Team Magic G4
#9316
cheers
www.rc-mushroom.com have this in stock I think
#9317
Just finished the upgrades , love how it looks
I am using the premium power 1300 lipo as well ...u can see it in the pics... fits nicely I fitted the other part into the compartment with the micro receiver (from DX3R)
now I want to upgrade to 18T / 52T and 25T / 45T ... can someone tell me if that is OK for our Moorebank track by any chance ? I think it offers highest acceleration with best top speed with my RB V12 R3 ... thats if I understood all the ratios correctly....
cheers
cheers
oh and give this a try 17/50 22/47 for me the car seems to like taller first gears. hey Patto what gearing did you run in Adelaide????
cheers
#9318
that car with the upgrades is looking just beautiful!the side plates look very smart like the G4+ and you got the battery to fit perfectly nice job Alex look forward to catching up hopefull early July for a run at moorebank.
cheers
cheers
#9319
The drive pin in the Hex drive?............yep, that would do it. Lol
Sometimes the simplest thing can be our biggest downfall.
Please don't take offence. I really do not mean anything by it.
#9320
British Menace-
I just bought Steve Perez's G4S. The car is totally new and box stock. He mentioned to me that you could help me with a good setup for a small track with high traction. Also, a good setup for the UFO clutch (I think thats the one that comes with the G4S).
Thanks!
Thanks!
#9321
I had a friend who spent prity much the whole weekend over motor problems, trying everything, he eventually changed all the o rings and sealed up the motor changed plugs and everything.
Turned out there was almost a whole exhaust gasget in the exhaust!! which was causing the problem!!?
The littlest things ......
Prety much ruined his weekend although he was please He had found the probelm!
Please you found out your problem keavz
British Menace
British Menace
#9322
Hello slokomo
Good to hear you've got a G4S ! Welcome to the family !
Say hello to Steve for me................
Small track High Traction?
On the clutch I would go with this,
Mugan silver 'Super Hard' clutch spring.
0.3mm tension on the clutch spring.
0.5mm clutch gap
0.1mm end play on the bell when assembled. (Basically as little play as poss' but must have "some" movement!!)
No weights in the 3 fly weight shoes.
I would use the red clutch shoe. (It allows a little more slip as the black can tend to be too aggressive....... almost on / off like a light switch....lol)
That should get the best out of the clutch for you.
On set up..............
Let me know, how high traction? Do people have alot of problems with grip rolling? All makes of car? Is the traction that high?
It makes a small difference.
Let me know. I really have to rush off now.......family duties...lol
Taking children to the park!!
British Menace
0.5mm clutch gap
British Menace
#9324
Unless your G4 is about 4 years old you'll be ok !
The tank which comes with the S is fine. No air traps and correct size too. As with all tanks (Any make) keep a check on the o ring in the lid and change if you suspect it.
If yours is new you should be ok for at least a year.
Also, ensure the tank mount at the front of the car has a small o ring on before you install the tank and the clip.
This helps to tilt the tank backwords and be able to use all the fuel in the tank.
The K Factory tank Patto referes to is very nice!! Comes with a better lid but is slightly heavier. Also comes slightly grey tinted too......very cool !!
Regards,
British Menace
#9325
can someone explain why should I remove the weights from the clutch shoes? I've been recommended to do this bit still not understand why ...
cheers
cheers
#9326
in each shoe and it wasnt as agressive I got more grip the car was easier to control so to speak.just give it a try and see how it goes it wont hurt.
cheers
#9327
ok ... thanks for the explanation ... will set it up tonight ...
I have to be ready to race for Sat Meca
#9328
As Aussies1129 pointed out. The weights effect how aggressively the clutch will engage. It has a little effect on when too, but not as much as the spring tension.
With less weights in the clutch plate will "slip" slightly before it really grips and you get full, direct drive to the drive train. This slight slip is almost none existant with 2 wieghts in, and the bite you get from the clutch can cause your tires to break loose and you loose grip.
The red clutch shoes can also help with this slippage too. They let an aggressively set up cluch slip a little so it doesn't break you car loose when you hit the gas hard.
Select the spring and the tension to how high up the rev range you want the clutch to engage, set the weights, shoe colour to how aggressively you want that engagement to be, the more grip you have, the more aggressive you can afford to be
Hope this helps.
British Menace
#9329
[QUOTE=Omarko;4481324]ok ... thanks for the explanation ... will set it up tonight ...
also to kfactory make a ufo shoe in white which allows for better engagement the material I think is softer I bought this not aware that this shoe is best for high traction sufaces so i went back to the red ufo shoe and also have coming the kfactory brown hard shoe so there are a few factors that you have to consider to get the right clutch setup.have fun sat! I have a intercity meet in townsville running at night so I hope I can grasp the track to make the final the rs is running well its going to be down to how well I focus and a bit of luck.
cheers
cheers
#9330
will try out my car one last time this sat before going for the sun race!
hope everything goes well.
