Old 02-18-2008, 06:22 PM   #9031
aussies1129's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Pattojnr View Post
what i did with the G4s, was take out the brake disc, take some material off the diameter of the disc. use a bench grinder or similar. do a little bit at a time, dont get the disc too hot. id rather remove material from the disc rather than engine or the mount.
yep thats a better option , oh and sorry for the two posts the server here at work is crap!!!
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 02-18-2008, 06:41 PM   #9032
dnitro's Avatar
Yeah...if you have to grind 1mm, then just take it of from the brake disk. I only had to grind .2-.25 of my engine so I didn't think it affected the performance, durability.
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 02-20-2008, 02:16 AM   #9033
Omarko's Avatar
would changing the spur gears and clutch bell gears help ? to higher teeth count I mean ...
Omarko is offline   Reply With Quote
Old 02-20-2008, 03:01 AM   #9034
Pattojnr's Avatar
Trader Rating: 19 (100%+)
you will find that the 0.8 gears are very similar in size even though the teeth count are different. i would grind the disk, safer, and a better option.
on the gearing, dont change it to suit a fitting problem, change it to suit the track and engine.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 02-20-2008, 05:12 AM   #9035
Hey Paul I ended up getting the premium power Rx battery from rcstation I have never dealt with them before so lets see what happens as Rcmush had no stock, what did you do to accomodate the lipo rx battery to the g4s how much modifying did you do?
cheers
H.E.I AUSTRALIA
Old 02-20-2008, 05:58 AM   #9036
Pattojnr's Avatar
cheers
i hope you do get the battery. i had things on order for over 2 weeks and nothing was happening. so i went through paypal for a refund. since then i have managed to get a hold of 3 LRP 1500mah lipos. they are small and a good fit. they also now have balance charge leads, first lot didnt have them, a better way to charge them, they last longer. if your stuck i have a new one in box. i have just assemble all the radio gear in mine. i should have taken a pic, but didnt. oh well. maybe after the weekend i could. basically i cut out the radio plate a fairbit. i made a 'u' shape plastic box that houses the lipo where the reciever fits. totally encased. then i cut out the radio plate above the throttle servo, enough to slide in the servo so it stands up . drill a hole in the plate to offset the tank. another plastic housing for the reciever backing onto the throttle servo. ill take some pics after the weekend. or before if i play wiht it some more.
Serpent - Walter RC
Old 02-20-2008, 06:13 AM   #9037
oh man that sounds like some serious open heart sugery on your g4s??where did you put the regulator as there is no room as it is did you encase it all in that plastic case you made?so how important is it to get the balancer?send me a pm with a pic and price.
cheers
H.E.I AUSTRALIA
Old 02-22-2008, 07:58 PM   #9038
rcrevolution's Avatar
Send a message via AIM to rcrevolution
ok sorry if this is a stupid question but,
can anyone post up droop set screws in mm and pivot ball space in mm as well?
the manual seems to be WAY off.
if possible
the distance of the set screw from the bulks to the end of the screw in mm
the distance of the pivot ball to the a-arm in mm
the distance inbetween the ball cups for the rear anti roll bar
the distance between ballcups for the steering linkage
the distance from one end of the shock to the other.
stuff the G4S manual listed that the g4rs doesnt have or is off on, anyone who has a caliper, it would be nice, now I know these change but I want a starting point, so anyone who has measurements that work, this would be a great help.
support your U.S. TM drivers
rcrevolution is offline   Reply With Quote
Old 02-22-2008, 09:40 PM   #9039
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Speaking of Lipos, what kind of charger are you guys running?
Thanks Jason
jscamry is offline   Reply With Quote
Old 02-23-2008, 02:04 AM   #9040
Thanks Jason
hey swallow 2 with balancer
cheers
H.E.I AUSTRALIA
Old 02-23-2008, 09:02 PM   #9041
i dont feel like spending $60 on a battery and more on a charger for it.
im gonna go with the 1100mah battery by tm, pick up 2 of those.
anyways, what is up with the rear dogbones? my pivot balls are screwed in to manual spec and i can play the dogbones out....
do i need to get unis, or longer 1/8th scale dogbones? seriously if I do thats one big issue.
Old 02-24-2008, 02:06 AM   #9042
Sp Racer's Avatar
http://www.rctech.net/forum/showpost...&postcount=238
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 02-24-2008, 06:34 AM   #9043
keavze's Avatar
is this thread 'dead'?
anyway, just a question: what's the diff between the G4S 2nd speed gear and the G4+/G4RS Duro 2nd speed gear?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 02-24-2008, 06:42 AM   #9044
basically duro means durable the housing is better made and the spurs are tougher
cheers
H.E.I AUSTRALIA
Old 02-24-2008, 06:47 AM   #9045
keavze's Avatar
cheers
hey, thanks for the quick answer...
btw, u got both a std G4S and G4RS? how do u find between driving the 2?
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
