Team Magic G4
#9091
if you are, let me know, ill get something to you to try out.
#9094
if your using the G4S, there is no reason to change. just get the speedshot on the car and the RS rear bracket that the shock tower mounts on and the new rear top arms and rear flash pit hubs. the RS doesnt have the ability to use the 2 lower hinge pin locations on the bulkheads. i modified the G4+ back plate to fit the RS and use the outer hingepin hole to be able to use the G4S rear arms. now i just have to get the swaybar attached to the arms
#9095
You wont go wrong with the Blitz bodies, they are great.
I am currently running the Altis 2.0 and it handles great but still have a soft spot for the Mazda 3.
Altis 2.3 looks good but havent tried it yet, waiting to get my new shipment in.
#9096
hey Don , hows things, had a chance to race this year yet ? i know its still cold over there. i recomend getting the new back support that the rear shock tower bolts to for your G4S. you running the speed shot also ?
I've only been out once for a club race this year (actually I was there to practice and didn't know there was a race but I joined anyway and ended up 1st). Still using the good ole G4s, I don't have the new back support or anything new for that matter. Racing season is heating up and I'll just have to see where the car stands before I plunk a good chunk of change for the RS. I'm willing to try anything you send over here.
PS thanks for all the info you've given to the G4 crew.
Don
#9100
Putting teh plastic parts in boiling water makes them a bit more pliable so they take shock much better.
Common to do in wing mounts on off road buggies.
usually if plastics will just snap but when boiled they absorb impact and return back to shap but it also depends on accident.
#9101
I'll give it a go then and let you guys know the result. We're in the process of converting our track from RoadRail to a permanent track with timber dividers, so the chance of broken arms will increase if I can't keep it off the boards.
Mike - put the new rear hus on the other night but have onle managed a few practice runs. Spent some time adjusting the clutch with the red shoe - not too sure if I'm going to get it right for our track. It either kicks in too hard and makes the car loose on power, or if I back of the tension on the spring it slips too much. Will have to try playing around with the weights and the gap to get it right. Otherwise, the car is coming along nicely.
#9102
Try a softer clutch spring if the one you have at the moment is too vicious.
#9103
rear arm up/down travel friction
heys guys if I do go rs quick flash setup do i need to change bulkheads again, as I already changed bulkheads to fit the new sway bar setup, what are the parts I need to do the rs change
cheers
cheers
#9104
cheers
#9105
What color spring are you using?
I've found that about 1mm pre load seems to be the maximum spring tension you can use before it starts becoming "undesirable"
Try taking out 1 weight at a time until it engages how you like it.
Shoot me a PM and I'll send you the clutch setup we are using at the moment.
Razzor - softer clutch spring sometimes makes the engagement harder - the harder spring makes the transition from slip to grip longer
