Old 07-11-2008, 09:11 PM   #9481
charlesd's Avatar
I have the speed shot front end, new g4 rear bulkheads + the new sway bar that i still have to install on the regular rear s arms. I'm going to have to use longer links and make my own holes on the arms. I also ordered the new brake bracket as the old one interfered with the roll bar.
I was thinking on getting the rs parts but was not sure i could swap rear end for rear end.
I do not have the ed transmission but the original g4s one.
I'll look for your post with the parts.
charlesd is offline   Reply With Quote
Old 07-11-2008, 09:35 PM   #9482
PrimeAKF11's Avatar
I am building the G4RS right now, and all I can say is that the build quality is stunning. Everything just....fits. So far, whenever I had trouble assembling something, it was ME who was doing something wrong.
PrimeAKF11 is offline   Reply With Quote
Old 07-11-2008, 10:32 PM   #9483
charlesd's Avatar
Originally Posted by Pattojnr View Post
i put a list of the part numbers a while back for all the rear end parts you will need.
I went through this thread and could not find parts list. Did i miss it or was it on another thread?
Old 07-12-2008, 12:00 PM   #9484
razzor's Avatar
This is Patto's post from the G4S thread #8844
"ok here we go, i hope to not miss anything out.
Front parts to use with G4S
K14124-6 nylon speedshot Top brace
K14124-4 carbon shock tower
K14124-5 inserts for roll center adjustment
K14138 front upper hinge pins
K14124-1 speedshot bulkheads
502341 plastic G4JS X brace
rear parts
502327 G4RS top arm links
502328 G4RS top shock tower brace
502329 G4RS rear shock tower
these parts will transfor the G4S suspension to the RS components. Charles, you can use the existing G4S chassis and roll bars and rear bulkheads, while retaining the same stronger G4S arms. the only thing you will loose on the rear is some leverage of the span between the rear lower flying arms compared to the original G4S arms. the distance from hinge pin to shock position on the arm is longer on the flying arms. but i would trade strength for leverage any day. im actually trying to chase down a G4S at the moment so i can make it with the parts listed above.
if you want to use the new rear swaybar and the flying arms, you will then need to get the arms of course and rear lower hinge pins and the new rear bulkheads. but id stick with the older arms for sure."
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-12-2008, 09:49 PM   #9485
charlesd's Avatar
Thanks Razzor. I'll give this a shot.
Old 07-12-2008, 10:17 PM   #9486
charlesd's Avatar
I just calculated the price of the parts i would need for the rear end and it comes out to 95$.
The G4js is 219$ and i already have the sway bar + the rear brake bracket here. Mmmmmmm, Some thinking to do ........
Old 07-13-2008, 04:54 AM   #9487
Pattojnr's Avatar
Trader Rating: 19 (100%+)
thanks razzor, i couldnt for the life of me remember which thread i posted it in. and i was away for racing for a couple of days. happy to also report G4RS TQ and win. the car just keeps gettin better.
Charles, the G4Js has a 6065 alloy chassis not 7075 alloy. but everything else is still ok .
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-13-2008, 01:52 PM   #9488
charlesd's Avatar
Hi Paul,
The idea behind the g4js was to swap the rear end of the js on my g4s, take the ed transmission from the js and put it on the g4s, and i would have some spare parts such as belts, clutch parts, etc.... I was up to 95$ just for rear end parts and that's without pullies nor the ed clutch gears. I'm still thinking about it.
Either that or i'll wait in the new year and get the rs.
Old 07-15-2008, 04:00 PM   #9489
Trader Rating: 16 (100%+)
Originally Posted by charlesd View Post
Does anyone have a link to the manual?Thanks
Here you go....courtesy from www.rcmanufactory.com
http://www.rcstudy.com/TM/G4RS-manual.pdf
Old 07-17-2008, 09:22 AM   #9490
keavze's Avatar
Hi Paul,
dont wait...just go for it NOW!
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 07-17-2008, 10:23 AM   #9491
which is the better car the rs or the + ?
nc racer is offline   Reply With Quote
Old 07-17-2008, 10:47 AM   #9492
Most of the time, NEWER is always better.........I never own the + so I cannot tell, but I know my RS is dialed after 2 practice run and 2 big races.
Old 07-17-2008, 07:11 PM   #9493
This is the thing I would like to do right after the Byron race....it is 100 times better then the original setup, and I am sure my cornering will be alot faster this time. The best part....cost like then $10 to do that....(wondering why TM does not want to do this the beginning...). I will be heading to Racine for the 4th leg of the Mid West Series....this time I feel more comfortable then the Chicago Leg with my Serpent 720.
I know Jonnysocko had his own version done for the upcoming Great Lake Challenge plus other modification, I will post pictures of his version after the GLC....good luck there Socko.
Also, good luck to the Iowa gang @ the "Heat of America" event...bring home the GOLD...
Old 07-17-2008, 07:54 PM   #9494
keavze's Avatar
+ is nicer to look at and stiffer with more alum parts...better for high traction tracks...
RS has abit more flex/roll due to plastic parts used and better in low traction tracks.
if you're buying new...go for the RS!
you can always 'hopup' to the + parts if needed. RS has the latest narrower chassis.
Old 07-17-2008, 07:58 PM   #9495
keavze's Avatar
you're talking about the extended 'braking arm' or the 'shielded rx'?
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
