Old 08-09-2008, 05:20 PM   #9631
PrimeAKF11's Avatar
Best of luck!!! Nice to see such a team of great drivers under the TM banner.
PrimeAKF11 is offline   Reply With Quote
Old 08-09-2008, 10:51 PM   #9632
Omarko's Avatar
Originally Posted by aussies1129 View Post
hey guys your not going to believe how much the wc upgrades are, at these prices who wants the upgrade?I was about to order but now have thought twice about it.
K14145 G4 WC Upgrade Kit US$234
K14145-1 G4 WC Upgrade Kit (front) US$58
K14145-2 G4 WC Upgrade Kit (rear) US$189
cheers
they do look very cool though ... very tempted to purchase the K14145 from RCSHOPPING ....
do u guys reckon its worth it performance wise or is it just bling bling ?
Omarko is offline   Reply With Quote
Old 08-09-2008, 11:44 PM   #9633
Sp Racer's Avatar
Performance & Bling
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 08-09-2008, 11:55 PM   #9634
keavze's Avatar
well, the new strengthen 3mm chassis is what i need...do they sell it separately?
i suppose the chassis will be included in the upgrade for the rear?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 08-10-2008, 12:17 AM   #9635
keavze's Avatar
Default wheel spin...
hi guys,
if yr car experiences wheel spin during acceleration (not from standstill)...what're the possible causes?
my clutch gap is 0.4mm and my clutch spring setting is visible with a single thread on the nut; using TM yellow spring.
ED transmission using 16/21 and 50/45...
Old 08-10-2008, 12:29 AM   #9636
aussies1129's Avatar
Trader Rating: 74 (100%+)
rear wheel spin I gathered how about try to stiffen the front and or soften the rear to give you better bite, try softer springs in the rear and play around with your droop. I run a front softer tyre in the front and go 6.5mm front and 6.0mm rear chassis height this has made the car so much more drivable the rear just feels so much better. see how you go
cheers
Originally Posted by keavze View Post
hi guys,
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 08-10-2008, 02:09 AM   #9637
Sp Racer's Avatar
hi guys,
How many weights are you using ?......what type of shoe?
I would have thought 16/50 should just about kill all the wheel spin...
Old 08-10-2008, 03:10 AM   #9638
keavze's Avatar
cheers
well...if i make the rear softer or stiffen the frt, the car will push more...understeering.
i'm running a frt spool and rear diff of 20k.
frt droop of 1 and rear droop of 3.
Old 08-10-2008, 03:14 AM   #9639
keavze's Avatar
i'm still using the stock UFO2 weights and shoe...
track here is about medium to low traction.
Old 08-10-2008, 04:01 AM   #9640
Pattojnr's Avatar
Trader Rating: 19 (100%+)
even on low to med traction , i always used the black spring, with no weights. clutch gap of 0.4 is what i was using.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-10-2008, 05:45 AM   #9641
NitroWD's Avatar
if not able to get power to the ground; isn't it the engagement too hard/harsh and we should soften the engagement?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 08-10-2008, 05:58 AM   #9642
Pattojnr's Avatar
car setup is also important. diff oils and most important, throttle Finger.
a clutch wont be effective if just grabbing the throttle. ease it on then the clutch will function smoothly rather than just on.
the black spring is hard, and i tightened to just see 1 thread . so not alot of preload on the spring, the no weights in the shoes make it lighter, so yes it will engage later, but also with out weight behind it. so it wont be as snappy.
hard spring and light weights. then adjust the spring as required. low traction 10K diff oil , and the rest is roll centers and springs. good luck.
Serpent - Walter RC
Old 08-10-2008, 06:00 AM   #9643
yep thats right if you go the black spring and about flush on the round nut no weights will allow the engine to engage later at a higher rpm that should fix the early hard engagement and hopefully stop the wheel spin.
cheers
H.E.I AUSTRALIA
Old 08-10-2008, 06:03 AM   #9644
H.E.I AUSTRALIA
Old 08-10-2008, 06:14 AM   #9645
NitroWD's Avatar
cheers
ok, now i understand regarding the hard spring and no weights but to engage at higher rpm?
won't engaging at higher rpm produce more wheelspin?
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
