Old 05-04-2008, 05:38 PM   #9256
NitroWD's Avatar
Originally Posted by rcrevolution View Post
cant I just get another set of frotn unis and use them on the rear?
if you're talking about kfactory unis K1488, yes you can...
they're length adjustable for either front or rear.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 05-04-2008, 05:43 PM   #9257
Pattojnr's Avatar
Trader Rating: 19 (100%+)
the Universals are the same front and rear. there are 2 pin holes you can set them at. outer hole is short, for rear, and inner hole is for long for the front. but the same part number.
the dog bones shouldnt fall out if you have your track width set right, and you have your droop set, and cambers set. i have seen one car using the dog bones, and they arent close to falling out. ?
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-05-2008, 06:27 AM   #9258
Pattojnr's Avatar
Originally Posted by gansei View Post
the Recent My G4RS Movie!!!
http://www.youtube.com/watch?v=xIaiSUKgO1s
howdy Gansei, looks like your still having fun and time on your hands to edit the videos always love your vids. keep havin fun.
Serpent - Walter RC
Old 05-05-2008, 03:36 PM   #9259
Perez's Avatar
hey guys, long time no talk. Well i just got a G4S from a good friend for a really good price!
so im gonna run it after all. I unfortunetly had to return my old g4s when my sponsorship ended including every upgrade, spur gear, and spare part i had. So im starting from scratch with no spares! I have the standard tranny, which is still ok right?
Where are you guys getting spares from here in the US?
thanks and its good to see you guys are still around especially patto and British M
Perez is offline   Reply With Quote
Old 05-05-2008, 03:38 PM   #9260
rcrevolution's Avatar
Send a message via AIM to rcrevolution
I have my almost new g4s for sale too on ebay.
rcrevolution is offline   Reply With Quote
Old 05-05-2008, 04:57 PM   #9261
aussies1129's Avatar
Trader Rating: 74 (100%+)
hi guys I didnt have a problem with the rear dogbones as pattojnr said as long as you have the correct width,droop setup it will be ok but I went and got the unis any way as I really dont want to lose a race because of a stupid break down.
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 05-05-2008, 05:07 PM   #9262
Try wolfhobbies. They have a website and I think they're in Granite Bay, CA.
Stroker Ace is offline   Reply With Quote
Old 05-05-2008, 05:08 PM   #9263
British Menace's Avatar
Ahhhh Mr. Perez I presume...... lol
So you finally got yourself your own G4S...........there's no looking back now
Divisional champ, all-state, National, Worlds!!! Is there an Inter-Galactic Champioship?? I'll get you entered.....lol
Good to hear from you steve!!
The stock G4S is a great car even with the stock tranny!
What I would do when you have some money to spend on the car is get the pulley set from the G4RS. They fit the stock two speed and front pulley shafts and they are ED sizes. Get the ED pinions and end bell set and you'll see a difference in acceleration and top speed using the ED system over the stock tranny. But for now, the stock stuff is fine!
I'm still running the S but I have the RS pulleys I mentioned on order from Wolf Hobbies.
Wolf Hobbies and UltraLine Hobbies are the places to get your spare parts if and when you need them Steve. Or myself......lol. After running the G4 for so long I thing I have more parts then most distributors.....lol.
Anyway, for the future. I would look at getting the speedshot front end with the plastic top brace. It's lighter. That will make future front diff' replacement's a breeze!
Let me know how you get on Steve. Any probs, give us a call.
Regards,
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 05-05-2008, 05:25 PM   #9264
Pattojnr's Avatar
Hi steve. i would also suggest the G4RS plastic pullies and ed pinions.
speed shot front end, and G4RS back top shock tower mount with the new rear top arms and rear hubs. everything else use the std G4S stuff, like arms and front steering blocks. but also get the new rear swaybar.
Wolf hobbies has all the parts, i would also suggest a Kfactory solid front axle. its light and fits the plastic pulley with ease.
i just got back from the SA titles, i qualified 7th , won my semi final and came 5th in the A Main. the car was great all weekend. no issues apart from the flying wing arms on the rear, there is casting bubbles in the plastic. they arent that straong, but if your using a G4s then keep the std arms.
Serpent - Walter RC
Old 05-05-2008, 06:21 PM   #9265
afm
afm's Avatar
Regards,
British Menace
Guys, what i did after carefully making my maths, is got myself a G4JS and with upper deck and rear shock tower from my G4S made me a quasi RS for 229.00 bucks. You get plastic speed shot, plastic ED transmission, flying wing susp.arms, new steering blocks, rear uprights, etc. etc. plus you stay with a lot of spares. it's cheaper than buying the parts alone.
AFM
afm is offline   Reply With Quote
Old 05-06-2008, 08:27 AM   #9266
keavze's Avatar
Default too much steering vs understeering
hi,
i believe i've read somewhere here that the RS has alot of steering and steering rate needs to be turned down...
does too much steering = oversteering?
i find that my RS suffers from understeering during on-power; any ways to improve or prevent?
setup as follows: front / rear
spool / 20k diff
1.6spring / 1.5spring
600 shock / 500 shock
90deg arb / 0 deg arb
3deg camber / 3.5deg camber
1deg toe out / 2deg toe in
1mm droop / 4mm droop
anyone got a good setup for a low-medium grip medium-sized track?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 05-06-2008, 08:32 AM   #9267
Hey G4S people.
I had an interesting race last weekend. A very bumpy track and a difficult start, my drive pin came out at the start and no second gear to boot!!?...lol.
Once back on the track though, my car was the fastest in the final!
Small to medium size track. Low to med' traction. Very bumpy. 80 degree track temp. 73 degree air temp.
G4S
Front:
Solid Axle
50Wt Shock oil on 2 x 1.3mm holes
1.5mm TM springs
Shock top position: 2nd hole from inside.
Bottom Position: Outside hole
Sway bar: 3mm Mugan bar, flat.
Toe: +1.5 Degrees (toe out)
Camber: -2 degrees
Front tire: 35 Shore GQ at 60mm dia'
Ride hight: 5.5mm
Front droop: +1
Rear
10,000 WT Diff
40WT shock oil on 2 x 1.3mm holes
1.4 TM springs
Shock top position: Centre hole
No sway bar fitted.
Rear Toe: -2.5 degrees
Camber: Left -3.5, Right -3 degrees
Rear Tire: 37 Shore GQ at 62mm dia'
Ride hight: 6mm
Rear droop: +2.5
Wheel base: Shortest.
Body: DNA 3
Motor: WERKS .12 3 port.
Pipe: Skyline VR12+
Clutch: Black shoes. No weights. Orange spring, 0.5mm pre-load, 0.5mm clutch gap, next to nothing clutch endplay.
Gearing:
ED transmission.
16/21 Bell
52/47 spur
Car weight: 1730g (with 80g of weights added to make weight all on chassis. Mainly at front to get weight distribution.)
WERKS Race Blend Fuel 30%
Regards,
British Menace
Old 05-06-2008, 08:52 AM   #9268
keavze's Avatar
Great job!
Glad that you stick with G4...
Old 05-06-2008, 09:00 AM   #9269
Pattojnr's Avatar
Originally Posted by keavze View Post
hi,
spool / 20k diff
setup looks ok, i would swap the swaybars around, flat front and 90 deg rear. also roll centers are very important. try top inner position with 3-4mm spacers on the hubs, and either lowest position on speedshot or middle inner for front roll center. the hard front swaybar can cause your understeer, i always run the front bar flat. work with the rear bar for grip and turn in. but do try those roll centers.
Serpent - Walter RC
Old 05-06-2008, 09:17 AM   #9270
keavze's Avatar
i've tried flat front with 90deg rear before; but it causes my car to loose rear grip...
roll centers: front is in middle inner but i'm still using the std G4 rear hubs...oops.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
