Old 02-13-2008, 08:00 PM   #9001
British Menace's Avatar
Originally Posted by rcrevolution View Post
I think i found a mistake in the manual, the booklet calls for 50.70 mm from cup end to cup end for the rear anti-roll bar, one problem, 50.70mm means the cups are uncrews off the rod....
any suggestions?
I believe they had this mystake in with the special edition too.
I believe you will end up with a measurement of between 46 and 43mm.
These measurements may alter though once you come to set the car up...ie setting the tweek of the car with roll bar fitted.
Check when you have fitted the bar that, with shocks fitted too, the bar does not foul anywhere throughout the entire movement of the rear suspension, set your droop screws low....about at 1 to 2mm first.
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is online now   Reply With Quote
Old 02-14-2008, 01:55 AM   #9002
Pattojnr's Avatar
Trader Rating: 19 (100%+)
that measurment is 47mm. but dependant of your rear droop, it comes close to the top of the rear belt. more droop and a short link will touch the belt.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 02-14-2008, 02:35 PM   #9003
sonyb's Avatar
Default Need Help for my G4
Im new running on road....I play off road all the time.....
G4 techies I cant shift my g4 to second gear.....can you guys give me advise
I just follow the manual set up...but i need more info ...if anyone can post a
picture will appreciate your help....
sonyb is offline   Reply With Quote
Old 02-14-2008, 03:38 PM   #9004
aussies1129's Avatar
Trader Rating: 74 (100%+)
we have all been here before with this problem but its an easy fix!
ok take out you shoes from the housing and take it all apart!
now put it all back together making sure u follow the manual and that all is back together correctly, nowthe tension screws on each side of the shoes need to be equal on each side so you half screw in one side u do to the other now do them up until they cannot get any further in then back them out equally until u can use your finger tips to spread the shoes apart equally say 3mm both gaps need to be equal!! now insert your set screws this is for diametre of the clutch shoes place your shoes into the housing until it just touches the housing and it does not fit now take it out and screw these set screws ot a bit equally and put it back into housing it should just fit a spin freely if not repeat! now put altogether make sure you have the shaft pin in behing the shoes give that a go, you need to set up with adjusting those tension screws on where and when u want the 2nd to engaged!
goodluck
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 02-14-2008, 05:06 PM   #9005
Hello sonyb and welcome to the G4 family.
I don't have photo's to explain, unfortunately, but I will try my best.
There are four screws on the two speed shoe assembly. The set screws need to be set so as the shoes are very close to the shoe housing, but not touching. Being brand new, they may not be perfectly round at the moment so they may just catch in one place, high spots. This should be ok for now. The other longer screws, as you probably know, adjust the change up. IE: the amount of revs the engine gets to before the car changes to second gear.
Turning these screws in, both the same (!!), will make the car change up higher in the engines rev range, screwing these out will make the car change up earlier, at lower engine revs.
Now you need to find out if the car is in second all the time, or first gear all the time. You'll probably best notice this from running the car. If it sounds as though the clutch is slipping and the car doesn't take off very fast but is quick at the end of the straight away. Your probably in 2nd. If it takes off well, but doesn't go as fast as the other cars by the end of the straight away. I bet your in 1st.
Once you know which gear your in all the time, you can adjust your change up screws accordingly. 1/4 turn at a time until you hear it start to change.
Then go to 1/8 or even 1/16th turns to get it just right.
Note here: Make sure your engine is tuned well. If you start having to mess around with the tune of your engine, this can throw your change up out too !
Hope this helps.
British Menace
Old 02-14-2008, 07:46 PM   #9006
Originally Posted by UltraLineMotors View Post
You may Also want to take a look around our website at www.ultralinehobbies.com
I tried to email your site at [email protected]
But it came back??
Anything wrong?
British Menace
Old 02-15-2008, 09:54 AM   #9007
Dan/Ultraline's Avatar
Send a message via AIM to Dan/Ultraline Send a message via MSN to Dan/Ultraline Send a message via Yahoo to Dan/Ultraline
But it came back??
Anything wrong?
British Menace
We have been receiving emails through out the night and today. Please try again or fill free to call with any questions.
Dan/Ultraline is offline   Reply With Quote
Old 02-15-2008, 10:25 AM   #9008
razzor's Avatar
But it came back??
Anything wrong?
British Menace
Bud you have the r missing in ultraline
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-15-2008, 07:42 PM   #9009
Lol.well noticed razzor ! Although I looked and I did put in the "r" when I tried to send the email.
I've since sent it again and it went through this time. But thanks for the heads up though.
Are you still running your G4 these days Razzor? What do you think of the new, shorter chassis and rear end this time round?
I feel like yourself and a few others have been around this car for ever!
Will be having another go with it this year, although not as much as I'm going to try some off-road this year. lol
British menace
Old 02-16-2008, 07:12 AM   #9010
Default G4S Shock Bladder
Hi Guys,
I have accidentally damaged one of the shock bladders. Can I change to another brand of shock bladder or do I need to get the original? I am thinking of changing 4 of them if I am unable to get the original.
If other brand shock bladder, what brand is recommended?
epsilon is offline   Reply With Quote
Old 02-16-2008, 08:19 AM   #9011
Pattojnr's Avatar
Originally Posted by epsilon View Post
Hi Guys,
try to get the Kfactory blue shock bladder, they are a bit thicker and less likely to turn inside out as well. cant remember the part # sorry.
Serpent - Walter RC
Old 02-16-2008, 09:01 AM   #9012
RC-ProSpeed's Avatar
Hi Guys,
Mugen Blader (MTX4/MRX4) works great.
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 02-16-2008, 09:12 AM   #9013
sonyb's Avatar
Default Thanks
Thanks for your help......
another question ...What is your opinion if I put OS 18TZ on my G4
Old 02-16-2008, 10:57 AM   #9014
thanks....the part number is K14121..
Old 02-16-2008, 04:51 PM   #9015
Hi Guys,
The orange Serpent ones also work. They come with sponge compensators and are prety reasonably priced, for Serpent.....lol
British Menace
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
