Old 02-07-2008, 05:13 PM   #8941
gansei's Avatar
Originally Posted by Sp Racer View Post
Gansei, what brand of shock oil are you using?
Did you grease the O ring seals when you assembled the shocks?....if so, what grease did you use?....I use Associated "green slime"
Petroleum based greases can make silicon parts swell
i used Much-More Shock Slime and Kyosho 500~600
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 02-07-2008, 06:42 PM   #8942
rcrevolution's Avatar
Send a message via AIM to rcrevolution
so the LX shocks do not come on the rs already?
and the way gensei said should make them work smoother?
rcrevolution is offline   Reply With Quote
Old 02-08-2008, 05:31 AM   #8943
aussies1129's Avatar
Trader Rating: 74 (100%+)
helP!
my G4RS is basically together but I have noticed that my rear drive shafts are very loose I can nearly pull them out I have the oring in there and bulkhead pin thru inner hole and have 4mm rear 2.5 mm front??any suggestions, how loose is ok??why didnt they put unis in the rear??
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 02-08-2008, 06:41 AM   #8944
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by aussies1129 View Post
helP!
cheers
put some tires on it and measure your track width at the rear.
if its over 200mm then you wont have a problem. havent used dog bones on the rear for a very long time, so cant really help you there. but look at shimming the hub axle closer to the diff side, see if this helps. as long as the bones wont fall out, and they dont push into the diff cups at full travel, then i think you will be ok. they obviously have more endplay than a rear cv, its just the way it is.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 02-08-2008, 06:50 AM   #8945
hey Paul I thought you would be around mate WA time is how many hrs behing QLD? I will check the car width but the G4rs comes with dogbones so i have to do with that I think I definately need to shim they are fairly loose to my liking, also i found that when i used a one piece K engine mount the 2nd gear comes withing 1mm of touching the clutch housing???
cheers
H.E.I AUSTRALIA
Old 02-08-2008, 06:58 AM   #8946
Pattojnr's Avatar
cheers
1mm is ok, remember endplay should be around 0.1mm so it should be ok, unless you run a huge enplay gap. but if your track width is over 200mm, you screw in the pillow balls to get it to 200mm, so you infact are taking some play out of the bones.
QLD isnt that far infront, you guys seem the only ones not with daylightsaving. so i think its only like 1 hours difference.
Serpent - Walter RC
Old 02-08-2008, 08:15 PM   #8947
hi.......everybody
i stopped by at speedworld today (speedworldraceway.com) and got all the parts that i need . If you guys need parts check'em out he got some in stock....he said there are more parts comin in couple weeks.
goldfishy is offline   Reply With Quote
Old 02-08-2008, 09:25 PM   #8948
Originally Posted by goldfishy View Post
hi.......everybody
hey I would love to drop into speedworld but it will take me a while as its about 9000miles away15hours on a plane
easier to order on speedworlds online store
cheers
H.E.I AUSTRALIA
Old 02-08-2008, 09:55 PM   #8949
Sp Racer's Avatar
hey sp what weight shock oil do you use,I have been running 50w in my g4s and the rs kit comes with tm600?
cheers
At the moment - Kyosho 600 with 1.2mm pistons
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 02-09-2008, 04:02 AM   #8950
finally its over I can go to bed before 12am but the wife still says sleep with your new baby in the shed!
some pics of my new girlfriend !
cheers guys!!!
H.E.I AUSTRALIA
Old 02-09-2008, 05:25 AM   #8951
Pattojnr's Avatar
Looking good Michael
Serpent - Walter RC
Old 02-09-2008, 06:25 AM   #8952
Hey no worries Paul cheers mate! do you have any suggestions on how to get rid of rain?my mate in Sydney is in the same boat rain everywhere.also what was the latest about your track is there another one coming online??we have the same problem here in Cairns for offroad "no track".
cheers
H.E.I AUSTRALIA
Old 02-09-2008, 06:36 AM   #8953
Pattojnr's Avatar
suggestion for the rain ! Perth ! no rain here apart from one day in 7 weeks. no news on the track, at the mercy of Councils . until then , bunbury is the only place to race onroad, unless you want to go to Kalgoorlie.
at least you still have onroad track, off road just isnt the same
Serpent - Walter RC
Old 02-09-2008, 06:55 AM   #8954
I really wish i could send the rain over mate!as we just dont need it all dams are full rain water tanks full etc etc, I also understand your frustraion regarding a decision by council because of some old granny complained about the noise.thats gota piss ya offwouldnt it be great to get a track like gansei's right in the middle of town yippee!
have a good one!
H.E.I AUSTRALIA
Old 02-09-2008, 02:55 PM   #8955
Omarko's Avatar
Hey guys
this thread is in my bookmarks now and I read it from beginning ... lots of good info here ...
same as Michael (aussies) I got a G4RS last week and nearing the completion of the build which is pretty exciting ! Still a lot to learn for a newb like me but I know I'll get there
will post pics of my G4RS soon !
btw you are right about the rear drive shaft, with same settings as yours, it looks like its about to come out, see pic:
Omarko is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
