr clutch shoe is wornout and not usable anymore? will that cause slippage too?
Old 08-16-2008, 06:26 AM   #9716
Pattojnr's Avatar
hi patto and sp,
you will find the alloy reatainer will touch the clutch bell when the shoe is worn out. then it will be either on or off. the bell will be shiny.
if using the UFO 2, they tried to get more life with the raised bit under side of the shoe. but if your replacing, i would go the red shoe. as i stated befoer i used no weights, but with the TM black spring. so the mugen will be different again. so do try one weight in each shoe, as SP ( Lui Lui........... 0..... yeah ) suggested.
Serpent - Walter RC
Old 08-16-2008, 06:52 AM   #9717
keavze's Avatar
thanks patto...
btw, UFO1 and UFO2 diff are only the shoe plate and shoe; other than having a 'longer' shoe life; any other benefits of UFO2?
Old 08-17-2008, 03:54 AM   #9718
Hi guys does anyone know if TM do steel pinions like mugen and kyosho? expecially the first gear as I just go through them every few months
cheers
H.E.I AUSTRALIA
Old 08-17-2008, 04:14 AM   #9719
razzor's Avatar
Keavze id also suggest going with 1 weight.
My setup is mugen hard spring 1 weight in flyweights
std black flyweights with black shoe
.5mm clutch gap
.1mm end play
about 1 thread of preload on spring
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-17-2008, 04:17 AM   #9720
razzor's Avatar
Pity for Dario Ballestri in teh WC finalls.
He had a accident and damaged the car to have it repaired and then after 50 laps have a accident and retire.
Have to wait 2 year again for another try in the US.
Casterracing ZX1.5R
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
