Old 02-09-2008, 04:00 PM   #8956
aussies1129's Avatar
Trader Rating: 74 (100%+)
hey Alex check your droop there mate that set screw could go down a fair bit more to pull your wing up then check your droop again I get mine close to parallel on the chassis then adjust from there,that should pull your dog bone into the cup a bit more, but like mine they are very loose even with oring installed??I think I will go unis in the rear. racing today but weather is crap!!!
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 02-09-2008, 04:56 PM   #8957
British Menace's Avatar
Originally Posted by Omarko View Post
Hey guys
this thread is in my bookmarks now and I read it from beginning ... lots of good info here ...
same as Michael (aussies) I got a G4RS last week and nearing the completion of the build which is pretty exciting ! Still a lot to learn for a newb like me but I know I'll get there
will post pics of my G4RS soon !
btw you are right about the rear drive shaft, with same settings as yours, it looks like its about to come out, see pic:
Hey Omarko,
Paul is right, (aussies1129) Looks as though you haven't set your droop screws yet. Once these are set, the shafts will go into the cups a little more.
But also, check your cars track, width at the rear wheels and ensure this is 200mm or slightly below. This should also ensure the shafts are fully in the cups.
If you don't have a set up guage (set) to set your droop, try placing the chassis, no wheels on, on a flat service, glass is good for this! Then take your ride hight guage or just a rule, and measure from the glass surface to the underside of the rear upright, the lowest side of the two pivot balls, lol. Do this on each side. Set this at 4mm for a smooth track and 2 - 3mm for a more bumpy track. You can do this at the front too. Try 0mm for a bumpy track and 1 or 2mm for smooth tracks, you can mess with this once you get used to the car and want to try some tuning.
If you guys already know all this, my applogies :-)
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 02-09-2008, 04:58 PM   #8958
I meant Michael (aussies1129) sorry
Old 02-09-2008, 06:01 PM   #8959
Sp Racer's Avatar
Hey guys
Don't stress!!!......I had the same "concerns" - once you set your droop , they don't even come close to looking like falling out...trust me!
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 02-09-2008, 06:18 PM   #8960
rcrevolution's Avatar
Send a message via AIM to rcrevolution
anyone have some tips specific to building this car?
I already know hwo to build these cars , but like gensei posts before about the shocks.
if anyone has tips like thos I would apreciated it.
like for example what shock oils and diff oils are you using?
rcrevolution is offline   Reply With Quote
Old 02-10-2008, 12:02 AM   #8961
Omarko's Avatar
phew ...
just finished mine ...
still needs a set up though ...
here are pics showing the whole process from the box to the final product - LINK CLICK HERE
PS: this is my first car I built on my own and first body I painted and cut so please no flaming ta
Omarko is offline   Reply With Quote
Old 02-10-2008, 01:25 AM   #8962
the g4rs manual has a few mistakes I cant find the rear hub setup diagram in exploded view? also rear hub setup page has front nad back around the wrong way??anyone else come accross this?
H.E.I AUSTRALIA
Old 02-10-2008, 11:14 AM   #8963
looks great, only thing I would change would be the black on the body, bright colors are easier to follow on a dark surface.
Old 02-11-2008, 04:08 AM   #8964
Omarko's Avatar
we'll see how it feels on the track
Old 02-11-2008, 05:09 AM   #8965
hey if your are happy with the colour of your car body then all is good get it out on the track and have fun!!
cheers
H.E.I AUSTRALIA
Old 02-11-2008, 04:33 PM   #8966
Damnit YLLIB your so called energy bar was 2 yummy reese's cups, and I ate them before I even started working on the car! DAMN MY OBESITY!!!
anyways great service YLLIB, first time I have bought any car in the G4 series whether it be the mongoose or g4s that I havent had a problem picking it up at the door or missing it. This time it seems like a winner.
anyways thanks for you're bussiness I will be recommending you to everyone who wants an r/c car.
and thanks for the yummy chocolates which btw came frozen since its so cold and that made them taste 100 times better.
EDIT: BTW I AM THE NEW PROUD OWNER OF A G4RS!!!!
Old 02-11-2008, 04:58 PM   #8967
Congrats rcrevolution on getting your G4RS !!
YLLIB I am surprised at you.............. no milk with that chocolate for the man??
Poor guy could have died with thirst..lol
Good service sir.
British Menace
Old 02-11-2008, 06:22 PM   #8968
I have a few bones to pick with TM and the G4RS.
First off all, make a proper manual
I was looking at the diff build section and it showed philips head screws , cmon philips? what is this 1998? why the lack of allen head screws?
Second of all, do not talk about a different model in one model's Manual.
I counted at least 3 places where it mentions the g4+, I GOT THE G4RS, dont make me feel bad about not getting the G4+ in the RS's manual.
Third, not all things are labeled with proper measurements, I know this is something i will eventually change no matter what, but things like the distance between the two brake pads with the screws in isnt anywhere to be found, my g4s manual lists that distance so i will have to go by that.
For the car.
FIX THE DAMN TENSIONER, the G4S had the same issue, once you put on the rear belt tensioner you can not adjust the brakes, grrr!!!!
Finally are these suposed to be turn buckles? are these bronze looking twigs turnbuckles? cmon my 6 year old cousin can bend these things in 1/2, what happened to the g4s's strong turn buckles?
Sorry if Im coming off rude or anything, I might just be angry at other things and venting them out on this car, but after I spent $400 I would expect a slightly better constructed car, yes its nice getting hop ups over the g4s, but not at the sacrifice of quality on some parts.
Old 02-11-2008, 06:37 PM   #8969
For the car.
I can agree with you on the manual they need to get someone to proof read it first before publishing??this is my fourth TM car I have built from scratch so building was not an issue, and thats where TM got there weight reduction from thinner turnbuckles and chassis etc?as long as it performs on the track I dont care!
cheers
H.E.I AUSTRALIA
Old 02-11-2008, 06:43 PM   #8970
yes the more I read this manual, the more the g4rs seems like a rushes version of the g4s, the g4s manual goes into so much more detail than the rs manual.
sigh oh well, next time I will go with a Xray or mtx-4
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
