Old 04-22-2008, 07:30 AM   #9196
charlesd's Avatar
Question for you guys that have used the first series of the JLR red dot:
On a relatively short track, what gearing did you use? With other motors i've been using 19/24. On my bell i have 18/24 on there now. too low for the red dot?
charlesd is offline   Reply With Quote
Old 04-22-2008, 08:40 AM   #9197
Speyederjedi's Avatar
I've run all 3 Red Dot motors and am currently running the Red Dot EVO III JL Tuned Version. We have a relatively short technical track here in San Antonio, Texas and with my previous car (RRR-Evo) and my current G4RS I've run 15/21, 16/21 and 17/22 on my pinions. It seems to work well for our short tight track. Even at the big track at Mike's Hobbies in Houston, Texas I ran 16/23 on my pinions with the 56/61 spurs and it was good enough to make the A-Main at the Gulfcoast Speedline Grand Prix. Hope this helps. I do think you may be to tall on your pinions but depending on your tire size and how tight the track is it may work for you. If your track is short and tight and you want to come out of the turns quicker I would suggest going shorter on the pinions. If your track is short but the turns are more sweeping than tight you may have the right set-up. Just experiment with the gearing without changinG the tire size and see which feels better.
G4RS
Speyederjedi is offline   Reply With Quote
Old 04-22-2008, 11:44 AM   #9198
charlesd's Avatar
Here's our track:
http://www.rcpikeriver.com/track.html
the back straight is about 150 to 180 feet depending on how we do the lay out on top of the permanent part. On the far right, that section can sometimes be make into a double S. (on the picture it shows the oval or the hair pin ). that 28 foot section is open pavement so we change the layout regularly.
Old 04-22-2008, 01:54 PM   #9199
Originally Posted by charlesd View Post
Here's our track:
Cool track!! It's a bit bigger than ours in San Antonio but just a bit smaller than the track I run at in Houston. From the photos and dimensions I'd probably start with 62mm rear tire height and 60mm front with the 16/21 or 16/22 pinions and 56/61 spur or 55/61. Give it a try and see how it goes.
G4RS
Old 04-22-2008, 05:14 PM   #9200
Pattojnr's Avatar
Trader Rating: 19 (100%+)
G4RS
what spurs are you refering to ? TM spurs come in (1st) 50-51-52 (2nd) 45-46-47 .
im guessing its a typo , but i thaught id ask anyway
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-23-2008, 02:56 PM   #9201
What is the internal gear ratio of the G4S with and without ED gears?
NinjaRacer is offline   Reply With Quote
Old 04-23-2008, 07:23 PM   #9202
afm
afm's Avatar
Std. = 2.526
ED = 2.190
AFM
afm is offline   Reply With Quote
Old 04-23-2008, 08:32 PM   #9203
British Menace's Avatar
Hello everyone,
How are you all? Are there many out there, in the U.S running the G4S or has everyone upgraded to the G4RS ?
I for one am still running the 'S' for now although that may change soon??!
The change to plastic "ED" pulleys seams a definate improvement to me. The shortening of the chassis due to the re-positioning of the rear sway bar is also an improvement.
Has anyone, or is anyone having any sort of problems with Spektrum Pro system, specifically in an M11, with the 800mAh or 1100 mAh battery packs?
I did have some issues with using these and I put it down to max Amp draw from these batteries was not sufficient to satisfy the Pro receiver and hence went into either failsafe, or some sort of Glitch, for want of a better word for it. Three times this happened and the car ended up going straight ahead at full throttle? This problem seam to go went I changed to a Li-Po battery and regulator set-up.
Just wondered if any body else had seen similar issues?
Regards,
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 04-23-2008, 09:01 PM   #9204
aussies1129's Avatar
Trader Rating: 74 (100%+)
Originally Posted by British Menace View Post
Hello everyone,
Regards,
British Menace
Hi British I am running the spek pro mod for the 3pks and never had a problem previously but upgrading to a 1300mah lipo has allowed me to run what seems like forever compared to the nimh, no going back now.
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 04-23-2008, 11:43 PM   #9205
aussies1129 & British Menace could you guys post pics of your lipo conversions and pack info, physical size and mah? I've been wanting to do this but haven't founf a pack to do it with.
schurcr is offline   Reply With Quote
Old 04-24-2008, 01:23 AM   #9206
RevMaxx's Avatar
Send a message via MSN to RevMaxx
lipos gives you an edge... be it in Tx or in Rx pack.
same here... "no going back"
RevMaxx is offline   Reply With Quote
Old 04-24-2008, 02:16 AM   #9207
Sp Racer's Avatar
Hello everyone,
Regards,
British Menace
You're not alone - we are experiencing the same problems
Not pleasant
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 04-24-2008, 05:08 AM   #9208
Pattojnr's Avatar
one thing to watch , i have found, is when i switched from old to new or new to old front steering hubs, they dont have the same turning radius. they stop travel on the pivot ball. this stalls the servo on full lock, and normally you are on the brakes also, this pulls down a pack quite hard, even had the same issues with lipo , till i found out what was going on. also if you narrow your front track width, make sure the hubs arent hitting the bottom arms on lock, same problem
Serpent - Walter RC
Old 04-24-2008, 08:36 AM   #9209
Hi Patto,
Paul makes a very good point here and one easily overlooked or taken for granted. I also found on occasion, I had too much steering throw and, un-be-knowing to me, the servo was still trying to push/pull to turn more, but my steering was locked and was already on full lock!! This causes a huge draw on the battery, weather you run Li-Po or NimH !!
Also, don't overlook the throttle servo doing something similar too !! ........
Especially if your like me and like a car with V. good brakes What can happen is this.
When the brake lever has stopped, and all your doing is applying the max torque the servo can put out to the brake lever. This then causes the same situation as with the steering scenario above.........huge power draw from the battery.
This gets worse if you use a very high torque servo. You just draw more Amps from the battery!!
If you use a high power servo for the throttle/brake. You may want to consider putting a stiff spring on the rear end of the brake linkage too.
This will then still give you max breaks, depending on the strength of the spring, but you wont be using the max torque from the servo and hence you will cut back on the power draw from your battery!
Either that, or just dont use such a high powered servo
On the throttle side. Is just the same as steering. Make sure the servo is still not trying to turn when the throttle slide is already, all the way open. But also check that the brake linkage has not bound up to and preventing further servo arm movement! This could also cause a large power draw.
Either way, I heard the Spektrum pro requires a higher then 'normal' amount of power/ Voltage to work and if the battery pack can not maintain this "required" power to the receiver, thats wheb we get problems.
Li-Po's, it seams does seam to conquer the problem Although it does require a little "messing about" in getting them plus the regulator to fit.
I now have a 950mAh Li-Po in the same location as normal for the battery packs. Just with the opening in the top deck opened out a little more. But I have been able to house the regulator right next to, in tha same space as the receiver! One of the advantages of using the V. small Spektrum Pro 3500 It's so small you are able to get both in the receiver compartment.
Sorry for the long post guys....lol. Kind of rabbled on a bit. Sorry.
Regards,
British Menace
Old 04-24-2008, 10:07 AM   #9210
My fault on the spur gear reference, I was still in RRR-EVO mode. I've been running the RRR for 2 yrs and just recently went to the G4RS so I do apologize for my error sir. I am currently running th 47/52 spurs at our local track and at the track in Houston I went to the 46/51 set of spurs. I have another buddy who is running the G4RS and he thinks he has a 48/52 setup on his car. I am not sure if there is a 48t 2nd gear spur but he said there is. Hope this helps.
G4RS
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
