Old 04-26-2008, 12:28 AM   #9226
NitroWD's Avatar
Originally Posted by Pattojnr View Post
dependant on how much paint is on the body, how many stickers and holes cut out, expect around 100g approx for a body. so you shold be closer to the 1750g weight, but do keep an old set of tires, then true them down to minimum size, and keep them for weighing the car.
when getting the car down in weight, it allows us to add it. now a tweak station, or the hudy setup woth scales is a good tool to be using to work out where to add the weight. if the car is left heavy, then add to the right of the chassis. simple alloy stick on weights are good for this. just make sure the surface is clean , then stick them on. the trick is to get a good balanced car, left to right, then if you need more weight added, you can stick it up front for a little more steering.. etc...
thanks for the tips...
i happen to have a tweak station which i didn't use at all!
btw, is there any rules about using unpainted body?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 04-26-2008, 11:34 AM   #9227
British Menace's Avatar
Technically. The body has to be painted and all windows have to remain transparent. There are also some rules around having to have certain decals on the car too. Headlights, rear (tail) lights and grills. But unless your in a big comp' I doubt many will make you answer to these rules too much.
Regards,
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 04-26-2008, 09:12 PM   #9228
charlesd's Avatar
Question on the brakes for you guys:
I just installed the k-factory brake pads with the k-factory brake disk. The separation is wide enough (done by the springs) but the disk still catches on the edge of the pads. I roll the car and you can feel it and hear it catching (tack, tack, tack). My question is, does this go away after a few runs?
charlesd is offline   Reply With Quote
Old 04-26-2008, 09:46 PM   #9229
Pattojnr's Avatar
Trader Rating: 19 (100%+)
are you using the ED trans Charles ?
the ED (alloy) trans you have to watch the disc cutting into the brake pulley.
once this happens then you get the disc chattering. but if your using the std trans, be sure to check the pins havent come out of the gear and catching on the bulkhead. if its all ok, then just run the car and check it out after a run , see if they bed in .
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-26-2008, 10:20 PM   #9230
charlesd's Avatar
Standard transmission and the pins are ok. It's the actual fins on the disk catching the pads. I'm hoping it will wear in.
Old 04-27-2008, 06:18 PM   #9231
keavze's Avatar
any ways to prevent the disc cutting into the brake pulley?
else we gotta replace the brake pulley?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 04-27-2008, 07:21 PM   #9232
Trader Rating: 66 (100%+)
Anyone lookin for a sweet g4s pm me or check out the for sale forum
Team G FORCE Hobbies / Team Driver
Losi/Tekin/Spektrum/AKA/SMC/Avid Rc
Pot Belly's RIP!
Jaypeezy is offline   Reply With Quote
Old 04-27-2008, 08:10 PM   #9233
rcrevolution's Avatar
Send a message via AIM to rcrevolution
hey guys hows it going!
I see the 2008 season is off to a good start, I am trying to get rid of the g4s and get my g4rs running.
what happened to the g4rs? it seems to be dead on the forums..
rcrevolution is offline   Reply With Quote
Old 04-28-2008, 02:29 AM   #9234
NitroWD's Avatar
maybe it's due to not many running the RS yet?
Old 04-28-2008, 02:33 AM   #9235
NitroWD's Avatar
hi all lipo rx users,
will using a 900mah lipo be better than using a 1100mah nimh?
Old 04-28-2008, 03:40 AM   #9236
razzor's Avatar
This weekend was the 2nd round of the national series.
Pleased to hear that a fellow G4S racer, the lone TM car in teh event, managed to take 4th overall in the A-mains and that with him competing against S720's and MTX4R's.
Dont necessarily think going to a new car is better.
He runs a stock G4S with ED tranny and a front diff. Everything else is box stock.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-28-2008, 04:59 AM   #9237
Pattojnr's Avatar
no there isnt. or not that im aware. it is maintanence or wear and tear item.
it has taken quite a few races for mine to start to wear the pulley, but thats about 6 months of racing. if you were running plastic pullies, they would have been replaced a few times already, so 6 months and replace a brake pulley seems ok for me,
Serpent - Walter RC
Old 04-28-2008, 05:02 AM   #9238
Pattojnr's Avatar
all depends on the regulator you are going to use. some have a cutt off at 6.7 volts, and some are around 6.2 or even 6 volts. so the cutt of voltage is better closer to the 6 volts. but a higher capacity lipo could see you run a higher cutt off votlage. this cut of voltage, is where the reg supplies a 6.7v till the battery cant deliver it, then it cuts out. so a higher voltage will see faster servo performance but its negligable to see the difference between 6.7 and a 6v supply.
Serpent - Walter RC
Old 04-28-2008, 05:06 AM   #9239
Pattojnr's Avatar
this weekend will see the South Australian state titles, i knwo about 3 G4RS cars attending, some of the names there will be Steven and Peter Jovanovic and Jessie Davis. so it will be a struggle, but thats why im going
Razzor, i totally agree. there is nothing wrong with the G4S, with the Ed trans. i would add the new RS top bracket and rear top arm. more rear roll center adjustments . speed shot also helps. but the G4S is still a great car.
Serpent - Walter RC
Old 04-28-2008, 11:54 AM   #9240
ALG
Pattojnr,
what Lipo are you using on the RS? I need to get a pack, but one that fits
Thanks for your help.
Have fun
ALG is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
